Old 05-23-2003, 08:06 PM   #4141
RClover's Avatar
Originally posted by tekrsq
I primarily use my overnight wall charger (designed for nimh cells) that charges at 150ma. I find my packs last longer like this. If I have to peak at the track, I use my Integy 16x9 at 1.2 amps & 20mV threshold (I forget who told me to use this setting). My Orion 1100mah nimh packs are fine and give me over a full weekends racing (without re-peaking). I realize they have almost 400 ma more than my 730, but I'm getting more than 3 times more run time. It just doesn't add up to me.
overnight charger tend to overcharge the pack and this will shorten the lifespan. I dont use the overnight charger anymore after my 1100mah pack lasted me for only 5 months where the run time reduce tremendously.
These small cells batt are best charged at automode and let the charger to detect its capacity without overfeeding them.
Sometimes, it could be the bad cells in the pack or faulty connection between cells when manufactured.
RClover is offline   Reply With Quote
Old 05-23-2003, 08:47 PM   #4142
RClover's Avatar
Default Re: black fuel deposit
Originally posted by kevink2
Had better luck running the Mugen (Byron) fuel in regards to fuel deposits. Ran my J-Tec at 280 for a 40 min. main, and it's clean. It leaves a nastier residue on the pipe though than O'Donnell. I also had to lean the motor a bit more with the Mugen compared to O'Donnell. Little less hp but runs cleaner, me thinks.
agree...
had my motor leaner during the race, no more black deposits.
motor no sign of overheating, idle good and lots of power..
Old 05-23-2003, 08:49 PM   #4143
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by RClover
Manti,
if i tell you that i can get around 100-120min of run time from my Speedmind 750mah Nimh pack, would you believe?
But i am using Sanwa VR & VB servos, with on-board Stealth battery checker & KO failsafe.
i charge the pack at 1amp in auto mode with my Schulze Electronik charger 330-d.
it that continous ?
Manticore is offline   Reply With Quote
Old 05-23-2003, 08:54 PM   #4144
RClover's Avatar
Originally posted by Manticore
it that continous ?
yes.
Old 05-23-2003, 09:15 PM   #4145
Advanti's Avatar
Default what motor ?
any suggestions what motor would be good for my MTX-3?
Advanti is offline   Reply With Quote
Old 05-23-2003, 09:28 PM   #4146
RClover's Avatar
Rody Tuned 5 port or JP S5 are good.
Old 05-23-2003, 09:32 PM   #4147
Manticore's Avatar
Default Re: what motor ?
any .12 motor will fit as long as the shaft is SG type. I think you should ask yourself how much power you need and you can handle it.
Old 05-24-2003, 03:36 AM   #4148
Originally posted by thebutcher
I reconfigured the brick pack. I took one off the side and puto it on top. (if that makes any sense) This way it will fit without pushing the tank to one side.
Butcher, you got a pic?
tekrsq is offline   Reply With Quote
Old 05-24-2003, 08:11 AM   #4149
RayJ's Avatar
Default MTX-3 Options.
Outside of the engine brace and the front sway bar mount what other options are really worthwhile? I've been racing the car for about two weeks and have it really dialed in. Outside of replacing some of the plastic parts once in awhile(plastic is cheap).....what other expensive aluminum parts will really make any difference?
RayJ is offline   Reply With Quote
Old 05-24-2003, 10:21 AM   #4150
RClover's Avatar
Default Re: MTX-3 Options.
items to go are:
1. Center block - Sato Seiki
2. Radio Plate Support - Sato Seiki
3. Brake bracket - Sato Seiki
4. Rear Adj Sway Bar - Kawahara
other than that of the above, the rest are not really necessary.
Old 05-24-2003, 10:24 AM   #4151
RClover's Avatar
oopps, forgot to mention that Sato Seiki is not expensive but with high craftmanship.
Old 05-24-2003, 10:34 AM   #4152
Manticore's Avatar
Default Re: Re: MTX-3 Options.
items to go are:
the kawahara rear sway bar set is a MUST for every serious MTX3 racer !!!!!
Old 05-24-2003, 01:31 PM   #4153
Moderator
Jpilone's Avatar
Send a message via AIM to Jpilone
Default J-tech
Very nicely. It was pre run before I sent it in, so it's not radically modified- mostly crank work, etc. Runs like a clock, easy to tune, and smooth as butter. Looks like it was worth the wait. He also did a TOP TT-12 for me that I'm going to save for the Nats.
The Murnan I have runs strong, but it's a little trickier to get the needles set right. It's much more radically modded, and maybe the bored out carb is making it more sensitive. Need to work with it a bit more.
Kevin,
It's nice to see people talk about J-tech. Jason is a good friend of mine. I run his fuel, he does my engines, and I have nothing but good thing to say about him and his products/services.
Jason also has a MTX-3 that he tinkers with.. if he gives you advice, take it.. the man knows what he is doing.
Jpilone is offline   Reply With Quote
Old 05-24-2003, 01:51 PM   #4154
kevink2's Avatar
Default Re: J-tech
Originally posted by Jpilone
Kevin,
Yeah, he's really nice to talk to and very helpful.
kevink2 is offline   Reply With Quote
Old 05-24-2003, 08:04 PM   #4155
dg8one's Avatar
mid shaft
anybody thouht about the serpent hollow mid shaft is this fit our car(mtx3)
thanks
nelly
dg8one is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
