Mugen MTX-3
Old 05-13-2003, 07:25 AM
  #3841
RClover's Avatar
Originally posted by FREAKAH
Here's the parts you need for a front diff:
C0228 Diff Gears
T0202 Diff Outdrives
C0227 Shim assortment
T0207 Diff Gasket
T0802 Roller Pin Set assortment
T0224 S5 O-Ring 10pcs.
My parking lot setup for rubbers on a blown tight track.
Kit setup plus the following changes:
FRONT
Diff w/10,000 oil
Grey front springs
0.5 deg. camber
REAR
Long rear camber link(inside hole)
2 Associated aluminum washers under rear camber link ball
5,000 rear diff oil
"C" roll center blocks
Red Associated TC3 springs
0.5 deg camber
Sorex 40R tires. Works great on 100-140 degree(F) track temps.
have you tried foam tyres on this set-up?
do you have a pic of your track?
RClover is offline
Old 05-13-2003, 07:27 AM
  #3842
did you see that car run? seems to me it would handle horribly
how can that possibly work he has the shock pistons backwards and the weight of the oil lighter on the 2 hole piston than on the 1 hole piston
how can you go from the stock setting to that
CRAZY
jason102276 is offline
Old 05-13-2003, 07:29 AM
  #3843
RClover's Avatar
Default Re: Re: unbelievable setting..
Originally posted by Corse-R
Is an Off-Road setup or a Rally Game setup?
this is the first time i went to this small parking lot track. its bumpy at certain area...those guys there all with similar ride height...but they are fast...
RClover is offline
Old 05-13-2003, 07:31 AM
  #3844
RClover's Avatar
CRAZY
that's the point...! its unbelievable...
RClover is offline
Old 05-13-2003, 07:35 AM
  #3845
Corse-R's Avatar
Default Re: Re: Re: unbelievable setting..
Whoa! next time you'll go probably need to use som Tamiya Rally Block tyres... (have some here if you want, can bring you a set )
Corse-R is offline
Old 05-13-2003, 07:37 AM
  #3846
RClover's Avatar
now it makes me think twice if i want to join the race this weekend at this track...i think my one-way wont be as fast...
RClover is offline
Old 05-13-2003, 07:45 AM
  #3847
Corse-R's Avatar
Save your car from a terrible pain caused by those bumpy surface. Needed to race on a bumpy track and is a pain in the a$$....
Corse-R is offline
Old 05-13-2003, 10:18 AM
  #3848
Manticore's Avatar
Default Re: unbelievable setting..
met up with the guy that i mentioned the other day who was on Full Diff with foam tyres.
Here's what he told me:
Front:
Diff with 7000 oil
Kyosho Green Spring
Shock oil 350
Ride height 9mm
Piston 2 holes
Anti Roll Bar Flat
Droop 1mm
Camber 1 deg
Toe 1 deg
Ankerman A
Rear:
Diff with 1000 oil
Kyosho Orange spring
Shock oil 700
Ride Height 13mm
Piston 1 hole
Stock sway bar
Droop 2mm
Camber 4 deg
Toe 2 deg
Rear Block combo - AB
can you believe this set-up?
funny thing does happen in your country !!
Manticore is offline
Old 05-13-2003, 10:25 AM
  #3849
Manticore's Avatar
Old 05-13-2003, 10:45 AM
  #3850
Corse-R's Avatar
just wondering if there's any way that we can check tweaked chassis without using the tweaked station...??
Best and cheapest tweak station for chassis: A piece of glass or a broken mirror, just cut straight and polish the edges to not be hurted when using it.
Corse-R is offline
Old 05-13-2003, 11:01 AM
  #3851
FREAKAH's Avatar
I haven't tried foams on this setup but I was competetive in the Mod/foam class against the oneway equipped cars .
I will be running my brand new 2nd MTX-3 in Mod this coming Sunday. The starting setup will be stock but with stiffer springs front and rear plus a front diff.
Sorry, I dont have a pic of our track but some sat it looks like a medium size parking lot electric track.
FREAKAH is offline
Old 05-13-2003, 02:43 PM
  #3852
dg8one's Avatar
thanks guys i'll try that this weekend
jack (ilaybrk) do do you have an extra non turbo buttonhead
(theirs a thick one and a thin version of that button i need the thick one)thanks jack
thanks
nelly
dg8one is offline
Old 05-13-2003, 03:08 PM
  #3853
ilaybrk's Avatar
no I only have the one a long stroke the thin one sory nelly
ilaybrk is offline
Old 05-13-2003, 05:11 PM
  #3854
JJ187RC's Avatar
I have got a quick question.
On my car, the rear wheels are wiggling. I have checked the uprights and they are not loose so it is not there. It seems that the axle that goes through the bearings is where I am getting the play. Any suggestions on how to solve this? The only thing I have not done is replace the bearings, but I did swap the fromts to the rear and it did the same thing. I even put a set of universals in the rear and that did not help either. This is with the plastic hex adapters or the aluminum ones I got from Rdlogics.
JJ187RC is offline
Old 05-13-2003, 06:54 PM
  #3855
Manticore's Avatar
Default kawahara (not harmony) rear sway bar again per Corse-r's request.
here
