Old 06-04-2003, 12:15 AM   #4741
Jonathan's Avatar
PMT
I laid down a small spew on O.D. as well tire split management a while back. They didn't buy it... But I did not do as well a job as you did in selling it either.
Speaking of techical info. Please enlighten me on the following.
Shock positions... as I understand it, the more laid down, the softer and also more progessive. Now..I have only used these diff. pos. to soften or stiffen. What am I missing out on by not using the "progressive" part. I'm thinking less responsive but more mid corner bite??? Please....
Ackerman... A= less initial and smoother but more throw... C= twitchy but less throw and thus less overall steering??? C felt like the 2 deg of front toe out I ran once in my v1rr. Is it a misconception that more toe out yeilds more steering cuz ulitimately you are getting less throw at the outside wheel... Again...please
Droop... less in the front yeilds more on power steering ... But I've read that Salven uses droop to keep tires in constant contact w/ pavement to get on power steering. He can't be wrong....?
What's better? Stiffer front spring and say 40's or softer front spring and 45's. Huuummm..
Lastly...boxers or ....j/k.
Thanks in advance. I have more questions later if you don't mind.
Jonathan
Check out my avatar!!! My son Ethan Henry.. Born Feb 1, 03
Jonathan is offline   Reply With Quote
Old 06-04-2003, 12:21 AM   #4742
Jonathan's Avatar
Kev.
Sometimes I feel like I should of kept the RR... Nahhh.
BTW. Where did you get a 22 pinion? I will see you this weekend at Rev.
Seeya!
Old 06-04-2003, 12:34 AM   #4743
InitialD's Avatar
Jonathan
I'm not PMT but I'm also learning. I'll try and answer your questions wherever I can in the hope that I can be corrected when and if I'm wrong and can affirm myself if it's correct information that I got.
Progressiveness of a shock as how I understood it is the shocks will be able to absorb small bumps without working through the entire suspension of the shock. So your car will still remain flat and stable even when working through the bumps.
Concerning front droop for on power steering, that is what I read as well. Michael Salven argues that when the car is on power, weight from the front transfers to the rear anyway, regardless if you're having more or less front droop. By limiting front droop, the front tires will lift on power and hence you loose front traction ansd steering. By using more front droop, you maintain front tire contact patch even when the car experiences weight transfer to the rear. I think this is what was discussed in the starting grid as well in one of the technical conferences and they came to the same conclusion.
As for tires, I've been experimenting the combination that you have mentioned above. I find that softer tires and harder shocks make the car handle better so far as the tires last you. Harder tires and softer shocks tend to make the car more lazy.
BTW, cool son Looks a lot like the father
Old 06-04-2003, 02:37 AM   #4744
Roger's Avatar
Check out my avatar!!! My son Ethan Henry.. Born Feb 1, 03 [/B][/QUOTE] Jonathan: My daughter was born on Feb 01, 2001. Same B-day as your son
Roger is offline   Reply With Quote
Old 06-04-2003, 02:46 AM   #4745
sparksy's Avatar
Trader Rating: 14 (94%+)
1st of Feb is a very good day......
sparksy is offline   Reply With Quote
Old 06-04-2003, 02:50 AM   #4746
Vinyard's Avatar
Jonathan: My daughter was born on Feb 01, 2001. Same B-day as your son [/B][/QUOTE]
talk about a match made in rctech!
Vinyard is offline   Reply With Quote
Old 06-04-2003, 02:59 AM   #4747
Corse-R's Avatar
Originally posted by RClover
here's my new pics after months of bashing...
Ugh! you like to ride your machine on quite bumpy tracks. Mine isn't scratched so much. Ride on pretty flat tracks, don't hit boards and don't assault pianos
Like to keep mine chasis as shiny as I can, only small scratches on front and rear ends due to hard driving.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-04-2003, 03:03 AM   #4748
Manticore's Avatar
R/C Tech Charter Subscriber
well, he needs to battle with those snakers in singapore !
who doesnt love shinny, bud?
Manticore is offline   Reply With Quote
Old 06-04-2003, 03:36 AM   #4749
Send a message via Yahoo to speedy100
Default sirio 5 ports aac - help
hi manti, i viewed a few page back and noticed that you are running a siro 5 AAC. any comment for that ? I run mine yesterday but it is not as good as i thought. I stripped off the motor today and found noticable wet in between the chamber and the housing. I believe there is some leakage but don't know where. also, is it mandatory to use the OS glow plug on sirio turbo head ? thanks anyone who have this engine can give me some advice too...
speedy100 is offline   Reply With Quote
Old 06-04-2003, 03:43 AM   #4750
Manticore's Avatar
Default Re: sirio 5 ports aac - help
right, i started running my AAC with a AIP modified carb from the first c.c. and the engine is clean as heaven. there is not any leak at all so far after around 1 gallon of fuel.
I listened to Mr. Lam's advice and use OS plug as he said the Novarossi plug thread is a bit too tight for sirio turbo button.
try to use colder plug for your sirio such as OS 7 and this will make your plug lives longer.
Old 06-04-2003, 04:07 AM   #4751
Manticore's Avatar
if you are able to use novarossi plug, then you shouldnt have problem unless you have loosen head screws or you have a leaking exhaust gasket but there could be some other reasons.
the engine is fast out of box and it is very easy to run in if you follow the instruction.
Old 06-04-2003, 04:08 AM   #4752
RClover's Avatar
nothing much i could do actually, forgotten to adjust the spring collars on few occasions...
RClover is offline   Reply With Quote
Old 06-04-2003, 04:10 AM   #4753
Manticore's Avatar
seems like you are too happy with your mugen !
Old 06-04-2003, 04:11 AM   #4754
RClover's Avatar
mine looks almost as bad as yours..if not mistaken!
no time to bring the car into pit as was under hot persue by some snakers...
Old 06-04-2003, 04:12 AM   #4755
Manticore's Avatar
dont worry, they are little snakers ! worms, bugs
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
