Mugen MTX-3
Old 06-02-2003, 03:58 PM
  #4591
EVOLUTION's Avatar
Originally posted by PMT
I have not tried the .12's so I can not comment on this but with the .21's they are ok. Performance is roughly equal to the M. Collari Modified Sirio engines that we have been using for the last couple of months. About equal to what you would expect from any top of the line mod engine i.e. JP, Collari Sirio,RB Rody, NovaMax etc. The power band on most of these engines are fairly similar and the differences in performance are small. For most these type of engines are not worth the money. In order to realy utalize the extra power every thing must be perfect including proper clutch adjustment, pipe length and needle settings. If any of these are off or if your set up is off these type of engines only make your problems worse.
If I find some time in the next couple of days I will try to take some pictures of the M. Collari modified Sirio .12 for you guys and post them here. Really nice engines, all hand done not mass produced modifieds like JP, RB & NovaMega .
That would be cool if you could put up some of those collari pics and any larger nova max pics you have,thanks.Have you actually run the modded sirio,if so what's your impressions and opinions of the performance?
EVOLUTION is offline
Old 06-02-2003, 04:00 PM
  #4592
TBR
TBR's Avatar
Heres a pic of my M Collari Sirio modified. And it in the weekend for the first time.
Went quite nicely, though I didnt go hard out on it with it first time out.
TBR is offline
Old 06-02-2003, 04:07 PM
  #4593
dg8one's Avatar
show us the inside
thanks
nelly
dg8one is offline
Old 06-02-2003, 04:15 PM
  #4594
PMT
We tried them for the first time at the Speedline race in Vegas in April. Was impressed, very, very fast!
PMT is offline
Old 06-02-2003, 04:42 PM
  #4595
RCTech Member #2
TSR6's Avatar
The only types of files that you can attach are gif, jpg, png, txt, zip, bmp, jpeg and pdf.
Send me the exel sheets. I can zip them, and attach them if you wish. [email protected]
TSR6 is offline
Old 06-02-2003, 05:04 PM
  #4596
TBR
TBR's Avatar
Originally posted by dg8one
show us the inside
thanks
nelly
I took a pic of the internals but the pictures a are quite blury (I am not a noted photographer)
Whe I replace the rod soon I will take a pic of the inside.
But heres a not so good pic of the liner.
TBR is offline
Old 06-02-2003, 05:33 PM
  #4597
Default Wheels rubbing
Should I be sanding some material off of my front and rear uprights? I'm seeing some rubbing on the insides of my wheels. I'm using the Mugen Fast Foams with the correct offset and still seeing rubbing. My only fear in just doing it is will I be weakening the part or should I just sand away?? Any input is much appreciated!!!
KEVIN
hicheef is offline
Old 06-02-2003, 05:45 PM
  #4598
EVOLUTION's Avatar
You need to focus brother.
Did you get the engine in Australia or OS,and also do you know who is the aussie importer of sirio engines?
Old 06-02-2003, 05:46 PM
  #4599
PMT
Attached is the Over Drive Ratio Chart for the 16/19 ratio. To mantify it just round to the nearest whole number basicly 1. Not sure how much help it will be for you then as the whole chart will be 1's but at least you won't get bashed if you talk about it on the thread
PMT is offline
Old 06-02-2003, 05:51 PM
  #4600
TBR
TBR's Avatar
Got it overseas
TBR is offline
Old 06-02-2003, 06:24 PM
  #4601
stefan's Avatar
Default Overdrive
PMT, now you made me curious with your chart.
I was under the impression that if you run same tire size with stock pulleys that you'd have no over/underdrive.
According to your chart, a 60 mm front and 63.5 mm rear tire give you 1.000, which I supposed is neutral.
That means the car has underdrive built into it to start with, correct?
How does the handling change in theory when you go above or below 1.000.
I've asked numerous people about these ratios, but nobody ever could give me an explanation that made sense, or it was totally contrdicting what another person told me before
So, help me out here and pleaqse make it plain and simple
stefan is offline
Old 06-02-2003, 07:16 PM
  #4602
Manticore's Avatar
Originally posted by TSR6
PMT - I for one am glad to have you on here.
Manticore and PMT - I hope you two learn to either get along, or ignore each other, for the sake of this thread.
There is another solution, but I hope it it can be resolved other ways..
-Troy
this guy has been doing strange thing here.
here is the link of the max power engine 3.5cc and it provides all the bigger pictures that our new guy PMT just posted.
He really needs some help or he is just being strange.
http://www.rcmaxpower.com/
Manticore is offline
Old 06-02-2003, 07:19 PM
  #4603
Manticore's Avatar
I have posted 2 overdrive ration charts below to illustrate the differences & reasoning behind calculating things down to 3 places behind the decimal point (.001). The second is rounded for my special friend
I know you love to play games.
TSR6, I am not sure if you like people play game here or not?
Old 06-02-2003, 07:43 PM
  #4604
RClover's Avatar
The problem is not going to disapear by it's self unless you leave or change your attitude. Unfortunately this thread is not your own private domain that you are king of. Arrogance gets you no where and unlike others in the past Manti, I'm not going to be chased away by you. I'm honestly quite suprised that people seem to bow down to you. However I think that I understand why, looks like you provide cheap parts from HK for them.
RClover thanks for starting the new thread. Please fee free to use it.
no problem!
who is arrogant here? who brought up the 'big' events in his last post?
well, perhaps you hate 'alum. parts' (all snakers behave like this)so you feel a little uncomfortable about cheap parts from HK.. i can understand that, but that's not your business! we can affort and its our money!
RClover is offline
Old 06-02-2003, 07:59 PM
  #4605
stefan's Avatar
Would you guys please stop arguing now and answer my damn question which I posted 3 times already
Stop it or you'll have a German yell at you both!!!!
stefan is offline
