Old 06-06-2003, 05:50 PM   #4876
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by eddiethefish
Hello TSR6,
There is no altered on the spring in any ways. I would just like to know the differences among the two spring brand, see attached pictures--left is FiveStars, the other is Mugen. They are the same in length/height, have the same thickness. The only difference is the number of coils. Please advise.
Regards,
eddie
It's the same thing.
With a two springs of the same dia. wire, the spring with the less coils will be stiffer.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 06-06-2003, 05:55 PM   #4877
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
oh! ok... Thank you.
Here's the picture of my twins!
eddiethefish is offline   Reply With Quote
Old 06-06-2003, 06:02 PM   #4878
PMT
Eddie, TSR6 is right on this one. Basicaly if a spring is the same length/height as the stock one but less coils it means that the wire that it is made out of is shorter. So even though the diameters of the wires are the same it is going to be stiffer because it is shorter. Example, take a pen, hold it at both ends and you can probably bend it easily. Hold it in the middle with your fingers about and inch apart and it is going to be hard to bend. Same principale applies to the wire that the springs are made out of, longer/more coils=softer (easier to bend), shorter/less coild=stiffer (harder to bend).
This can also be used as a tuning aid. You can use stock springs and cut 1/2 to full coils off of them to alter the stiffness of them.
PMT is offline   Reply With Quote
Old 06-06-2003, 06:04 PM   #4879
PMT
Sorry, you guys snuck in there before I hit submit.
Old 06-06-2003, 06:19 PM   #4880
Thank you! I'll have to bring my softer one, [COLOR=red]RED, just in case I need to soften the rear.
Old 06-06-2003, 10:08 PM   #4881
Taylor-Racing's Avatar
Yep.
You could work it out - a bit fiddly though. The thickness of the paint makes it practically impossible to get an accurate reading of the wire diameter.
Measure the diameter of the wire, the number of free coils, the outside diameter of the coils and apply this:
p = (G * F * d^4 ) / ( 8 * N * ( D - d )^3 )
p = rate in lbf/in
G = torsional modulus of elasticity = 11.5 * 10 ^ 6 for most spring steels
d = wire diamter (inches)
N = number of working coils
D = outside diameter (inches)
Taylor-Racing is offline   Reply With Quote
Old 06-06-2003, 10:55 PM   #4882
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by Taylor-Racing
Yep.
p = rate in lbf/in
great information. can you illustrate this with an example?
Manticore is offline   Reply With Quote
Old 06-06-2003, 10:56 PM   #4883
dg8one's Avatar
eddiethfish
can i order this part by phone (kawahara sway bar, five star alum shock stopper) cause i dont have that paypal
thank you
nelly
dg8one is offline   Reply With Quote
Old 06-06-2003, 11:08 PM   #4884
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
in the formula mentioned, what is meant by the wire diameter and outside diameter? If I understand it correctly, you want the actual wire diameter and the overall diameter (including the paint)? What does the overall diameter have to do with it since the only difference between it and the wire diameter is the thickness of teh paint and last time I checked, paint isn't significant enough to change the spring rate.
Racing4Evo is offline   Reply With Quote
Old 06-06-2003, 11:23 PM   #4885
RCTech Member #2
TSR6's Avatar
Spring Rate = (Gd^4) / (8ND^3)
as said before, G is 11.25x10^6 for most steel springs
Wire Diameter, or D is measured with a caliper, and should be the same for the whole spring ( unless it is a progressive spring, but you cant use this equation on a progressive spring anyways... so if it is progressive...stop here. )
N - Active coils.. only the ones that are doing the compressing. You don't want to count the "flat" coil that sits on the sping cup.
D = Mean coil Diameter ( Racing Evo, this is for you ) - The mean coil diameter is the Outside diameter, minus the wire diameter (D).
Troy
RCTech Member #2
Old 06-07-2003, 12:38 AM   #4886
Data's Avatar
Default Re: Question re Spring
Hello,
I'm now using the FiveStars BLUE spring. When compare to the Mugen's Blue, I've noticed that the FiveStars has less coils. They both have almost the same thichness at 1.74mm in diameter and of course the same in height.
What would the less coils spring perform when compare to the Mugen's one? Any better or worse?
Thank you,
just go by the spring rate of the springs you got (if it is specified). since you are not going to modify the spring, don't worry about # of coils or wire diameter. not enough information is not good, too much information is not going to help either.
Data is offline   Reply With Quote
Old 06-07-2003, 12:44 AM   #4887
RCTech Member #2
TSR6's Avatar
Default Re: Re: Question re Spring
I think the whole point was that he did not have the spring rate for the other springs, and was wondering how it compared to the Mugen springs.
I used the cut-spring example to show that less coils = harder spring. I really wasn't suggesting to cut the springs, although it is an option...
Troy
RCTech Member #2
Old 06-07-2003, 05:31 AM   #4888
Actually, this might be easier:
http://faq.f650.com/FAQs/SpringRateFAQ.html
Old 06-07-2003, 05:50 AM   #4889
VenomWorldOrder's Avatar
oww no don't enter the realm of maths and physics please!
sometimes it's easier if you just say to yourself: "it is, becouse it is"
get a pen spring compress it. soft. now stretch it out. it has now become harder. same principle.
VenomWorldOrder is offline   Reply With Quote
Old 06-07-2003, 06:06 AM   #4890
The "wire diameter" is the thickness of just the wire that is used to make the spring.
The "outside diameter" is the overall diameter of the whole spring.
The reason the formula wants these two measurements is that it calculates the "mean" diameter of the spring - that is, it calculates the spring diameter as measured from the centre of the wire on one side to the centre of the wire on the other side.
. . . and the reason it does that is because springs work with torsional loads - that is, as the spring compresses, the wire is actually twisted about the certre point of the wire's cross-sectional diameter. This is where the modulus of elasticity comes into it. As you might imagine, aluminium springs, having a lower modulus of elasticity, would not be as strong for the same diameter of material.
No, paint is not a significant factor in the spring rate.
The issue here, is that the paint on some springs is quite thick, and measurement, therefore becomes problematic. When we are talking about wire diameters of about 1.7mm, I wouldn't be surprised to see paint thicknesses of .5mm if you include both sides of the wire - that's a significant error being introduced.
Hope this helps.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
