Old 03-16-2003, 07:30 AM   #2536
modellor's Avatar
The oil/grease weight in the diffs is really a personla preference thing. Some people with 1:8th background prefer heavier or solid whereas people with more electric background will prefer looser diffs.
I personally come from a 1:8th background and prefer solid axles to diffs even on twisty tracks. Due to our rules however, we have to have all wheels braking so I run solid axles front and rear as a diff wont work in the front with a rear solid axle.
As for lack of grip on different surfaces, I compensate the loss through the shocks and anti-roll bars which seems to work best for my no brakes driving style.
modellor is offline   Reply With Quote
Old 03-16-2003, 07:33 AM   #2537
Corse-R's Avatar
Default Re: Re: Re: preaching to the converted
Originally posted by VenomWorldOrder
ok. that's enough mugen talk for the fortnight. i'm putting myself on a "mugen praise" ban until next race meet. ow yeah i think i was the first to traction roll for 2003 at helles. i was running greys all round with 40's and tractionrolled comming into the first corner after the straight about 2 or 3 times. my best lap time was done with chunked rears and warped front tires. THIS CAR IS TO EASY TO DRIVE.
To cope with traction rolls you need to put the larger 2.5mm rear roll bar. Haven't tested but some people stated that the 3racing rear blade roll bar is softer than the stock bar.
Saturday we did some pretty backflips and traction rolls at my track.... Grey springs, 42/42 shores, messing with shock positions.... none, nothing, nada.... the cure for this was the 2.5mm roll bar.
In fact, broke my personal best lap... Oumph! 20,05 secs from Barry Baker last year are quite near... near! only more HP, please.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 03-16-2003, 07:55 AM   #2538
RClover's Avatar
Originally posted by NitroMugenLV
Question:
And is there any option or hop-ups that you would recommend for this car. Or is it just perfect straight out the box?
there plenty of hop-ups that we run on our cars, such as:
1. Alu. Anti-roll bar mount (Front)
2. Alu. Center Shaft mount
3. Alu. Radio Plate Support
4. Alu. Engine Brace
5. Alu. Brake Bracket
6. Alu. Hex Drive Hubs
7. 4mm Chassis
8. Teflon Brake Pads
9. CVD front
10. Alu. Engine Mount
if you want to reduce flex of the car, item 3 & 4 is what you need.
The car handles great even w/o hop-ups too! Ask robbie! he ran his car stock during Winternat!
RClover is offline   Reply With Quote
Old 03-16-2003, 08:00 AM   #2539
RClover's Avatar
anyone running the k-factory rear adj blade bars yet? looks good!
Old 03-16-2003, 09:06 AM   #2540
tennessee's Avatar
Yep
They work very well
I picked mine up from
www.justrc.com
It only took 2 days
tennessee is offline   Reply With Quote
Old 03-16-2003, 09:34 AM   #2541
What's the difference between the stock rear sway bar, the Mugen 2.5, and the blade type bars? I'm assuming it's stiffness, but which is softest, stiffest, and which is more adjustable?
tekrsq is offline   Reply With Quote
Old 03-16-2003, 10:06 AM   #2542
Corse-R's Avatar
I only can talk about the Mugen 2.3mm and the 2.5 (the ones I own). But what I've read here is in order of stiffness go like this:
- Mugen 2.5mm.
- Mugen 2.3mm (Stock).
- 3 Racing blade bar.
On adjustability, the 3racing is the most adjustable, but the wire ones are too adjustable (you only need to adjust the stiffness moving the ball coupling on the bar inner or outer).
Cheers,
Corse-R
Old 03-16-2003, 11:23 AM   #2543
So the 3Racing bar is softer (at its softest setting) than the stock bar? But at its stiffest setting, should be stiffer than the 2.5 bar?
Old 03-16-2003, 06:48 PM   #2544
Hi guys,
My MTX-3 is still stock, and I have a question on diffs.
I replaced the supplied one way with a diff. I run 5000 front and 3000 rear. I only run at one track. It's alphalt, short track with many tight corners.
I dont have experience playing around with diff settings. My quiestion is, does my setting sounds right? I know that it's not possible to point out the best setting as there is no such thing, many variables need to be factored in. At least I just want to make sure that I'm in the right direction.
darthkir is offline   Reply With Quote
Old 03-16-2003, 07:18 PM   #2545
FREAKAH's Avatar
I also run on a tight asphalt track with a front diff and rubber tires. I am presently using 10,000 and 5000 front and rear with great results.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 03-16-2003, 07:34 PM   #2546
tennessee's Avatar
Play around with you're diff oils....
You may like using 50,000 or 100,000 wts in the front diff if you run on a tight track while using 10,000 to 30,000 wts in the rear, this may seem odd to do but try it and see how it does.....
Old 03-16-2003, 07:41 PM   #2547
tennessee's Avatar
Question:
I have been out of Sedan Racing for about a year now, and am looking at getting back into it. I am planning on getting the MTX3, I am just wondering if there is any split in the tires when using foams?
They're is no split like in 1/8 scale, but you may run you're rears about .5 to 1 mm bigger than the front tires depending on tire wear....
Aluminum side brace is a must and radio tray brace also....
goto this site for all of you're hopups
www.justrc.com
Old 03-16-2003, 07:44 PM   #2548
tennessee's Avatar
Default Re: Re: Re: Re: preaching to the converted
Which blocks were you using in the rear????
What track were you at????
Old 03-16-2003, 07:59 PM   #2549
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
FYI:
For those of you that just bought your cars and are planning to upgrade soon be aware that the RDLogic Radio Tray support is not compatible with the new 4mm chassis from Mugen. I guess this goes for everyone that have yet tp hop up their cars too.
Racing4Evo is offline   Reply With Quote
Old 03-16-2003, 11:15 PM   #2550
NitroMugenLV's Avatar
Im going to running on a big track (Las Vegas Silverbowl R/C track) and I was wondering if anyone knew of a good gear ratio to run on this track. I will be using the MR-12 engine.
NitroMugenLV is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
