Old 02-13-2003, 08:15 AM   #2176
YBSLOW's Avatar
Default 4MM Chassis
I have seen the 3 Racing chassis that JustRC sells and if you use the Mugen starter box your hosed. The new Mugen chassis from Mugen should be available at the end of the month, Robbie is running one in Florida and says it is pretty sweet. The blade sway bar worked very well for Tennessee and I at Crystal Park last weekend. It is definetly softer in its stiffest setting but only slightly. I think at Revelation you would like the stiifer optional bar from Mugen and it is already available. I myself am planning on mounting some stiffer blades to the 3 racing setup.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 02-13-2003, 07:49 PM   #2177
Thumbs up
Corse-R:
I will try to post it up tonite.
Well done! Tennessee and Brad!
justrc is offline   Reply With Quote
Old 02-13-2003, 11:32 PM   #2178
Here is a better picture of the Square chassis.
Old 02-13-2003, 11:47 PM   #2179
Default Most Importtant Hop-Ups
what are the most important hop-ups need for the mtx-3 from justrc.com?i want to make my car much more stiffer and faster.please help.
shortyboy is offline   Reply With Quote
Old 02-13-2003, 11:48 PM   #2180
Manticore's Avatar
R/C Tech Charter Subscriber
i have the square chassis and I can tell you the picture here cannot show the beautiful craft quality of the chassis mainly because of the dark color.
Manticore is offline   Reply With Quote
Old 02-14-2003, 01:14 AM   #2181
shortyboy: you are welcome to send us an email, we can recommend a few options to your need.
Manticore is right about the chassis, you have to see it to believe!
Old 02-14-2003, 01:33 AM   #2182
RClover's Avatar
Default Mugen TQ in Winternats
just read that Kenji Osaka TQ in the Winternats ahead of Trinity and one lap ahead of serpent...
is he driving MTX-3...???
read from here
http://www.myrcworld.com/news/publ.asp?pid=7376
RClover is offline   Reply With Quote
Old 02-14-2003, 01:41 AM   #2183
Manticore's Avatar
Default Re: Mugen TQ in Winternats
read from here
dont need to say more ! it is not a snake for sure !
Old 02-14-2003, 03:07 AM   #2184
Corse-R's Avatar
Default Re: Most Importtant Hop-Ups
Most common upgrades fall into two categories: lightening and strengtening.
Lightening:
- lightened gear housings.
- Lightweight pulley adaptors (you need 3 in total)
- Lightweight shafts (have the Square hollowed 2 speed shaft and love it).
Strengtening:
- Aluminium center bulkhead
- Motor brace
- Brake cam (uhm.... don't know if it's only available without the blade roll bar...)
Other people can suggest others.... those parts except the brake cam were what I've ordered from JustRC.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 02-14-2003, 04:05 AM   #2185
chookgb's Avatar
Trader Rating: 26 (100%+)
Originally posted by tekrsq
chook,
Does the carbon fiber front plate keep the body posts in the stock position?
Is the blade type rear sway bar softer or harder than the stock bar?
BTW: Nice looking ride
yes the body posts mount in the same location and i am running the blade bar this weekend for the first time,next week i will fit the alloy pulleys and light weight 2 speed housings
chookgb is offline   Reply With Quote
Old 02-14-2003, 05:43 AM   #2186
TBR
TBR's Avatar
Thats domination from Kenji Osaka in the MTX3 11 seconds over Josh in second in ten minutes Whats he going to in the A main race?
TBR is offline   Reply With Quote
Old 02-14-2003, 06:29 AM   #2187
Corse-R's Avatar
2 Speed housings hollow shafts and lightweight pulley holders make a difference on acceleration, but I noticed a slight loss on the giroscopic effect of those - specially noticeable when you are at the end of the backstraight and leave engine from full WOT and entering to the turns.
Some further practice is needed to get another time the references but is good (more time full WOT means more speed and less time). Can be a little harder for the brakes but none that can be solved with a good disk brake. Noticed at my local track (at the end of backstraight you go at >90Km/h after >190Ft of full WOT).
Cheers,
Corse-R
Old 02-15-2003, 01:58 AM   #2188
Corse-R's Avatar
Uhm... I think that we should wait to the end of A-final to see what happened, 45 minutes of racing are very tough for the drivers and the cars. A-main winner is a lotto game that plays every A-final contestants, sometimes won my finals being constant and having care with my car, others lost my finals needing to retire with 2 or three minutes remaining to the end.. with a silly problem (name it, probably had it...).
Watch for the second and third positions... if are close enough of first, can be a lot of surprises here.
This weekend I plan to test many things (some gearing, some clutch shoes and springs and some exhaust - pray a little for my mental sanity ) and have three days in front to test - nationals start very soon.
Have here some different shoes to test - one resembles the yellow one that came with Picco cars (harder), I'll post some results with all the shoes (Mugen gray, Yellow and Black2 - last ones came from Italian sorces...).
Cheers,
Corse-R
Old 02-15-2003, 08:24 AM   #2189
Corse-R's Avatar
Default Testing results....
Made some break from my testing and got quite good and interesting results with some parts that I've tested today.
Clutch: Tested some clutch pads, the best was one yellow pad that is softer than the black pad and harder than the grey... Very pretty. Post after a photo. Is quite similar to the yellow clutch pad that had Picco on their Integra cars (no.... isn't a Serpent... serpent had only 3 pins on their clutch, this is a 4 pin model and lasts longer and grips better). With the stock spring and lightened flywheel weights.
Tested the 2.5mm rear anti roll bar (T0140). Unique I can say is.... Fantastic! give more steering without reducing the rear grip.
Cheers,
Corse-R
Old 02-15-2003, 09:31 AM   #2190
corse-r what did you mean when you spoke about the giroscopic effect of the lightened drivetrain?
did you mean the car slowed more rapidly after throttle was released?
and you are talking about clutch shoes that work with mugen centax right?
are some of them available through mugen and do you have part numbers?
and what kind of reaction was there when using the different shoes?
sorry for all the questions all i can do is bench race it is snowing again i have never in 26 years in Maryland seen a winter this bad the snow hasnt melted and its snowing again and its supposed to snow all weekend why didnt i keep that t-maxx or my xxx-s at least i could play with something
jason102276 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
