Mugen MTX-3
Old 04-14-2003, 04:32 PM
  #2866
Top three cars at speedline were mtx3's.
Bryan N. is offline
Old 04-15-2003, 02:15 AM
  #2867
Corse-R's Avatar
Default Re: Re: Spanish nats. (2nd round). Arenales del sol track.
Originally posted by patelladragger
Why were you guys discarding at such a large diameter. Were you finding the car works much better on full-size tires?
Track was so bumpy that if you go with smaller tyres you got problems with the chassis bottoming out (no matter whatever you did with droop adjustment) .
I didn't discarded, kept all the sets I used for another time (here there are tracks where you need to start at 62mm or lower).
Corse-R is offline
Old 04-15-2003, 01:35 PM
  #2868
Default servo saver
What kind of servo saver did you guys find more appropriate for steering? Help greatly apprciated.
Pepe is offline
Old 04-15-2003, 02:41 PM
  #2869
Vinyard's Avatar
i am running ackerman B.
so far it works for me in both big and small technical tracks.
Vinyard is offline
Old 04-15-2003, 02:42 PM
  #2870
Vinyard's Avatar
Vinyard is offline
Old 04-15-2003, 02:54 PM
  #2871
pepe i think you should use the A ackerman
correct me if im wrong guys that is the one with the most aggressive steering
pepe races with me on a really tight and technical track where i am always trying to get more steering
jason102276 is offline
Old 04-15-2003, 03:39 PM
  #2872
TBR
TBR's Avatar
I know that I run on a different track but I found that by using B Ackerman was better as I found A gave to much steering.
TBR is offline
Old 04-15-2003, 05:42 PM
  #2873
mitch179's Avatar
Hey people...
I will be getting an MTX-3 in the next month or two...
i just had a few questions:
1. How strong is the car ? ? is it as strong as say a v one rr ?
2. What spares should i get when i buy the car ? whats most likely to break if something does break ?
3. do you have any tips in building the kit ?
please dont tell me to read the whole thread i dont have time
i think i will be getting the rody X12 for it so this car should be fun
mitch179 is offline
Old 04-15-2003, 06:28 PM
  #2874
TBR
TBR's Avatar
The MTX-3 is the Bomb!
It goes hard right out of the box.
Only building tip I suggest is shave a little of the brake pads so they dont bind up and feel tight when pushing the car along.
Spares
I suggest just things like rear swing arms and front A arms
TBR is offline
Old 04-15-2003, 06:47 PM
  #2875
mitch179's Avatar
RAD!
thanx for the info
cant wait to get mine
also what gearing comes with the car ? ? the track i race on has a huge straight so i might need to buy some taller gears
mitch179 is offline
Old 04-15-2003, 07:04 PM
  #2876
kevink2's Avatar
Yep, depends on your track of course, but the A ackerman is pretty aggressive.
kevink2 is offline
Old 04-15-2003, 07:10 PM
  #2877
TBR
TBR's Avatar
Originally posted by mitch179
RAD!
thanx for the info
I think its 17/20 correct me people if I am wrong. I use 17/21 and change the spur gears from 47/43 to 46/42
hope this helps
TBR is offline
Old 04-15-2003, 07:12 PM
  #2878
TBR
TBR's Avatar
Originally posted by kevink2
Yep, depends on your track of course, but the A ackerman is pretty radical.
Yeah,
What blocks do you run in the rear A, B or C
Have you experimented with having different ones?
TBR is offline
Old 04-15-2003, 07:25 PM
  #2879
Manticore's Avatar
hope this helps
stock gearing is 16/20 and 47/43
Manticore is offline
Old 04-15-2003, 07:38 PM
  #2880
patelladragger's Avatar
is anyone running the solid axle yet? If so any input on how it is working with the car?
patelladragger is offline
