Old 05-11-2003, 01:20 PM   #3781
Corse-R's Avatar
Default Re: Spring Rates
Originally posted by hicheef
Sorry about the consecutive posts but sometimes you post and then remember something you want to post. Does snyone know where I can find the Color and spring rate chart for Mugen spring set? As well will the springs for the MTX-2 fit the MTX-3?? Thanks for yor help!!!!!
From softest to hardest:
- Purple.
- Blue (Stock on MTX3).
- Gray.
- White (Stock on MRX3).
- Pink (only rear).
- Red (only rear???? seemed to see a red spring set).
If plan to buy some springs found on the MTX3 works quite well with Blue and Gray, whites are probably too stiff and only suit on quite particular track conditions. Purple are too soft for normal conditions (have a set, but probably only work on wet, dusty tracks or the ones who uses rubbers use them. On foam aren't normally used).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-11-2003, 01:23 PM   #3782
Corse-R's Avatar
Originally posted by Nytrochaos
Whats the word on the mugen fast tires? can i take their shore ratings to the bank?
Mugen Fast are the same type of foam as Ellegis with the same disparity on shore ratings (quite close but not exact, probably be +/-2 shore degrees between batches).
Cheers,
Corse-R
Old 05-11-2003, 03:09 PM   #3783
theRED5's Avatar
R/C Tech Charter Subscriber
I tried, but can't seem to get thru the 1st 100 pages...
What's the deal on the front dogbones? What;s the best fix, is everyone using the MTx2's or CVD's?
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 05-11-2003, 03:18 PM   #3784
im using mtx-2 dogs, but u can take a length of fuel tubing and put it in each of the out drives on the one way or diff
Nytrochaos is offline   Reply With Quote
Old 05-11-2003, 03:42 PM   #3785
FREAKAH's Avatar
I think that using the "A" ackerman plus a loose servo-saver setting allows the inside tire to turn too much allowing th bone to fall out. This seems to happen only whene you hit something or land off a corner dot.
I tried using O-rings and fuel line but the best seemed to be a pen spring cut to length.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 05-11-2003, 04:09 PM   #3786
tomdav's Avatar
Trader Rating: 42 (100%+)
Default Lola body's
Our club is going to try and have a few Lola body races to break things up. We will no doubt use a yokomo and wonder if there are lower shock mounts for the mtx3 to make it work. The Yok truck would have worked w/ no mods but not everyone agrees with the looks of it even though on our tight track it will no doubt work great.
Tom
tomdav is offline   Reply With Quote
Old 05-11-2003, 06:02 PM   #3787
Wow, the spring in the outdrives sounds like a cool trick, ill have to try that!
speaking of springs, has anyone tried springs on the 2 brake pins? i need to take my whole rear assembly apart for cleaning and diff maintnance before the season starts up, i may try it when i put it back together
Old 05-11-2003, 08:09 PM   #3788
i am using the axle from a mtx3 outdrive with a mtx2 universal bone attached
i had problems breaking the mtx3 universals
i am using a spring on the negative side of the brake linkage when the throttle is opened the linkage pushes against the spring and opens the brake as far as possible for no drag
the mtx3 has a stopper on the brake lever so it only engages breaks one way the mtx2 ddint and if you pushed the lever back it would engage the brakes but mtx3 is better
jason102276 is offline   Reply With Quote
Old 05-11-2003, 08:19 PM   #3789
jason, thats the break trick i was referring to with the springs, can you notice it actually working, or is just kina all show and no go......not that the springs look all that cool
Old 05-11-2003, 08:25 PM   #3790
it works really well
my brakes used to drag on the mtx2 so i figured since i could do this on this car i would
dont want brakes dragging while running a one way so evry extra percaution is worth it especially when its almost free and so easy to do
Old 05-11-2003, 10:18 PM   #3791
Send a message via AIM to Bryan N.
any pictures of what your talking about?
Bryan N. is offline   Reply With Quote
Old 05-12-2003, 12:35 AM   #3792
RClover's Avatar
Originally posted by ME-student
yup, there are also a few Rody 5port owners in this forum. I am sure they will agree...
2 words -- No regret!!
RClover is offline   Reply With Quote
Old 05-12-2003, 12:44 AM   #3793
RClover's Avatar
Originally posted by Manticore
ran the kawahara rear sway bar today. The only word that I want to say "AWESOME"
what's your setting ? Soft/ Medium/ Hard?
Are you on stock setup? what chages on the set-up? How about Tyres? I am going into a race this Sunday..Medium grip asphalt track with technical infield...
Old 05-12-2003, 02:16 AM   #3794
Send a message via Yahoo to speedy100
Default Sirio 5 port AAC
Hi, anyone who has the experience with the sirio 5 port AAC ? there are many conficting opinion in the market of this motor...any insight you have ? thxs
speedy100 is offline   Reply With Quote
Old 05-12-2003, 03:05 AM   #3795
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally posted by chookgb
my transponder and switch to show there is plenty of choices
Since we are one the subject and I haven't been here in ages....
Square Transponder mount
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
