Old 04-12-2003, 08:24 AM   #2851
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by eddiethefish
yeap! Manticore got it darn right! Those bearing will make'm smooth as KY Gel... he he he...
who makes them?
Manticore is offline   Reply With Quote
Old 04-12-2003, 06:50 PM   #2852
Roger's Avatar
Got a question. Just put my car together and ran it for the first time on my driveway. I noticed that when I hit 1/8 throttle, the engine revs, but the car doesn't move. It'll start moving when I hit 1/4 throttle. Should I loosen the clutch or tighten ?? Thanks gang.
Roger is offline   Reply With Quote
Old 04-12-2003, 07:09 PM   #2853
I believe you loosen the clutch because your engine is engaging to late.....be careful with it engaging to late because thats how you burn up those weird looking bearings......(having a brain spasm....forget what they're called) anyways, good luck, and if that doesnt help, the manual does a pretty good job and if you go back like a billion pages, when i was having trouble with my clutch everyone helped me out very spicifically so you could check there also
Nytrochaos is offline   Reply With Quote
Old 04-12-2003, 07:13 PM   #2854
Roger's Avatar
thanks
Old 04-12-2003, 07:24 PM   #2855
I'm pretty sure:
weird looking bearing= thrust bearing
tekrsq is offline   Reply With Quote
Old 04-12-2003, 07:51 PM   #2856
kevink2's Avatar
Make sure the clutch bell is shimmed properly per the instructions. If so, then you can begin loosening your clutch for quicker engagement.
kevink2 is offline   Reply With Quote
Old 04-12-2003, 11:21 PM   #2857
thanx for your help and support guys,my front diff isn't leaking any more and i think my white hairs are going away.thanx! =)
shortyboy is offline   Reply With Quote
Old 04-13-2003, 04:55 PM   #2858
Default Servo Horn Included
Just a quick question?
Is the servo horn included in the kit or do I have to buy one. Couldn't find it in my kit?
Sami
ttektek is offline   Reply With Quote
Old 04-13-2003, 05:14 PM   #2859
kevink2's Avatar
Default Re: Servo Horn Included
Sami
You'll have to buy one separately. It's nice if you get ones that have multiple mounting positions incase you need to alter the amount of servo throw in relation to wheel/trigger movement.
Old 04-13-2003, 07:34 PM   #2860
patelladragger's Avatar
Send a message via AIM to patelladragger
Default mtx-3 kicking arses
mtx-3 are spreading like wildfire down here and kicking some major butt at the track too. One very good driver I know picked up 2 laps on his NTC3 FIRST TIME OUT with the car. Went from mid-pack A to TQ'ing and kicking everyone's butt - bone stock setup. This car is for real!
patelladragger is offline   Reply With Quote
Old 04-14-2003, 01:59 AM   #2861
Send a message via ICQ to Cartman
Default British Nats
just completed 1st round
out my mtx3 18th and finished 16th
here is my rubber set up
blue springs all round
3racing roll bars soft settings
shock pistons front 3 X 1mm hole rear 4 X 1mm
modified shock mounts
100,000 front diff
10,000 rear diff
1 camber all round
rear hubs cut down 5 mm
outer camber link
1 small washer front caster
"a" ackerman
"c" rear mounts
1/2 toe in
5mm ride height front
6mm rear
ran ing tyres
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 04-14-2003, 02:04 AM   #2862
Roger's Avatar
Team Mugen takes it again at Las Vegas. Robbie Collins and his MTX-3 won nitro sedan. I wonder how many mugen cars were in the A-main ? Anybody ?
Congratulations Robbie. ( Hey Robbie, if your reading this, watch out for the blair witch. Remember ? )
Old 04-14-2003, 03:25 AM   #2863
Corse-R's Avatar
Default Spanish nats. (2nd round). Arenales del sol track.
Well, this time couldn't be the same as the first round of the nats, where 2 Mugen were at 1st and 2nd position (an NTC3 was at the 3rd), Held at Lerida (Catalonia).
Yesterday the podium were quite different, but the most shocking was at the minute 27 where an MTX3 was at first position needed to retire with the two rear bulkeads broken at the same place (at the bulb). Final podium was formed by Serpent 705 at the 1st and 3rd position and one MTX3 at the 2nd place (after all isn't at all bad - 2 rounds, two times an MTX is at the podium).
BTW: The guy that retired at minute 27 was the same that won the first round of our nationals. He's a privateer and if he won the second round, the sky for sure that rumbled.
Third round is the next month. We'll see how evolves. Will try to find and post photos of our nationals.
I've had a terrible weekend. Got difficulties to setup the car for those bumpy and slippery track (we used 64mm of diameter tyres and discarded at 62mm), on a terrible smack warped the chassis and without spares got a faulty handling.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 04-14-2003, 04:18 PM   #2864
Default Re: Spanish nats. (2nd round). Arenales del sol track.
Why were you guys discarding at such a large diameter. Were you finding the car works much better on full-size tires?
Old 04-14-2003, 04:21 PM   #2865
Moderator
Jpilone's Avatar
Send a message via AIM to Jpilone
Dang! I cut my tires at 61 in the rear and 60.5 in the front!!!
I'll take all of your 62mm tires!
Jpilone is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
