Old 06-03-2003, 12:46 PM   #4696
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by eddiethefish
Keep'em for quick change of spurs, if I need to. Sorry
i know, just kidding ! i prefer stick with the original ones.
by the way, are you about to get the japanese mod Rody engine?
Manticore is offline   Reply With Quote
Old 06-03-2003, 01:01 PM   #4697
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Kondo engines were all out when I was in Japan, despite several effort visiting four different r/c stores in Tokyo. Hopefully, there will be some when I go next time. I figure it may worth the money to buy one and see what Mr. Kondo has done to the engine.
But, anyway, even a typical engine would cost a lot more than HK or in the States--exclude OS.
eddiethefish is offline   Reply With Quote
Old 06-03-2003, 01:03 PM   #4698
Corse-R's Avatar
What about a Next Racing? Looks quite good. Shame of the 300UK Pounds plus Tax that wants their European Importer.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 06-03-2003, 01:15 PM   #4699
yike!
anyway, got any pictures of the "Next Racing"?
Old 06-03-2003, 01:22 PM   #4700
yike!
http://www.active-hobby.com/j/next.html
Do you have any pics of the kondo engines or a web address?
MR STI is offline   Reply With Quote
Old 06-03-2003, 02:45 PM   #4701
Send a message via ICQ to Cartman
I have replaced my Kawahara light weight housing on both 1st and 2nd spur with this Team Active ones. Will see if they work well or not.
these look like KFactory parts!!!
Fish where you get the alloy front shock tower show more please!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 06-03-2003, 03:22 PM   #4702
Ah10's Avatar
Send a message via ICQ to Ah10 Send a message via AIM to Ah10 Send a message via Yahoo to Ah10
send me your kawahara adaptor and housing fish !!!!!!
NO NO NO, those are mine!
Ah10 is offline   Reply With Quote
Old 06-03-2003, 03:27 PM   #4703
Vinyard's Avatar
I've seen this in Japan, but did not get it, since the AIP's MTX-3 Floating Mount will be launched anytime soon.
Always wanted to try Lola on the MTX.
erm fish, could i be on the list to test it out too???
Vinyard is offline   Reply With Quote
Old 06-03-2003, 04:34 PM   #4704
PMT
As mentioned yesterday Collari Sirio pictures follow.
.21 Engine
PMT is offline   Reply With Quote
Old 06-03-2003, 04:38 PM   #4705
PMT
.21 AAC Sleeve
Old 06-03-2003, 04:40 PM   #4706
PMT
Low Res .12 ABC Sleeve
Old 06-03-2003, 04:41 PM   #4707
PMT
Collari Sirio Carnk
Old 06-03-2003, 04:42 PM   #4708
PMT
Collari Sirio Crank 2
Old 06-03-2003, 04:43 PM   #4709
modellor's Avatar
Default Re: Re: Overdrive
Originally posted by PMT
Stephen, I was thinking about your post some more and should wanted to reiterate that the overdrive ratio chart that I posted is for the 16/19 combo. This gives about a 6% overdrive ratio to the car. This is why you need to run a split to have a drive ratio of 1. With the stock pulleys you would indeed be able to run same sized tires front and rear. The advantage of the overdrive pulleys is that you can run a smaller front tire. This has a couple of effects including the following:
1) Reduces the amount of side bite on the front. Has the effect or gives the feel of slightly number steering responce and has less of a tendency for the car to traction roll.
2) Allows you to drive the car harder, more punched and allows you to use the throttel to rotate the car.
Basicaly the whole point of this is to allow you to drive the car in a similar fashion as an 8th scale car using the throttel to rotate the car and rather than having to wait while cornering for the car to straighten before accelerating, it allows you to accelerate harder and sooner out of the corners i.e. right after you apex.
Hope this helps. If you have more qestions feel free to ask.
I agree with your method. Its apparent you have some knowledge of true overdrive however your chart is still inaccurate unless you know the given rpm of the engine. If someone hands you a new engine like say motorman during a meeting and it has 4000rpm more than the engine you were running then your overdrive calculations are worth squat and you have to recalculate for each give tire diameter.
modellor is offline   Reply With Quote
Old 06-03-2003, 04:44 PM   #4710
PMT
This is all for now. I have a .12 3 port AAC & 5 port AAC + .21 Off Road that I will take some pictures of in the next couple of days.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
