Old 03-17-2003, 11:20 PM   #2566
i installed the mugen 4mm chassis on my car tonight and its sweet
i wish it had come with the brake stopper piece that screws in instead of the pins anyone know where i can get one?
and my engine mounts i got from justrc with the other chassis might have fit but i noticed the screw heads would have stuck out below the chassis i really wanted to use them too
i also had to remove the spacers i put to lower the tank
luckily my servo still fits under the upper deck
there is almost no room at all under engine and i am not sure i can even slide a piece of paper under the throttle servo
and i noticed when i was done installing it after removing the chassis from justrc i had to lower the ride height a couple of mm
this is an awesome chassis
do any of the aftermarket aluminum radio tray supports fit without modification?
jason102276 is offline   Reply With Quote
Old 03-18-2003, 01:26 AM   #2567
can i get harmonymodels website?thanx
also,does anyone have a good rubber tire setup for asphalt?im currently running the mtx-2 setup on their website and 10k front and 5k rear.
shortyboy is offline   Reply With Quote
Old 03-18-2003, 02:12 AM   #2568
FREAKAH's Avatar
My rubber setup is pretty good right now(about 75%) but i'm still working on it. It's not too far from the stock setup though.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 03-18-2003, 04:43 AM   #2569
RClover's Avatar
i cant remember their web address, but its just a simple one page website with Contact details and shop front image.
Just tell him what you want and he'll reply you the same day. Prompt and fast service.
RClover is offline   Reply With Quote
Old 03-18-2003, 05:14 AM   #2570
RClover's Avatar
go for the Sato Seiki radio Plate support, you only need to file away the edges just a little to make it fit. It took just few seconds.
Old 03-18-2003, 05:26 AM   #2571
RClover's Avatar
File away both sharp edges on the right while only front sharp edge of left will do.
Old 03-18-2003, 06:03 PM   #2572
NitroMugenLV's Avatar
Wondering if someone could help me with the diminsions of the Battery tray on the MTX3. And much space there is from the chassis to the bottom of the fuel tank.
NitroMugenLV is offline   Reply With Quote
Old 03-18-2003, 06:23 PM   #2573
RClover's Avatar
both the stock chassis and 4mm Mugen chassis weight the same, slightly below 110grams...
Old 03-18-2003, 08:04 PM   #2574
puma1824's Avatar
Send a message via AIM to puma1824
-I am also looking for a good rubber tire setup.
- I unfortunateky bought the kit WITHOUT the engine so I'm having a difficult time picking an engine and pipe. Any suggestions? I don't know who to believe anymore.
Please post away
puma1824 is offline   Reply With Quote
Old 03-18-2003, 10:03 PM   #2575
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
My mistake guys but I forgot to mention that this problem also occurs with the radio tray support from JustRC as well. They are both from the company 3Racing you will encounter the same problem.
Racing4Evo is offline   Reply With Quote
Old 03-18-2003, 11:26 PM   #2576
Corse-R's Avatar
Much depends on your skills, the amount of money and your local rules. Choose of pipe depends too on the layout of your local track, tell us about and you get an answer.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 03-18-2003, 11:32 PM   #2577
Puma,
Here is a set-up for rubber tires to be run in a perking lot if this helps...... its from a Mugen Team driver in the US....
42 fronts
37 rears
silver springs all around
shock oil 800w front
shock oil 350w rear
front shock position second hole from bottom
rear shock position second hole from bottom
front camber -2 degrees
rear camber -3 degrees
front toe 1/2 degrees out
rear toe 1 1/2 degrees in
swaybar front 15 degree angle
rear swaybar none
front droop +2
rear droop +6
down stops none
rear camber link inner hole down
outer hole up
front ride hieght 4mm
rear ride hieght 5 mm
front car wigth 198mm
rear car wigth 200mm
gear 16/49 19/45
body Dodge Stratus
wing position middle hole
plug Rex No 6
fuel 30% to 40%
Alot of people ar loving the new MR-12 engine......
Hope this helps
Old 03-18-2003, 11:59 PM   #2578
Corse-R's Avatar
Originally posted by NitroMugenLV
Puma,
gear 16/49 19/45
Uhm.... are you sure that this setup isn't for an MTX2?
Cheers,
Corse-R
Old 03-19-2003, 01:38 AM   #2579
FREAKAH's Avatar
Puma,
42 fronts
37 rears
Isn't this a foam set up?
Second-Hand Racing
RACE WORLD HAWAII
Old 03-19-2003, 05:45 AM   #2580
puma1824's Avatar
The one track I'm going to go to has no regulations on engines short of a .21
I'm actually new to the race scene and also do a lot of parking lot bashing/racing with friends.
My kit's still in the mail from Ultimate Hobbies. Does the kit come with the manifold? I know it has NO engine or NO pipe.
Was considering the following:
Sirio .12 legal or outlaw (not sure which pipe)
RB Concepts .12 X12 w/x12 pipe
Mugen .12 MT Turbo or MR roar legal (which is faster? not sure which pipe)
OS .12 TR Turbo (not sure which pipe)
Also still looking for a rubber setup since I have a ton of rubber tires and wheels laying around.
Have you guys fowled up your belts much? I'm coming from a NTC3 background.
Help
Thanks,
Puma
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
