Mugen MTX-3
Old 05-05-2003, 08:58 AM
  #3661
Heres the "G" I missed!!
click, dublin is offline
Old 05-05-2003, 09:00 AM
  #3662
Corse-R's Avatar
Default Re: Brake Pins
Originally posted by click, dublin
I noticed one of my brake plates had come loose.
I stripped the rear end & found I was missing the two long pins the brake plates slide on!!!
This is caused by a faulty install of the pins when are inserted into the chassis or the bulkheads. You need to install them in one hammer whack (put some CA to the ones that go into the plastic bulkheads to secure them - beware with fingers and nails Mr. Murphy is ever ready to act ).
Corse-R is offline
  #3663
RCTech Member #2
TSR6's Avatar
You can click and edit it.
I'm still waiting on the brown santa..
TSR6 is offline
Old 05-05-2003, 09:24 AM
  #3664
mcsquish's Avatar
Thanks Corse-R I'll take all of the help I can get. I had some realy cool rolls. One was about 50 feet long with total flips, no slidding. I think the rear blade is from square, but I cannot remember. I will give your ideas a try. Thanks again My bad, it is a 3racing. I have a 2.5 bar on order, I think I am going to order a Kawahara also.
mcsquish is offline
Old 05-05-2003, 09:32 AM
  #3665
Corse-R's Avatar
Put the stiffer wire from Mugen (T143) and probably all your problems will be gone. Cheaper and still adjustable.
Corse-R is offline
Old 05-05-2003, 10:08 AM
  #3666
Default MTX-3 Tires
Whats UP All!!
Having a very tough time getting foams for this thing. All I know is the Fast tires wil definitely fit. Any other Manuf. making MTX-3 compatible foams?? I know offset of 2 for the rear, is that the only concern??? Searchrd the thread but haven't found the definitive answer. Any input is appreciated.
26mm front
30mm rear
Kevin
hicheef is offline
Old 05-05-2003, 10:13 AM
  #3667
Manticore's Avatar
Default Re: MTX-3 Tires
Originally posted by hicheef
Whats UP All!!
26mm front
30mm rear
Kevin
enneti tires
Manticore is offline
Old 05-05-2003, 01:32 PM
  #3668
hicheef did you get my pm about mr-12 settings?
about the foams 2 degree offset tires are nice they will make you life easy
but they are not totally necessary you can use the mugen pro spacer behind the wheel hex and use any 30mm rear and 26mm front
i believe kawahara also makes wheel hexs that add the 1mm needed to run any wheel
ellegi, enneti, nitro shoes, mugen fast tires, and probably a couple others i missed will fit
personally i run the mugen fast tires on the mtx3 wheels so i know i will never have a problem
i believe if your looking at tire descriptions and it says dtm mousse in the description that wheel has the necessary offset this applies to all tires made by GRP
jason102276 is offline
Old 05-05-2003, 02:29 PM
  #3669
Way to go Guys!! Thanks for the input!!!
Jason, no, didn't get the pm but i did mess around with the needles. Sent them all the way in counting the turns. Main went in two so I backed it out to the same, seemed right. The low though was only out about half to 3/4 turn so I'm gonna send that out another half and see if the temp comes down a bit. I'll let you know. If you do know though exactly what the Factory says they are sending them out set at I'd appreciate it!!!!
KEVIN
hicheef is offline
Old 05-05-2003, 05:51 PM
  #3670
Default rc magazines
hi guys i need your help im subscribing to a japanese magazine and need to know between rc magazine and rc world wich magazine is better???????
ps:i was told rc magazine has a lot of advertising,please help
rcdubs is offline
Old 05-05-2003, 08:43 PM
  #3671
NitroNut's Avatar
What's the part # for a mugen centax and that fits a v1r right witout mods i know this is only mtx3.
NitroNut is offline
Old 05-05-2003, 09:54 PM
  #3672
Manticore's Avatar
use the whole set of mugen clutch and you dont need to mod anything.
Old 05-06-2003, 12:09 AM
  #3673
Roger's Avatar
Default Re: rc magazines
Yeah, RC Magazine has alot of ads, but if you know how to read Japanese, then both magazines are good. Both magazines have great articles about set-ups, tuning, suspension dynamics, and racing. If you don't know how to read Japanese, then at least you'll have alot of pictures to look at. I know a picture can say a thousand words, but reading about a particular product ( if you know Japanese ), can be a never ending learning process because there is sooooo much information that the Japanese write about. The Japanese takes RC to another dimension. They are really serious about thier toys and racing. Thats why both magazines have soooo many articles. Especially if it is used by one of their Big name drivers. i.e. Hara, Adachi, Osaka, or Masami. Goodluck
Roger is offline
Old 05-06-2003, 06:33 AM
  #3674
hicheef those settings you described in your post are way way off
2 turns high and 3/4 low is way way too lean
i would start at least 3 turns out on low and 4 turns out on high
it is a much better idea to start too rich than too lean
i hope that you havent already done damage to that engine
my mr-12 also came at 3/4 out on low speed needle i dont know why i think ive gotten a mt-12 the same way ive found that is way too lean
luckily novarossi engines seem to be nearly indestructable
Old 05-06-2003, 10:53 AM
  #3675
tomdav's Avatar
Trader Rating: 42 (100%+)
Default tires
What shore tires come with the kit? Do nitro shoes work well?
Check out this track. Its huge and in his backyard.
http://www.timezoneracing.com
tomdav is offline
