Old 05-07-2003, 05:53 PM   #3706
kevink2's Avatar
Default Re: Re: Re: tires
Originally posted by Taylor-Racing
We use "Active" tyres as do approx 50% of the local guys, though quite a number run ZAC's. Their performance seem very similar, though I prefer the stiffer rim on the Active's.
I understand both Active and ZAC use the same Japanese rubber.
We've found that tyre wear is about 30% better than GRP rubber and would expect the ZAC's to be similar.
The shore ratings seem to work a bit differently and we usually run the same shore front and rear, say 40 / 40 on a track with decent traction. Wear from F/R is quite consistant, using a one-way and rear diff. This is on a V-One-R.
Hope this is of some help.
Loved the ZAC foams on my V-One R, but not the rim construction. I haven't used them in a while, so they may be better now, but not sure.
kevink2 is offline   Reply With Quote
Old 05-07-2003, 08:23 PM   #3707
Default diff screws
hey guys.. I've been trying to find the 2.6x6 flat head screws for the front diff... that's all i need to complete the setup. I have some 2.6x8 phillips head screw (not flat). would they work? can i use a 3mm instead? what's your input?
TIA
Sike is offline   Reply With Quote
Old 05-07-2003, 11:27 PM   #3708
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: diff screws
TIA
use 3mm screws !
Manticore is offline   Reply With Quote
Old 05-08-2003, 12:43 AM   #3709
FREAKAH's Avatar
Default Re: Brake
Originally posted by Cartman
i run rubber tyres with the black brake shoes and i have trouble getting a progressive brake seems i get brakes all of a sudden.
will the yellow ones cure it??? and why?
I put in the yellw Teflon pads while I was building the kit. The stock pads were too "grabby" in my MTX-2 so I learned from that.
The track I run on requires a lot of braking so the yellow pads smooth and progressive action help prevent brake spinouts.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 05-08-2003, 03:46 AM   #3710
chookgb's Avatar
Trader Rating: 26 (100%+)
Default Re: Brake
i have recently installed the mugen one piece disk part no-HO369 as well as the yellow pads and the brake is smooth and does not grab and the brake drag problem is not there i would say a must have item if you want useable brakes
chookgb is online now   Reply With Quote
Old 05-08-2003, 03:52 AM   #3711
chookgb's Avatar
here is a pic of the disk off the mugen site it is the hop up for the mrx-3
Old 05-08-2003, 07:43 AM   #3712
Manticore's Avatar
i have the enneti disk (thanks to corse-r) and i have seen the mrx disk. I think the enneti is far more superior (one piece) and it is a bit lighter.
Old 05-08-2003, 07:58 AM   #3713
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I finished the MTX-3 the other night. The only thing i have left to set is droop. I'll start break-in tonight.
I was very impressed with the way the car went together. I'm just worried that I didn't sand down the brakes pads enough, so I may take them out tonight and take a little more off of them.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-08-2003, 08:14 AM   #3714
Manticore's Avatar
wow, you put it together fast !
use the teflon pad and you dont need to sand down anything.
Old 05-08-2003, 08:17 AM   #3715
RCTech Member #2
TSR6's Avatar
I actually had it together tuesday night, for the most part. Last night was just finishing cleaning up the wire-routing, fuel tubing, mount the pipe, toss it on the hudy board and little stuff like that.
teflon pad? The black brake pads it came with?, or is this an optional part?
Troy
RCTech Member #2
Old 05-08-2003, 08:19 AM   #3716
Manticore's Avatar
teflon pad is optional and it is orange color. the box stock pad is black color and it is a bit thicker
Old 05-08-2003, 08:23 AM   #3717
Corse-R's Avatar
The teflon brake pads are an optional item. Are REAL interesting if you run with foams and one-way (makes the braking less criticalal) now seemed weird that Mugen didn't trowed a set of teflon pads on their MTX3 makes the braking more progressive and easier.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-08-2003, 08:52 AM   #3718
Teflon pad part number H0359
Pepe is offline   Reply With Quote
Old 05-08-2003, 08:59 AM   #3719
Manticore's Avatar
now you've become mugen expert !
Old 05-08-2003, 09:01 AM   #3720
DSR
Does the teflon brake pad, H0359 work with the MTX-3? SpeedtechRC has it listed as a MTX-2 part.
DSR is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
