Old 05-18-2003, 01:17 PM   #3946
Corse-R's Avatar
Default Re: MTX-3 & Wet weather
Originally posted by click, dublin
Then my two speed started to act up going down the straight it sounded like it was attempting to go into 2nd then drop out then back in, out, in etc.
I did manage to keep ahead of a 2003 SMP Slide for about 4 laps . . . he was on foams & I was using wet weather rubber!!
Any ideas on the two speed?
Much probably was water in the 2nd gear clutch. There's not much you can do with this, probably will hold a little better if you do some light cuts to the shoes like a wet tyre, but you can ruin the shoes.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-18-2003, 06:12 PM   #3947
NTC3NUT's Avatar
Hi guys, I have a friend who is also a fellow racer, and he has very little internet access. He runs a MTX-3, and is looking for a good rear sway bar. Could one of you direct me to a supplier, or source for the Kawahara unit? I'll get ahold of one for him. Thanks in advance.
NTC3NUT is offline   Reply With Quote
Old 05-18-2003, 06:44 PM   #3948
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: help manticore
Originally posted by rcdubs
hi manticore can you tell me what's the kawahara 0.8 mm spur gear combo sot suippose to do i saw it on their website but have no idea what does it do?also is it worth getting?
thanks
i dont see any advantage of using such kind of gears.
Manticore is offline   Reply With Quote
Old 05-18-2003, 06:47 PM   #3949
Manticore's Avatar
Hi Guys,
Had a bad day today at the first round of the MMAI national championship.
It rained VERY heavy throughout the day, the rain was hopping off the ground about 2 feet!
We ran our cars in between the showers.
First I lost a throttle servo, then I had a problem with radio glitches, water in the receiver!
All the best
check your 2 speed shoes adaptor nut. there must have some "Dead spot" on the flat surfact so that the steel ball cannot move freely. this happened to my 2speed last week. take a look at it.
Old 05-18-2003, 06:49 PM   #3950
Manticore's Avatar
Originally posted by ilaybrk
does the 3 racing have a web site. and from what I can see the three racing chassi does not raise cg but steals 1mm of ride height. Since the extra mm is below the hinge pins I dont se how that raises cg. If I am wrong please explain. jack H
think of the ride high, if there is not any recess area there, the parts that above the 4mm chassis will be raised by 1mm.
Old 05-18-2003, 06:49 PM   #3951
Manticore's Avatar
and the suspension geometry will also be changed.
Old 05-18-2003, 06:54 PM   #3952
Everyone give manti a round of applause!!! He has hit 6000 post!
Something i could only dream of aspiring too!
Congrats!
oh and also, maybe if you had answered each persons question in 1 post rather than 5, ud still be at 218 post!!
Nytrochaos is offline   Reply With Quote
Old 05-18-2003, 07:00 PM   #3953
Manticore's Avatar
Congrats!
your dream should be more then that ! it is not that something i am proud of !
Old 05-18-2003, 07:11 PM   #3954
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Delrin Front Upper Suspension Arms
While being at the toy show, I ran into this great products by Nanteco System Engineers, Kanagawa, Japan. If you have been in the forum for quite some time, you may recall I once posted the black and white picture of it. Here's the real ones.
eddiethefish is offline   Reply With Quote
Old 05-18-2003, 07:13 PM   #3955
Default Close Up View
Here's another closer look at it. Notice that the 4 metal sealed ball bearings come preassembled.
Old 05-18-2003, 07:22 PM   #3956
puma1824's Avatar
Send a message via AIM to puma1824
Default Re: Close Up View
I guess that's for the MTX3...how much? Only available overseas?
-Puma
puma1824 is offline   Reply With Quote
Old 05-18-2003, 07:23 PM   #3957
ilaybrk's Avatar
what is the graphite part and when and were will be avalible
ilaybrk is offline   Reply With Quote
Old 05-18-2003, 07:24 PM   #3958
they look great!, how much will they really reduce friction though, i already have that hingepin assembly lubed with Harken Team McLube, (its for sailing gear but works wonders on anything and everything) and if it is a vital piece, why arnt we seeing them built by the top companies right now, and why arnt they out for other cars that have been out a while?
either way, im sure it will somehow find its way onto my car!
Old 05-18-2003, 07:28 PM   #3959
Send a message via Skype™ to JordanC
Originally posted by RClover
The black diposites on the alumminum piston usualy means trouble with heat above 250 F'.
For me that is 50 F' hot and I get all the power in 200 that others get at 250. so you probubly need to tune properly or add fuel to the mixture.
Got this off from another forum, is this guy telling correctly?
I have those dark brown deposit on the piston head while my pipe still spitting fuel from stinger, and the car not very fast.
Is that caused by too lean..?
It could actually be the other way around. If you run too rich (4 stroking) the motor will run too hot. If this is the case the top of the piston will look a dark brown colour like it is burnt. I any case, it sounds like you need a tune. Set the motor back to factory and then bring it out another turn top and bottom. Creep up on your tune from there. It also sounds like you may be too lean on top, and too rich on bottom.
JordanC is offline   Reply With Quote
Old 05-18-2003, 07:49 PM   #3960
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Congrats!
Congrats Manticore.
Im thinking I may order the CV's.. I had a dogbone fall out while cleaning the car with an air compressor.. heh.. ''not good''
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
