Old 02-08-2003, 02:55 PM   #2101
kevink2's Avatar
Originally posted by jason102276
does anyone know the roar minimum weight in grams?
1700 g.
kevink2 is offline   Reply With Quote
Old 02-08-2003, 03:14 PM   #2102
Originally posted by Corse-R
Uhm.... Chassis should be massive to put those kind of weight on your light MTX3 all the guys I've asked it were slightly under the minimum weight.
Not really.. Mine weighed 1723g BOX STOCK with body, MR12, electronics, and new foams. I have not weighed it since I started reducing the driveline weight. I'll complete the reductions, then re-weigh it. One of the guys here runs a Sirio in his (box stock otherwise). I don't remember the exact weight he told me, but it was considerably underweight. If he lightens the driveline, he'll have to put lead all over it to get it back to legal.
tekrsq is offline   Reply With Quote
Old 02-08-2003, 04:21 PM   #2103
yeah that chassis is heavy i may lighten it some after all other mods are completed
i should also check my scale we use it at work to measure freon but i am not 100% sure of its accuracy
jason102276 is offline   Reply With Quote
Old 02-08-2003, 05:58 PM   #2104
Manticore's Avatar
R/C Tech Charter Subscriber
So.... isn't Manti approved and being for the childish and eye candy guys?
What you think about this disk brake? It's made by an Italian manufacturer for MRX3... Very cheap when compared with the Optional Mugen (Only 25 Euros vs. 62).
it is cheap but is it good? you let me know !!
Manticore is offline   Reply With Quote
Old 02-08-2003, 10:27 PM   #2105
Francis M.'s Avatar
the 4mm chasis is a bit heavier but it realy stiff. so i will
try to loose the weigth i added with the chasis and other
stiffeners by going with titanium pillow balls and light weight
shafts for you guys barely making minimum weight make sure
you go a tad bit more or weight the car with used tires
so it will pass after running the mains with less tires.
last i have a scale that reads in ounces does any one have
the conversion for ounces to grams.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-08-2003, 10:43 PM   #2106
the minimum weight went up to 1725g this year.
justrc is offline   Reply With Quote
Old 02-08-2003, 11:00 PM   #2107
Manticore's Avatar
i would rather have the origional option 4mm chassis frm mugen. it has made recess to retain the CG and roll centre of the car even the chassis is 4mm thick.
Old 02-08-2003, 11:07 PM   #2108
Manticore's Avatar
Old 02-08-2003, 11:30 PM   #2109
Send a message via AIM to Bryan N.
Franchis check your PM.
Bryan N. is offline   Reply With Quote
Old 02-09-2003, 01:24 AM   #2110
kevink2's Avatar
Where'd you get that info from? My 2002 rule book which came with an addendum dated 8/2002 specified 1700. Has it changed again as of the Jan.?
Old 02-09-2003, 01:29 AM   #2111
quozl's Avatar
25 grams added to IFMAR 8th, 10th 235 and 200mm minimum weight rule to take into account the AMB personal transponders that most clubs use now.
Cheers Alastair
quozl is offline   Reply With Quote
Old 02-09-2003, 01:31 AM   #2112
kevink2's Avatar
So that's IFMAR's weight min. correct, not ROAR?
Old 02-09-2003, 02:31 AM   #2113
quozl's Avatar
That is IFMAR's min weight, correct. I'm not sure about ROAR but what usually happens with FEMCA, EFRA etc is that technical rules like weights etc are taken from the IFMAR specs so when they change the member blocs change there's as well. If you post a message in the ROAR forum on the Starting grid confrences though you'll get an answer directly from a ROAR rep as the frequent that board.
Cheers Alastair.
Old 02-09-2003, 05:18 AM   #2114
According to the new ROAR rule book (I just got the new one), minimum weight for .12 fuel touring cars is still 1700g (60oz) with the transponder.
Old 02-09-2003, 11:05 AM   #2115
28 grams per ounce
i heard something about the change in weight due to transponders
they changed the rule to add transponder in the weight so those who used personals had no advantage over those who didnt
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
