Old 11-10-2002, 03:43 AM   #316
Im2lazy's Avatar
one q chookgb ... are referring to me when you've been saying ilaybrk?
No, your negative diff gives you normal differential action when your car is not running, yes? just like your old diff that you took out, yes? the thing is that when you are not accelerating, your car should have normal diff action like with your old diff. When you are accelerating your diff will lock up adn become like a solid axle setup.
Im2lazy is offline   Reply With Quote
Old 11-10-2002, 03:52 AM   #317
chookgb's Avatar
Trader Rating: 26 (100%+)
Cool
the dynamics of how the neg diff works is not the issue the issue of getting the car to hold a tight exit speed is, i have tested the diff at 2 tracks with the same result the car is fitted with a front one way and has good entry and exit speed but with the neg diff it runs wide on exit which is due to the locking of drive which can not be adjusted unfortunately,to back this up my lap times were .5 of a second quicker at both tracks with the same car set up and identical track conditions with the standard diff.
chookgb is offline   Reply With Quote
Old 11-10-2002, 04:02 AM   #318
I had the same problem (actually still do sometimes), but here's what I had to do. Set the front droop to 0, run the rear sway bar at 2mm, front sway bar flat. I run 35-40 shore on the rear (depending on track conditions), and 40 front. Basically, this will cause the rear to "whip around" a little when you apply power going through the center of the turn. Almost like driving a 1/8. The benefit (as compared to a solid rear) is that you can enter the corner better, then power slide the rear around, and shoot out of the corner.
tekrsq is offline   Reply With Quote
Old 11-10-2002, 04:10 AM   #319
chookgb's Avatar
Thumbs up
cool at last some productive support,have you found that with these changes the car now gives you quicker lap times than the standard diff
Old 11-10-2002, 04:12 AM   #320
Im2lazy's Avatar
my bad... My other idea was that it had to do with droop... I just got confused by some of your post.
I think that these diffs probably won't fit b/c there are supposed to be new bulkheads in the MTX3. I wish more things would carry over .
Old 11-10-2002, 05:01 AM   #321
NTC3NUT's Avatar
Stefan, Stefan,
Relax man, why all the hostility? You don't have a NTC3 anymore, so everything will be O.K..
Patelladragger,
The only thing not "out of the box" at the Worlds was the one-way, the ring & pinion gears, the dual chamber pipe, and the sway bars. You can pick everything up at your local hobbyshop other than the gears, which I expect to be out soon. If they did anything else to the car, it was by modding stock parts.
And just for the record (Stefan, are you listening?), I have never made the statement that the NTC3 was "the best". If you read back to the first few pages of this thread you'll see that I am just as excited about this new Mugen as the rest of you. I agreee 100% with anyone that says they are all equally awesome cars.
NTC3NUT is offline   Reply With Quote
Old 11-10-2002, 05:39 AM   #322
Im2lazy's Avatar
That wasn't hostility, that was bitterness . Certain cars work for some people, but sometimes it seems that the Nitro TC3 doesn't want to work for many of its drivers. I'll repeat that it has great potential, but there are too many things that have been plauging people to make it a truly viable car for some people right now.
And modded stock parts is not very "out of the box" b/c these guys have access to milling machines (course, many use dremels when their impatient )
Old 11-10-2002, 06:18 AM   #323
NTC3NUT's Avatar
Dremels where sent by God. You would have to pry my cold, dead hands form it.
Old 11-10-2002, 06:27 AM   #324
Anyways, NTC3 is a good car I'm sure, everyone and there mum has one, blah, blah... moving on.
So no impressions of the car yet? A couple of you have had 2 days with the car thus far, hurry up!!!
calimassive is offline   Reply With Quote
Old 11-10-2002, 07:15 AM   #325
Im2lazy's Avatar
Wink
I've seemed to have had a dream that never happened
Old 11-10-2002, 07:50 AM   #326
stefan's Avatar
Send a message via AIM to stefan
Default Negative Diff,
guys, you can adjust the locking action of the negative diff.
First, you can put the clutch shoes in trailing or leading.
Trailing =soft engagement, leading=harder engagement
Then you can also either lighten the shoes by drilling holes in them or put short set screws in the shoes to make them heavier.
I went with leading shoes with one 3mm setscrew, which really makes a huge difference. The diff feels much more like a solid axle much sooner in the corner and I like that.
stefan is offline   Reply With Quote
Old 11-10-2002, 07:58 AM   #327
well, not that ive been counting, but only 21 days till i get the car!!
it kinda sucks though, cause when i go home from boarding school, in 13 days, ill know that there is an mtx-3 somewhere in my house, and that alone will kill me!!!
secondly, even though ill spend all my time looking for it.......if i find it, theres nothing i can do!! i think it would look pretty bad on my part if on hannukah my present was already built!!
the stress is killinbg me!!!
also,once i get the car, there isnt a track within 100 miles of my boarding school, so itll be a basher until i go home for brakes so i can go to my local track
anyway, moreto the point, did anybody else see my paint scheme? what do you like,what dont you like, what colors would you change?
lastly, on the mugen site, it sais power pack 650 and 730 are the rx batteries to use, the problem is, i cant find them anywhere!! will other batteries work? if so which ones?
thebody im gonna use is the volvo s60.....theres just to many damn 300m's and stratus's!!
thanks
Nytrochaos is offline   Reply With Quote
Old 11-10-2002, 09:14 AM   #328
stefan's Avatar
You can use any AAA NiMh cell.
A good place to buy those is: http://www.onlybatterypacks.com
I got the 700 mAh in my MTX2 under the tank and the easely make a 30 min main.
Old 11-10-2002, 09:16 AM   #329
stefan's Avatar
Default Ooops,
wrong link,
for loose cells go :
http://www.onlybatteries.com
Old 11-10-2002, 09:43 AM   #330
i decided my colors were a little tame,and thought id go a little more exciting with it
hows this?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
