Old 11-15-2002, 03:13 PM   #481
Robbie, I meant no disprespect to you or anyone else on a personal level when i made those comments. It was more tounge and cheek. But yeah, I think the website could be better. I'm not sure if you agree with that, but as a fan of RC and a participant in the hobby I think I have a right to comment on the product, wether that be the actual product or the websites supporting and show casing the product. I'm sure you can agree with that. Moreover, please dont stop posting. I think the vast majority of us would welcome and appreciate your expertise and insider knowledge. Dont feel slighted by any of the comments made in here, I think alot of it needs to be taken in context, and again, I dont think anyone meant any disrespect.
Thanks, please keep posting.
P.S. the car looks awesome. Any further thoughts or insights into the cars performance? How much better is it than the MTX2?? I mean, based on your personal experience on the track.
calimassive is offline   Reply With Quote
Old 11-15-2002, 03:17 PM   #482
ROBBIE C's Avatar
Send a message via AIM to ROBBIE C Send a message via Yahoo to ROBBIE C
There are two battries for this car 650mah 730mah both are from Mugen heres the part numbers B0217 B0218 I think Nitro sales batteries also for cheaper price.
ROBBIE C is offline   Reply With Quote
Old 11-15-2002, 03:21 PM   #483
ilaybrk's Avatar
whats up brother man
ilaybrk is offline   Reply With Quote
Old 11-15-2002, 03:25 PM   #484
ilaybrk's Avatar
robbie where is on off swich on MTX3 and are the front and rear difs difrent.
Old 11-15-2002, 03:53 PM   #485
ROBBIE C's Avatar
Cool I'm over it.
I really like the way this car transsitions fron right to left and I also think the over all performance is better do to the low CG's in the car, you can drive more aggressive with control.
Bottom end seems to be better because of smaller flywheel.
Topend seems to be better because of final drive, of coarse you need to use different gears at least their avalible.
What I can't under stand is the front diff grears not being in the kit, that really bites but what can you do?
confused:
Old 11-15-2002, 03:55 PM   #486
ROBBIE C's Avatar
As for the on off switch there is a option, eather you use transponder bracket or switch holder trust like on the MRX-3.
Old 11-15-2002, 04:00 PM   #487
ROBBIE C's Avatar
Someone asked about running this car with rubber tires, I think it would work just fine, remeber this if your car works good with rubber then it will work great with foam.
Old 11-15-2002, 04:04 PM   #488
ilaybrk's Avatar
how the hell are you brotherman what about the diffs are same or difrent
Old 11-15-2002, 04:06 PM   #489
Send a message via ICQ to Cartman
Robbie hi there it was me who asked about rubber
I race for the Uk team (finished 15th in the uk) and am waiting my new mtx3 i also write for one of the UK's top mag's radio race car international.
any tips you can post i would appreciate, i may also quiz you a bit if thats OK via pm
ps i wish i could get your job in this country!!!
have you tried rubber tyres yet?(you have answered) as we run these in the UK
we were told it had a solid rear axle and the rear roll center/camber change was wrong for rubber, do the mtx2 rear hubs fit?
also are the gears the same or does the front diff fit and do you need to change the pulley to get the mtx3 final drive ratio?
alot i know but we all need your help
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 11-15-2002, 04:33 PM   #490
ROBBIE C's Avatar
You guys should also try out the new stratus body it works really good, I was verry suprised by the performance of this body.lots of steering.
Old 11-15-2002, 04:39 PM   #491
ROBBIE C's Avatar
Hello Mark the diff housings are different but the internal gears interchangable.
Old 11-15-2002, 04:58 PM   #492
ilaybrk's Avatar
not mark jack h
Old 11-15-2002, 05:06 PM   #493
stefan's Avatar
Send a message via AIM to stefan
Default Robbie,
good to finally see you here and that you put an end to this gearing discussion
Now I also got a question for you:
I have my MTX2 reconfigured to a point where it's very similar to the MTX3 (before I ever saw the new car)
I have a 750 mAh AAA pack mounted on the chassis, it's not absolutely in the center but close.
I run the newer Kawahara top deck, with the receiver where the battery was before. I also have the kawahara narrow rear ed conversion (and a lot of other stuff) on the car.
Here is the question now. Do you think it will be a considerable difference between this car and the MTX3, big enough to justify a new car for me?
I have a pic of my MTX2 attached.
Thanks Robbie.
stefan is offline   Reply With Quote
Old 11-15-2002, 05:08 PM   #494
stefan's Avatar
I forgot, I also have the Kaw 2 speed and the small centax flywheel.
Basically everything that the MTX3 has, except the laydown servo...
Old 11-15-2002, 05:49 PM   #495
ROBBIE C's Avatar
Your cars looks very good and I'm sure it runs as well as it looks.
Here's why I think change is good.
MTX-3 batteries in center, more balanced from side to side front to rear, with your setup you have to much weight forward.
Fuel tank is much lower( low CG's)
Anti squat adjustment in rear for more cornering speed.
Front bell crank steering more reactive and equal amount of steering, also (low CG's)
Different front steering angles, more or less steering reaction.
Low belt outside of chassis, low friction.
New rear sway bar more reactive because angle.
Rear uprights you can change the roll center of the car easily.
Different final drive, more straightaway speed.
The list go on, these are the things I noticed and like.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
