Old 05-15-2003, 12:33 PM   #3916
kevink2's Avatar
Originally posted by Corse-R
Black deposits over the piston can be caused by several factors.
- Too much oil (castor oil) on your fuel.
- Too high compression chamber (run at low compression).
- Too much heat.
- Too many gallons trhu the piston (this shouldn't be your case).
I've also been told some fuels will leave more of those deposits than others. I think I've had more of that black stuff running O'Donnell (pure synthetic blend) than Byron fuel types (castor plus synthetics) for example. I usually try to run around 240 to 250. I'm in the process of experimenting with some Mugen fuel because of this very "problem" and will know more after this weekend.
kevink2 is offline   Reply With Quote
Old 05-15-2003, 12:58 PM   #3917
stefan's Avatar
Send a message via AIM to stefan
Default Kevin,
Mugen's fuel is from Byron..
stefan is offline   Reply With Quote
Old 05-15-2003, 06:56 PM   #3918
RClover's Avatar
Originally posted by FREAKAH
Try increasing rear droop a little to get the weight to the front while off power or braking.
after looking at this chart about Droop setting, i am getting confused the term increase and decrease of droop.
Increase Droop = 4,5,6 ??
Decrease Droop = 3,2,1 ??
(Number shown on the Hudy Droop Gauge)
have i got it the other way round?
RClover is offline   Reply With Quote
Old 05-15-2003, 07:52 PM   #3919
Manticore's Avatar
R/C Tech Charter Subscriber
seems like this chart is applying to buggy setting with soft suspension.
Manticore is offline   Reply With Quote
Old 05-16-2003, 01:07 AM   #3920
RClover's Avatar
i think this chart provided by popsracer somewhere in RCtech forum...
Old 05-16-2003, 01:26 AM   #3921
FREAKAH's Avatar
Scenario C. More droop meaning the rear of the car rises more during braking.
On my AE droop gauge, #1 has the most droop.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 05-16-2003, 03:51 PM   #3922
someone here posted a video showing mtx3 running on wet tracks. What exactly did u do to make the electronics waterproof? Im using jr XR3 rx and rx and ko 2173(steering) and futaba 9404(throttle).
btw FREAKAH thanks for the rubber setup. I appreciate it.
penggoy is offline   Reply With Quote
Old 05-16-2003, 08:08 PM   #3923
dg8one's Avatar
question guys
i was tring to set my front droop and find out that one of the set screw is not even touching anything but the other side is way screwed in but i measure them and the #mm is almost untill i start messing with this thing on the sway bar that you can rotate irotate that till the screws are even
what this thing do? and how you set this up
thanks
nelly
dg8one is offline   Reply With Quote
Old 05-16-2003, 09:07 PM   #3924
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
Default Finally....
Got this thing built and ready to run, I hope. It was harder,for me, to build this thing compared to the GT4 and NTC3. Lots of tight spaces and a whole bunch of screws.
By the way, did your kit come with a flywheel collet? I didn't find one in the kit or the instructions. I just used the collet that came with the MR12(bought it separately). It seems to fit right and the pinion/spur combo matches up well.
BOLISARIO is offline   Reply With Quote
Old 05-16-2003, 09:25 PM   #3925
Default yo bo !
so u went on and done it!
isuzuguy is offline   Reply With Quote
Old 05-16-2003, 09:29 PM   #3926
BOLISARIO's Avatar
Default Re: yo bo !
yup...hope when this thing fires up for the first time, it doesn't fall to pieces. Crossing my fingers that I built it right.
Old 05-17-2003, 02:43 AM   #3927
Corse-R's Avatar
Originally posted by dg8one
question guys
1. Disconnect the roll bar removing one metallic part and adjust the droop.
2. Seeing the front side of the car at the right hand you should have an eccentric to adjust some kind of uneveness on the roll bar, withe the metal part you removed installed another time, adjust those eccentric to get the all two sides go up and down at the same time and with the same height (droop).
BTW: All this should be done with the shocks removed from the car to avoid any parasitic action of shocks in the suspension scheme.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-17-2003, 04:00 PM   #3928
Default to the hop up kings
i have a question what's this suppose to do and is it worth getting????
rcdubs is offline   Reply With Quote
Old 05-17-2003, 04:02 PM   #3929
could u give us a little more description? theres like 5things on that page...what is the hopup called?
Nytrochaos is offline   Reply With Quote
Old 05-17-2003, 04:02 PM   #3930
is the 0.8mm spur gear set what's it for?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
