Old 03-10-2003, 06:26 PM   #2461
Hi Guys,
I had the same problem with the leaking front diff. The design is not very good.
The cover is extremly thin, especially the countersunk screwholes. This means you can't put alot of pressure on the gasket as you will pull the screws through the cover. I did this after I noticed a leak!!
A small bead of silicon sealer is absolutely necessary, its just not a very good design!!
All the best
click, dublin is offline   Reply With Quote
Old 03-10-2003, 07:27 PM   #2462
patelladragger's Avatar
Send a message via AIM to patelladragger
so I must've missed it earlier. the mtx-2 dogbones are the right size that will stay in the mtx3 without falling out?
patelladragger is offline   Reply With Quote
Old 03-10-2003, 07:50 PM   #2463
sparksy's Avatar
Trader Rating: 14 (94%+)
Yep
The MTX 2 bones will fit up front. They are slightly longer than the 3's so they also fall out less
sparksy is offline   Reply With Quote
Old 03-10-2003, 07:54 PM   #2464
RClover's Avatar
Default Fuel leakage
What could be the better solution to stop fuel from leaking all over the crankcase? what's the better sealer and where to seal?
RClover is offline   Reply With Quote
Old 03-10-2003, 08:15 PM   #2465
I used CA to stop the leak. I dunno if its a good way.
darthkir is offline   Reply With Quote
Old 03-10-2003, 08:32 PM   #2466
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Fuel leakage
replace the front bearing. that is the most likely problem with fuel leaking from an engine.
Manticore is offline   Reply With Quote
Old 03-10-2003, 08:33 PM   #2467
Manticore's Avatar
Old 03-10-2003, 08:37 PM   #2468
Jack's Avatar
use high temp copper sealant that is oxygen safe...
that is your best bet.
Jack is offline   Reply With Quote
Old 03-10-2003, 08:39 PM   #2469
Advanti's Avatar
my engine leaks too...i noticed the fuel coming from the carb slide and around the carb neck joint...replaced the o-rings but the leak persist...
Advanti is offline   Reply With Quote
Old 03-10-2003, 08:58 PM   #2470
Originally posted by Manticore
I stopped the diff leak by using CA. I glued the diff case together.
Old 03-10-2003, 10:39 PM   #2471
CSF0623's Avatar
Originally posted by kevink2
Robbie C. gives us a race update from Crystal Park yesterday! How'd it go?
Hey Kevin it was Robbie, Pepe and I think Tennesse (Pepe TQ) for the top 3! I finally ran my MTX 3 yesterday and the car was not that bad for the first time out. Robbie gave me a hand with set-up couldn't fiqure out the front droop/sway-bar setting. Thanx Robbie for the help! I myself qualified 11th over all and finished 3rd in the B-main (need mo' motor). Will you be racing the AIRTRONICS race?
CSF0623 is offline   Reply With Quote
Old 03-10-2003, 10:46 PM   #2472
kevink2's Avatar
Originally posted by CSF0623
Hey Kevin it was a Robbie, Pepe and I think Tennesse (Pepe TQ) for the top 3! I finally ran my MTX 3 yesterday and the car was not that bad for the first time out. Robbie gave me a hand with set-up couldn't fiqure out the front droop/sway-bar setting. Thanx Robbie for the help! I myself qualified 11th over all and finished 3rd in the B-main (need mo' motor). Will you be racing the AIRTRONICS race?
Yeah I'll be there Carl. I'll be doing 1/8th scale and pan car though. I'll probably be at Rev. next weekend though, working on the MTX. Hey, 11th overall qualifier ain't bad for the first time with the car, especially with that crowd.
kevink2 is offline   Reply With Quote
Old 03-10-2003, 11:34 PM   #2473
Send a message via AIM to Bryan N.
Kevin, I sent you a PM.
Bryan N. is offline   Reply With Quote
Old 03-10-2003, 11:45 PM   #2474
RClover's Avatar
Default Re: Re: Fuel leakage
will check that out...but it looks more like a carb leaking problem where most of the fuel gathered around the carb joint area...
Old 03-11-2003, 08:25 AM   #2475
Advanti's Avatar
Default Re: Re: Re: Fuel leakage
its normal for these engines to have leakage problem
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
