Mugen MTX-3
Old 04-22-2003, 01:09 AM
  #3061
Manticore's Avatar
Originally posted by penggoy
but I already put 60wt on my shocks instead of 48wt( 50wt). What can I do about it?
i have been using the same system ( (shock # / 10) - 5) long time and I have been mixing # and WT front and/or rear and couldnt have problem at all.
who is going to measure up to 48 or 46 wt? i am sure the quality control in not stable for most of the brands except asso.
try it out and see what you think about it. dont worry about the difference of 12wt if it really have such difference.
Manticore is offline
Old 04-22-2003, 01:10 AM
  #3062
Manticore's Avatar
Originally posted by Vinyard
pepe, u are using a K&N filter?
are the same as they use on cars and bikes?
or do they have filters specially for R/C cars?
the K&N filters look great but not work as good. I go back to foam filters. the K&N filters are just not able to filter out fine particles.
Old 04-22-2003, 01:12 AM
  #3063
cHckbOY5's Avatar
so is this too complicated for newbies?
cHckbOY5 is offline
Old 04-22-2003, 01:18 AM
  #3064
Manticore's Avatar
not at all, suggest you to stick with wt or # if you are not too sure.
Old 04-22-2003, 01:26 AM
  #3065
Vinyard's Avatar
point taken and registered. thanks
Vinyard is offline
Old 04-22-2003, 02:05 AM
  #3066
FREAKAH's Avatar
What is?
The oil thing or the car?
FREAKAH is offline
Old 04-22-2003, 02:07 AM
  #3067
cHckbOY5's Avatar
the car lol
cHckbOY5 is offline
Old 04-22-2003, 02:27 AM
  #3068
FREAKAH's Avatar
There are other kits out there that have better instructions and come equipped with set-up tools(NTC3).
The complexity of most of the cars out now are pretty similar so it depends on your mechanical and tuning skills.
FREAKAH is offline
Old 04-22-2003, 06:33 AM
  #3069
eddiethefish's Avatar
Originally posted by Pepe
Yes, that is what i did... polished. Man, I love this engine... and after polished, it is even more powerful and faster
Pepe,
Can you tell me how you polished it? What tool and what kinda polishing compound? I wanna do it on my Big Kawahara head. Thanks...
eddiethefish is offline
Old 04-22-2003, 07:36 AM
  #3070
Corse-R's Avatar
Originally posted by eddiethefish
Pepe,
You can do it with your 'almighty dremel' a #429 Felt polishing wheel and #421 polishing compound. You may need lots of polish compound if plan to polish the gritty surface.
Corse-R is offline
Old 04-22-2003, 07:54 AM
  #3071
Dill's Avatar
did you notice the engine running any hotter after polishing it? Kinda wondered if it would run a lil hotter due to losing some surface area to the polishing.
Dill is offline
Old 04-22-2003, 08:05 AM
  #3072
pepe looks good
what gave you the idea to polish the engine head? i know someone who also does that ME
did you get your radio figured out on sat?
do you really think your going to catch up to me in posts?
to polish the head i first use the dremel with a dremel bit called a buff that will allow you to get into the center
you can use a dremel to do the whole process but it can be hard to get it perfect becuase it swirls
jason102276 is offline
Old 04-22-2003, 08:10 AM
  #3073
the picture is of my sirio head after using just the buff wheel
i had flipped the car without the body and it scratched pretty badly so i decided to polish it
i had polished my buggies engine head for the same reason
also i had polished almost every piece that was purple
Old 04-22-2003, 08:16 AM
  #3074
i am unsure of the effect of polishing the head on its temp
but it may actually lower temp some
correct me if im wrong (and i probably am) but isnt aluminum foil reflective to give away heat
with the buggy it is not to uncommon for me to be able to pick it up by the engine head after a run especially in cooler weather
as far as getting hotter due to loss of material no not enough material is removed during polishing to make that happen
so little is removed during polishing just any roughness we would have to measure in in thousanths of an inch
Old 04-22-2003, 08:18 AM
  #3075
Corse-R's Avatar
Default Too many freaks there....
Whoa!
This thread is getting full of hop-up freaks, polish freaks, what about getting some TQ freaks?
Corse-R is offline
