Mugen MTX-3
Old 03-25-2003, 03:13 PM
  #2626
PM or email me: [email protected] A friend is looking for one.
ChrisF is offline
Old 03-25-2003, 03:14 PM
  #2627
CSF0623's Avatar
Default MTX3 FOR SALE
Open to those living in the So Cal area!! Car used 1 race day @ Crystal Park Raceway.
Car includes the following no eletronics/mtr!
-New Mugen 4mm chassis (recently installed NEW)
-Aluminum mtr mount
-Aluminum side brace
-Aluminum hex hubs
-Front universals
-Xtra spurs 46/42
-Xtra pinions 17/21
-Springs frt and rear grey/purple sets
-Silver rear swaybar
-Lower frt and rear arms (1 set)
-Front steering blocks ( 1 set)
-Rear uprights (1 set)
-Diff gear set to build front diff w/out front bearings
-New Fast tires front 26mm 40 (4 pairs), 42 (2 pairs), Rears 30mm 40 (3 pairs), and 42 (2 pairs).
Everything worth over $760, price not yet set should be way below listed price. E-mail me if your interested!
Thanx Carl.
CSF0623 is offline
Old 03-25-2003, 03:15 PM
  #2628
Carl:
Your PM'ing is disabled and there is no email address.
ChrisF is offline
Old 03-25-2003, 03:34 PM
  #2629
CSF0623's Avatar
Chris: try it again sorry!
Here's another pic w/body.
CSF0623 is offline
Old 03-25-2003, 04:09 PM
  #2630
CSF0623's Avatar
Chris you got mail!
CSF0623 is offline
Old 03-25-2003, 04:37 PM
  #2631
Default Brakes and Front Gears
I finally got the clutch straigten out (I think). the screw is about 1-2mm outside the nut but it has a decent acceleration, I just put Racer's Edge one way bearing lube every other tank.
This car runs great and has excellent handling. It's just hard to get used to one having the one way though. But a lot of people like it coz it has that drifting effect. Not good on tires though.
My problem is that I sanded the pads a bit and I even sanded the ninja start vent disk but the brakes still drag a bit. Sometimes it moves somewhat freely but sometimes it just drags.
Also, Anybody know the front diff gear set part number? I just need the gears right or do I need a different housing than the one that came with the kit?
your help has always been grately appreciated
Sike is offline
Old 03-25-2003, 04:38 PM
  #2632
kevink2's Avatar
That was kwick Carl, is it Yoke time? BTW I meant to ask you last weekend, who paints your bodies? They're really nice!
kevink2 is offline
Old 03-25-2003, 05:38 PM
  #2633
CSF0623's Avatar
Kevin: yeah received an offer I couldn't refuse from another mfg! I paint my own bodies w/ the aid of parma masking.. BTW are you Karsikk? If so your painting are the sh*# also! Always admired your paint jobs since the So Cal electric days.
CSF0623 is offline
Old 03-25-2003, 06:05 PM
  #2634
kevink2's Avatar
Yep. You do an awesome job, man, it looks totally pro. That's also great regarding the offer, congrats!
kevink2 is offline
Old 03-25-2003, 07:09 PM
  #2635
Default Re: Brakes and Front Gears
You can use the housing that comes with the housing BUT change the screws to a longer and wider cap. If not the diff oil will sure to leak
darthkir is offline
Old 03-25-2003, 07:36 PM
  #2636
Michael_T's Avatar
Trader Rating: 49 (100%+)
The brakes need to be sanded down quiet abit. Also, you should notice after 1 day of racing, they should not bind anymore. I would just leave them, run the car for awhile and check them. Most of the guys at our track had this problem, but after a hard days racing, the car's drivetrain loosened up quiet a bit. If they still bind, it could be a problem with the way you have your brake linkage setup.
Michael_T is offline
Old 03-25-2003, 07:42 PM
  #2637
Manticore's Avatar
Default Re: Re: Brakes and Front Gears
the main reason of brake blinding is because of the steel brake pad backing plate is not perfectly flat. the plate is curve due to the manufactoring process. check it on a flat glass top to see that the plate is uneven and curve. simply use your finger to twist the backing plate until it is almost flat and the problem is fixed.
Manticore is offline
Old 03-25-2003, 09:39 PM
  #2638
CSF0623's Avatar
Thanx Kevin!
CSF0623 is offline
Old 03-25-2003, 10:09 PM
  #2639
Michael_T's Avatar
Default Re: Re: Re: Brakes and Front Gears
Once again Master Moon saves the day
Old 03-27-2003, 12:53 AM
  #2640
RClover's Avatar
i have done up my kit but havent got time to run it.
But i notice the 'clicking' sound coming from the front near the one-way pulley only when i roll the car backwards. Anyone knows why?
RClover is offline
