Old 05-26-2003, 01:05 PM   #4186
Send a message via ICQ to Cartman
Originally posted by kevink2
More shims seems to yield more forward bite. Less seems to let the rear end follow the front on power.
RCLover, not sure if they'd work together, it might cause the hinge pins to bind. However in theory that would adjust your rear anti-squat, which should change the rear traction characteristics quite a bit. Used much more in offroad.
how u mean more forward bite?
i have chopped 5mm of mine so there the same hight as the mtx2 hubs (rubber tyres)
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 05-26-2003, 01:18 PM   #4187
kevink2's Avatar
More shims seems to make the car straighten up out of turns sooner on the gas. Less seems to allow the car to drive rounder circles, less pushy. Maybe forward bite isn't the right term, maybe more bite overall, but I notice the diff. most when on throttle.
kevink2 is offline   Reply With Quote
Old 05-26-2003, 01:20 PM   #4188
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Originally posted by thebutcher
Try it again.
Got another PM for ya.....regarding Mr Fox too....
BOLISARIO is offline   Reply With Quote
Old 05-26-2003, 03:18 PM   #4189
0 offset 30mm rear tires will rub the rear upright unless you put some sort of spacer in there
order the 2 degree offset if you can it just makes it easier
jason102276 is offline   Reply With Quote
Old 05-26-2003, 05:47 PM   #4190
FREAKAH's Avatar
Default ROSSI PIXY
Anybody runing this engine in their MTX-3?
I have heard this engine is a bit bigger/longer than the Novarossi engines and was concerned if it would fit in the MTX-3 without any problems with clearances?
Also heard this engine is a bit heavier. Will this upset the low CG and handling charactristics of the MTX-3?
Thanks in advance!
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 05-26-2003, 05:57 PM   #4191
TBR
TBR's Avatar
Default Re: ROSSI PIXY
Thanks in advance!
Hi a guy at our local track had a Rossi Pixy in their Yok GT4 and then got themselves a MTX-3 and found that it didnt fit because of the different crankcase shape. So to my knowledge no it doesnt fit.
TBR is offline   Reply With Quote
Old 05-26-2003, 05:58 PM   #4192
patelladragger's Avatar
Send a message via AIM to patelladragger
the engine is a bit heavier than say a sirio or mr12 but it fits in with no problems on mtx3 and you'd have to be a serious professional to detect any negative delta on handling caused by CG. At least I couldn't detect any. Great engine.
patelladragger is offline   Reply With Quote
Old 05-26-2003, 06:00 PM   #4193
TBR
TBR's Avatar
Default Re: Re: MTX-3 Options.
Originally posted by RClover
items to go are:
1. Center block - Sato Seiki
2. Radio Plate Support - Sato Seiki
3. Brake bracket - Sato Seiki
4. Rear Adj Sway Bar - Kawahara
other than that of the above, the rest are not really necessary.
Does that centre block fron Sato Seiki fit on 4mm Mugen Chassis? I remeber some disscussion about it a few pages back I beleive that the RD Logics one doesnt fit without some modification but does the Sato Seili one fit? Whats the weight difference from the orginal plastic parts?
Old 05-26-2003, 06:59 PM   #4194
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: MTX-3 Options.
i am using the sato one and yes you need to trim the bottom part so that it may fit on the recess part.
Manticore is offline   Reply With Quote
Old 05-26-2003, 07:06 PM   #4195
ilaybrk's Avatar
I have a pixi in my mtx3 no problem
ilaybrk is offline   Reply With Quote
Old 05-26-2003, 07:08 PM   #4196
RClover's Avatar
The center belt block doesnt have any problem.
Its the radio plate support from Sato Seiki that required some slight filing around its 2 legs which go into the 4mm Mugen chassis. It took me less than 1 min to get it done, dont worry its simple!
They weight almost as light as the stock plastics.
RClover is offline   Reply With Quote
Old 05-26-2003, 07:41 PM   #4197
RClover's Avatar
Does anyone know which port cap goes to the Carb and which goes to the exhaust stinger?
and what use is the Large port cap for?
Mugen B0424 - Medium & Large
Mugen B0423 - Small & Medium
Old 05-26-2003, 08:09 PM   #4198
Manticore's Avatar
this is for big block 3.5cc and 2.5cc engines
you can only use the exhaust port cap and the stinger cap on 2.11 cc
Old 05-26-2003, 08:15 PM   #4199
RClover's Avatar
So Mugen B0423 - Small & Medium caps works on the Carb and stinger?
Old 05-26-2003, 08:29 PM   #4200
Manticore's Avatar
i forget, i used to have B0423. i think they fit on both carb and exhaust port and also stinger but depends on stinger size
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
