Old 05-07-2003, 06:04 AM   #3691
Taylor-Racing's Avatar
Default Re: Re: tires
Originally posted by Corse-R
<SNIP>
I have a forthcoming race on a REAL abrassive surface and planned to use some ZAC project tyres to cope with the brutal rear tyre wear (manti told me some dirty tricks that I need to try). Anyone has enough feedback with those tyres (specially when is related to a even F/R tyre wear)?
We use "Active" tyres as do approx 50% of the local guys, though quite a number run ZAC's. Their performance seem very similar, though I prefer the stiffer rim on the Active's.
I understand both Active and ZAC use the same Japanese rubber.
We've found that tyre wear is about 30% better than GRP rubber and would expect the ZAC's to be similar.
The shore ratings seem to work a bit differently and we usually run the same shore front and rear, say 40 / 40 on a track with decent traction. Wear from F/R is quite consistant, using a one-way and rear diff. This is on a V-One-R.
Hope this is of some help.
Taylor-Racing is offline   Reply With Quote
Old 05-07-2003, 08:09 AM   #3692
pro spacers are part # CO227
i couldnt find anyhting on the kawahara wheel hexs
try asking manitcore he seems to be an expert when it comes to kawahara
jason102276 is offline   Reply With Quote
Old 05-07-2003, 09:34 AM   #3693
Manticore's Avatar
R/C Tech Charter Subscriber
hmm....
since when I've become an expert on kawahara
well...
at least it is much better an expert on GPM ! right? Fokie?
Manticore is offline   Reply With Quote
Old 05-07-2003, 10:48 AM   #3694
i don't think I am an expert in kawahara; however, I have the part #
Z-763
Pepe is offline   Reply With Quote
Old 05-07-2003, 11:25 AM   #3695
mcsquish's Avatar
Where is everyone getting the Kawahara blade rear swaybar, and is it stiff enough? I currently have the 3-racing which I have heard/read isn't stiff enough. I want the adjustability of a blade. Thanks
mcsquish is offline   Reply With Quote
Old 05-07-2003, 11:34 AM   #3696
Vinyard's Avatar
Default Front Diff
HAve you guys tried the front diff for the MTX-3 yet??
What are the parts required for building the front diff?
Some of guys at track are running the car with front diff and they complain that it leaks, what are the things i need to do to prevent it from leaking??
lastly, if i were to use say 10k diff oil in the rear, do i run a higher rating diff oil in the front or the same?
thanks
Vinyard is offline   Reply With Quote
Old 05-07-2003, 11:46 AM   #3697
Manticore's Avatar
the 3racing blade is just too long !
Old 05-07-2003, 12:03 PM   #3698
Send a message via Yahoo to hicheef
Default Re: timezone
Originally posted by tomdav
You mean saturday? What class are you racing?
Tom
I'll be the really slow rook who's having trouble keeping his engine fires
Kevin
hicheef is offline   Reply With Quote
Old 05-07-2003, 12:04 PM   #3699
Default Re: Re: timezone
Kevin
I mean FIRED. 1/10 novce sedan
Old 05-07-2003, 12:38 PM   #3700
JJ187RC's Avatar
Does kawahara have a web site?
JJ187RC is offline   Reply With Quote
Old 05-07-2003, 01:46 PM   #3701
http://www.rcimports.net/site/control/rc.htm
Kawahara's US importer
BossPlaya is offline   Reply With Quote
Old 05-07-2003, 02:11 PM   #3702
http://www.kawahara-racing.co.jp/
Old 05-07-2003, 02:39 PM   #3703
Send a message via ICQ to Cartman
Default Brake
i run rubber tyres with the black brake shoes and i have trouble getting a progressive brake seems i get brakes all of a sudden.
will the yellow ones cure it??? and why?
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 05-07-2003, 03:47 PM   #3704
Corse-R's Avatar
Default Re: Brake
Hehehe.... seems that you started to have some quite serious brakes...
This is the same problem that almost all of us faced previously. With the normal 'Ferodo' brakes, you have too much stopping power (friction coefficient) between the disk and the pads basically due to the density of the pad (don't stretches nor compresses). Teflon (Yellow pads) are more plastic and can adapt to the rotor surface and transform some of the power applied by the servo into brake pad deformation (plasticity of materials).
In few words, the plasticity and elasticity of the yellow brake pads gives you less stopping power and much more progresivity. Used almost from the start on the MTX3 because found the brakes very poor on progresivity.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 05-07-2003, 04:23 PM   #3705
puma1824's Avatar
Send a message via AIM to puma1824
Cartman
What's your rubber setup? How do you like it compared to the foams?
Thanks,
Puma
puma1824 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
