Mugen MTX-3
Old 05-27-2003, 06:01 PM
  #4276
stefan's Avatar
NO, NOT SHORT TERM.
I had a RB X12 5 port loose it's compression very early in it's life and I sent the p/s to OS Rocket for resizing.
After a very short re- brak- in the engine ran strong as a bull for 2 full racing seasons.
Since that time I'm a religiuos customer of OS Rocket and every engine he did for me ran better and longer afterwards.
stefan is offline
Old 05-27-2003, 06:02 PM
  #4277
Manticore's Avatar
Originally posted by Ah10
Here is your answer!
Check THIS out, Kawahara Delin rear lower arms. They are very strong, I had it on my mtx2 when I had the car, and it last forever!
i had this arm on my MTX2 and they works great. it also removed the slop if you use the stock arms.
Manticore is offline
Old 05-27-2003, 06:05 PM
  #4278
Manticore's Avatar
Default Re: Receiver batt. connection
Originally posted by click, dublin
Hi Guys,
Has anybody got a bullet-proof solution for connecting the receiver batt. to the receiver.
I stopped using switches years ago as I always had problems with them. They all seam to be quite cheaply made.
I use a batt. extension lead from the receiver & connect this into the batt. when I need to.
But I've found this can also have problems, especially in the wet.
So . . . Any solutions? I've thought of using a high quality micro switch from an electronics supplier?
All the best
get one which is dust/water proof. micro switch is prone to malfunction with dirts.
Old 05-27-2003, 06:09 PM
  #4279
RCTech Member #2
TSR6's Avatar
Originally posted by rcfiend
Hey guys I have been away from gas for a little while, playing with the electric stuff. Time to break out the MTX-3, don't know what came over me. Couple of questions.
1. What diff oil are you guys using in your rear diffs w/one-way installed?
2. When do you know to increase or decrease the thickness of the diff oil?
3. The directions are some what vague, but how do the different blocks for the front and rear impact the cars handling?
The different blocks change the roll center. A is low roll center, B is mid, and C is high roll center.
Raising the roll center will add traction, and some chassis roll to the car. Lowing the roll center will take away chassis roll, and remove some traction.
TSR6 is offline
  #4280
kevink2's Avatar
Originally posted by stefan
NO, NOT SHORT TERM.
Good for you then. That's one. Anyone else?
kevink2 is offline
Old 05-27-2003, 06:10 PM
  #4281
kilokhan's Avatar
If you intend to spend a little bit of money Get KO switch.. works like charm... got a batt indicator too
MANTICORE u got my message ?
kilokhan is offline
Old 05-27-2003, 06:13 PM
  #4282
Manticore's Avatar
yes i did, i am reading it now
Old 05-27-2003, 06:20 PM
  #4283
Manticore's Avatar
check your PM !!
Old 05-27-2003, 06:46 PM
  #4284
ilaybrk's Avatar
stefan can you give me his web page would like to send him this s3 thanks
ilaybrk is offline
Old 05-27-2003, 06:49 PM
  #4285
RClover's Avatar
Originally posted by Manticore
rear shock tower a revised version. much stronger then the first version.
where's the first version manti?
RClover is offline
Old 05-27-2003, 07:05 PM
  #4286
Manticore's Avatar
i dunno, but the first time i saw that thing was weak and the one i;ve got is more beefed.
Old 05-27-2003, 08:25 PM
  #4287
RClover's Avatar
u got it from Mr Lam yesterday? i am gonna miss this lovely tower b'cos he could have sent my parcel away today already... well, till my next order in few months time...
RClover is offline
Old 05-27-2003, 08:40 PM
  #4288
Manticore's Avatar
we guys are making snakers and Ass o car owners envy on us getting so many, inexpensive, effective hop ups for our cars.
Old 05-27-2003, 08:51 PM
  #4289
RClover's Avatar
true...true...veri veri true..!!! but..but, some Ass o will say 'if you add up all the hop-ups, that will cost more than Ass o car and anyway the Ass o car is already strong like a tank...blah..blah..blah'
RClover is offline
Old 05-27-2003, 11:56 PM
  #4290
Corse-R's Avatar
Use the same but with the old Multiplex connectors, are much better to do battery connections on greasy/messy cars.
Corse-R is offline
