Old 02-27-2003, 09:01 AM   #2341
kevink2's Avatar
Originally posted by jason102276
if i am remembering correctly
ankerman a=most steering c=least steering
maybe i should say responsive steering
a blocks in rear roll center=less rear traction and c= most rear traction
am i right? i hope so
i know somebody out there knows for sure
kevink2 is offline   Reply With Quote
Old 02-27-2003, 09:08 AM   #2342
ROBBIE C's Avatar
Send a message via AIM to ROBBIE C Send a message via Yahoo to ROBBIE C
Originally posted by Cartman
Robbie is there a pdf version i can download?
Cheers
Mark
You should be able to download the manaul from the mugen racing website.
ROBBIE C is offline   Reply With Quote
Old 02-27-2003, 09:31 AM   #2343
ROBBIE C's Avatar
Default Re: Re: Re: Re: Re: mtx3 engines
Originally posted by Corse-R
Robbie, congrats about your position at the Winternats (yes, I know you're tired of hearing/reading the same, but.... ) to the 'business'...
What about the Mugen 4mm chassis? I find that I've stiffened enough the rear portion of the car, but planning to put on the track a second chassis with Lola body and wanted to know about the optional chassis.
Any throughts if Mugen plan to release a floating rear body mount or need to do some bricolage like the photo that posted Manticore on the past days?
The option chasis is milled out for lower cg's, by having lower center of gravity stability of the car should be good less chance of rolling over.
I don't think Mugen will be coming out with a floating rear pod, this type of rear end usually only works on large high bite tracks, floating rear pods takes the roll out of the rear end thus taking away traction, on the other hand if you are using a Lola body this type of rear end would be great do to the fact Lola bodies have so much down force.
Old 02-27-2003, 09:35 AM   #2344
Corse-R's Avatar
Originally posted by Manticore
Just got the Mugen option 4mm chassis. real cool and stiff !!!!!!
Aaargh! And you told me 'hop up maniac'????
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 02-27-2003, 10:03 AM   #2345
ROBBIE C's Avatar
Default Re: Robbie C
Originally posted by Novarossi
Hi Robbie,
Hope you can answer these 3 questions I have regarding your WinterNats setup ;
1. Yourself/Kenji/Tim all opted for the optional H0767 Super Hard clutch spring over the standard kit spring - What was the reason for this? Any input on feedback on this would be great
2. I noticed you and Tim were using Red Clutch shoes - I take it these are harder than the standard black shoes - Are these Mugen products?
3. Did you guys play around with the different ackerman and rear block adjustments? Any info on how the other ones felt?
1. The sliver spring gives you more snap off the corners.
2. The red shoe is a hard material power is smoother and consistent, it also last alot longer than the other soes.
3.When the bite came up we changed to the B ack in front and the A A blocks in the rear = less steering lower CG's.
Old 02-27-2003, 10:20 AM   #2346
Corse-R's Avatar
Default Re: Re: Robbie C
So.... with the addition of 4mm chasis and the blocks, and dirty tricks like throttle servo under the radio plate, CG should be about a pair of inches under the track...
Seems that i'm not the only that doesn't likes the stock shoes... I change it almost each race on the MRX3, they glaze and don't grip correctly.
Wanted to test the Red shoe, but found some that went real good and the best of all, doesn't glazes nor wears anormally.
Cheers,
Corse-R
Old 02-27-2003, 10:40 AM   #2347
ROBBIE C's Avatar
Default Re: Re: Re: Robbie C
I've been running the same shoe for four months.
I have two major racess and alot of club racess on it,still works great.
Old 02-27-2003, 11:02 AM   #2348
robbiec when do you expect the mugen 4mm chassis be available here in usa
jason102276 is offline   Reply With Quote
Old 02-27-2003, 11:18 AM   #2349
ROBBIE C's Avatar
next week
Old 02-27-2003, 02:03 PM   #2350
chookgb's Avatar
Trader Rating: 26 (100%+)
robbie c are the red shoes a mugen part if so is there a part number please if not where are they available
chookgb is offline   Reply With Quote
Old 02-27-2003, 02:35 PM   #2351
ROBBIE C's Avatar
No there not from Mugen, Tim Long sells them for $9.99 you can reach him at (949) 707-5607
Old 02-27-2003, 02:46 PM   #2352
JUN
Are these the delta red clutch shoes??
JUN is offline   Reply With Quote
Old 02-27-2003, 04:06 PM   #2353
Motorman's Avatar
As Tims phone Rings constantly off the wall. BRIIING, BRIIING, BRIIING. LOL
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 02-27-2003, 05:47 PM   #2354
ROBBIE C's Avatar
Yeap delta is what they are.
Old 02-28-2003, 09:35 PM   #2355
acs
acs's Avatar
Have you got any pics of the chassis on your car?
acs is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
