Old 04-21-2003, 02:22 PM   #3031
patelladragger's Avatar
Send a message via AIM to patelladragger
Originally posted by Manticore
yes, stock shock oil is #600, i think 60Wt does work similar.
actually me and some friends just looked this up. 600wt theoretically is equivalent to 48wt oil.
One is using the cps rating while many american cars (and serpent) use the WT "weight" rating.
Here is a chart
100 Cps 10 WT
150 Cps 15 WT
200 Cps 20 WT
275 Cps 25 WT
350 Cps 30 WT
425 Cps 35 WT
500 Cps 40 WT
Try here for more info
http://www.twf8.ws/new/tech/tip/shock.html
patelladragger is offline   Reply With Quote
Old 04-21-2003, 02:28 PM   #3032
Originally posted by supra528
can someone please answer my question?????????/
I think we already did. There aren't many situations in nitro RC where a heavier car is preferable over a lighter one that I can think of. I'm not an expert by any means so maybe someone else can advise you on this.
Old 04-21-2003, 02:44 PM   #3033
supra528's Avatar
ok......thnx
supra528 is offline   Reply With Quote
Old 04-21-2003, 04:24 PM   #3034
Data's Avatar
Default Solid Axial
patelladragger, manticore, czotails, kevink2, tekrsq:
came up with two ways to do the solid axial :
1) modify existing gear/diff housing, then make two Al shafts which will sandwich the modified gear in the middle – this way is easier to do, but need to get a brand new diff housing to work on and will be a little heavier.
around $15 for the two shafts plus the cost of the diff housing ($9 + tax…..damn… )
2) make spur gear out of delrin and then the two Al shafts – this way has more labor involved but it will be lighter then the first one.
around $45 for the gear and the two shafts.
also grub screw extremist manticore suggested to use grub screw to hold the out drives instead of the pins. then i need to cut flat on the out drive shaft.
i am leaning toward the first one, so what do you guys think ?
Data is offline   Reply With Quote
Old 04-21-2003, 05:14 PM   #3035
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: Solid Axial
I'd rather have my car light, so I prefer the latter one. Thank you
eddiethefish is offline   Reply With Quote
Old 04-21-2003, 05:20 PM   #3036
Data's Avatar
Default Re: Re: Solid Axial
you are not on the list, so i don't care which one you prefer. now go away
Old 04-21-2003, 06:12 PM   #3037
Default Re: Re: Re: Solid Axial
mean, mean, mean...
Old 04-21-2003, 06:15 PM   #3038
For some reason, I can't picture what you're talking about in the first example.
I don't know what type of maching capabilities you have, but I was thinking somethng along the lines of the front axle. A single machined piece of aluminum that the stock gear could be bolted to. Simply cut out the center section of the gear so it'll slide over the axle section. The outdrives could either be slid into the ends and secured with grub screws, or machined into the axle as one piece. I have a titanium axle for my MRX-3 made like that. It's incredibly light, very trick, and works very well.
I have the AIP solid axle "adapter". It's pretty trick, but I think someone with the right machines could make something lighter.
tekrsq is offline   Reply With Quote
Old 04-21-2003, 06:25 PM   #3039
Data, it took me a while , but after heraring the way you talk, I just realized who you are. Have you run the car with a solid yet?
thebutcher is offline   Reply With Quote
Old 04-21-2003, 06:34 PM   #3040
kevink2's Avatar
1) modify existing gear/diff housing, then make two Al shafts which will sandwich the modified gear in the middle ?this way is easier to do, but need to get a brand new diff housing to work on and will be a little heavier.
around $15 for the two shafts plus the cost of the diff housing ($9 + tax?.damn?flaming: )
2) make spur gear out of delrin and then the two Al shafts ?this way has more labor involved but it will be lighter then the first one.
Data: I would go for whichever has the least rotating mass. Rocket Ronbo just epoxied his diff together, so it'd be cool it is even less massive than that. If you look at the Kawahara solid for the V-One R or the one for the Yoke GT-4, that's what I would desire most.
kevink2 is offline   Reply With Quote
Old 04-21-2003, 06:37 PM   #3041
yeah, those units are trick. But if you could mold the outdrives into the piece that would be even tricker....(wait is that a word?)
Old 04-21-2003, 07:59 PM   #3042
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
is this car too complicated for newbies?
cHckbOY5 is offline   Reply With Quote
Old 04-21-2003, 10:39 PM   #3043
Cool Pictures of my car
I am trying to attach a picture... but nothing.... lets try again
Pepe is offline   Reply With Quote
Old 04-21-2003, 10:43 PM   #3044
Default Pictures
Pic 1
Old 04-21-2003, 10:44 PM   #3045
Default Pictures
Pic 2
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
