Old 02-12-2003, 07:10 PM   #2146
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by shortyboy
i have a big problem,i took my centax of my engine to sell it,when i took a look at the thrust bearing,the balls where missing.i found all the balls and im trying to put them back together.please help.
you have toasted your trust bearing. I would replace a new set instead of put the balls back !
Manticore is offline   Reply With Quote
Old 02-12-2003, 07:10 PM   #2147
quozl's Avatar
You can't the bearing is dead. You need to go and buy a new thrust bearing available at most good bearing stores, or hobby shops. To prevent this from happening make sure you lube the thrust bearing before each race day with a good quality high tempature grease like moly grease.
Cheers Alastair
quozl is offline   Reply With Quote
Old 02-12-2003, 07:14 PM   #2148
Manticore's Avatar
Cheers Alastair
the best way to maintain the trust bearing is to set your clutch properly. I havent lube the trust bearing long time and they work fine. I only lube them once ever 2 week "at most" or when I remember !
Old 02-12-2003, 07:30 PM   #2149
quozl's Avatar
Well that may be your method but I wont start a race day without first lubing the thrust bearing. Each to their own I guess. I also pull my car and motors down after every run to check them over, so I just do the thrust bearing as I'm reassembling the clutch.
Cheers Alastair
Old 02-12-2003, 07:38 PM   #2150
Send a message via AIM to ChrisF
quozl:
Amen! And I bet you finish most of your qualifiers and mains too
ChrisF is offline   Reply With Quote
Old 02-12-2003, 07:42 PM   #2151
Francis M.'s Avatar
yeah i agree you need to make sure the thrust bearing don't
dry up.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-12-2003, 07:52 PM   #2152
Manticore's Avatar
dry up.
surely agree but your trust bearing will possibly dry up in the first lap no matter how much lube you put on it unless you are running a snake closed trust bearing device !
as i said, a proper setup clutch is the insurance of your trust bearing from failure. the failure of the trust bearing is mainly due to over rev of the clutch bell from clutch shoe slipping
Old 02-12-2003, 07:57 PM   #2153
I agree with Manticore. I never lube my thrust bearings, the only time they failed was when i stuff the clutch settings up.
Jeffrey
Gear is offline   Reply With Quote
Old 02-12-2003, 08:26 PM   #2154
Francis M.'s Avatar
having the clutch shimed properly is a given. but if run
dry it will give out at the most unexpected time. like during
a race.
Old 02-12-2003, 08:49 PM   #2155
a race.
I think if a trust bearing is going to go it will go. Its more important to check your bearing cage for wear. having lube on the bearing gives more chance to something sticking to it.
Jeffrey
Old 02-13-2003, 01:43 AM   #2156
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Manti, what lube do you use. I use Mugen 'Sticky' grease, after a full days racing, there is still grease inside the cage.
Funny story was back when I first starting running the original MTX2, our supplier didn't have any grease at the time, so I'd lube up the thrust with heaps and heaps of Tamiya grease (the white stuff). The second I tried starting the car on the starter box, the grease would hit me in the face.
If any bearing is going to go, its either your clutch or thrust bearing. Don't forget these things spin at 35,000+RPM and take alot of the crankshaft heat. Setup up correctly, heaps of grease, and thats one less thing that won't go wrong.
Michael_T is offline   Reply With Quote
Old 02-13-2003, 02:09 AM   #2157
Wolf's Avatar
Send a message via ICQ to Wolf
For the thrust bearing, I used to lube it with some light oil. I'm getting lazy on this and only lube it if I remember. However, I will blow it with compress air almost every time I clean my car. The bearing is still in good shape.
The thrust bearing is not design to spin at a very high speed. Indeed if the clutch is not slipping severely, the bearing only rotate almost near the engine idle speed.
Wolf is offline   Reply With Quote
Old 02-13-2003, 02:19 AM   #2158
Manticore's Avatar
I will only use ronnie gease for this trust bearing if I want to.
well, wolf is correct, the trust bearing only spin before the bell is engaged. so again, if you set up your clutch correctly, the chance of toast up the bearing is very low. besides, even the snake has enclosed trust bearing, people are still toasting the bearing because of incorrect setup of clutch.
Old 02-13-2003, 02:26 AM   #2159
Ec1
Ec1's Avatar
What tips and trix do you recomend for the Mtx-3, (building one right now)
what sedan body ?? stratus?? We are not allowed to use the stratus 3 here...
Ec1 is offline   Reply With Quote
Old 02-13-2003, 02:26 AM   #2160
Ec1
Ec1's Avatar
Ops not allowed to use the Stratus 2 it shoud be..
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
