Old 10-31-2009, 01:23 PM   #17191
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by NitroHammer View Post
do you still have your mtx-3 stuff? I like the 3 much better than 4 so staying with what works for 2009/2010 season, it just is the way to go for me points don't lie!
Yes, have all that was listed plus more that I found will cleaning out the RC closet. I was going to re-list, but just had not gotten to it.
PM me.
Mark
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 03-03-2010, 11:34 AM   #17192
Carlos's Avatar
Default MTX-3 Roller
If anyone is interested I have a roller with some parts. I know this car is old but never the less it's still one bad little car.
Just look in the For Sale thread under Mugen MTX-3
Carlos Marcano a.k.a Sponge Bob
R.M.I. Racing
Xray NT-1
Spec-R R1
Carlos is offline   Reply With Quote
Old 05-24-2010, 12:04 AM   #17193
Default stripping 2nd gear mtx3
seems i have been stripping second gear cant seem to find the problem my mess is right on i use all metal gears and i even tried the new updated gears from the mtx4 do you think that the clutch is shifting to hard and slamming second gear please help
infernoman2008 is offline   Reply With Quote
Old 05-25-2010, 02:46 PM   #17194
Does anyone have the instruction manual for the MRX3 a down loadable .pdf would be nice ...
Twisted_Metal is offline   Reply With Quote
Old 05-25-2010, 05:39 PM   #17195
Seisick's Avatar
those gears are way too short for the final ratio, way high acceleration and no final speed!
mesh should be tight just with the 2nd speed spur on and almost no space between the two speed shoe and the housing,
good luck
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 05-25-2010, 06:27 PM   #17196
taco94's Avatar
Hello fellas,
I have an old MTX-3 I bought all the way in late 2003. I haven't raced the car vigorously since, but when I run it, I notice that when the brakes are applied, it is strong and you have no control. I even read an old article stating that the brakes are strong and there is a large lack of control or smoothness. I want to know if anyone else has had these problems and if this problem can be fixed, as I might be bringing it back out from a 2-year break in about 2 or 3 weeks. Thanks in advance.
Derek T.
Serpent 733 / Novarossi Keep On / Airtronics M11
Falcone Racing Products
"Always support your local hobby shop. Internet retailers do nothing to help you race." - Tom B.
taco94 is offline   Reply With Quote
Old 05-25-2010, 11:04 PM   #17197
good luck
ok what gear should i be using then , they show that you can use the new 0.8 modules for this car right now iam running at 18-24 59 -53 set up in the gearing
Old 05-26-2010, 08:06 AM   #17198
Seisick's Avatar
use 21 27, these are only aluminum but will last some time, if your track is small you can also try 16 21 47 42, these pinions will last longer but will provide less acceleration and top speed
there are lots of parts for x3 on ebay
good luck
HobbymaniA
GoT MuGeN?
Old 05-26-2010, 08:49 AM   #17199
Grenade10's Avatar
Originally Posted by taco94 View Post
Hello fellas,
If your running a one way in front, your car will not stop straight no mater what you do. If you change to a spool or gear diff, brakes are great. I've gone to 100,000 lube in the front diff which helps forward traction, just have the car pointed in the right direction when you give it power.
Old 05-26-2010, 09:06 AM   #17200
lil-bump's Avatar
Trader Rating: 83 (100%+)
The original MTX3 used 1.0 module gears the Mtx3 "pro-spec" used .8 module gears which do you have?
I agree the MTX3 can not used the Mtx4 gears they are way too short
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 05-26-2010, 03:20 PM   #17201
yes i have the 0.8 modules gears so if i use the 21 27 gears what spur gears should i run it is a large track with lots of speed and grip also i was wondering how do it get the car to be really fast like snappy
Old 07-16-2010, 11:25 AM   #17202
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Default MTX-3 parts blowout!
Was at SpeedtechRC yesterday. They found a box of old nitro parts that had been stored away. Among them were a bunch of parts for the MTX-3. Mostly gears such as spurs and pinions and some Kawahara parts as well as some plastic parts like bulkheads and suspenstion arms.
They won't be listing them on the website so you'll have to call them to find out what they have or have what you are looking for.
Call them at: 626-237-0807
YR4Dude is offline   Reply With Quote
Old 07-16-2010, 07:58 PM   #17203
SpeedTech's Avatar
Yep, this is what we got:
Mugen Seiki MTX3 pick-a-part!! $3 a part plus shipping!
Please email customersupport (at) speedtechrc (dot) com to order.
Also include your address so we can estimate shipping.
Onroad servo saver j0306 1
Clutch shoes for 3 pin flywheel c0707 2
mtx3 damper cap h0554 2
mtx3 rear brace t0130 3
mtx3 front lower arm t0136 2
mtx3 front one way drive axle t0228 1
mtx3 middle shaft t0231 1
mtx3 2 speed shaft t0232 1
mtx3 servo saver shaft t0305 1
mtx3 servo saver pipe t0306 2
mtx3 servo saver spring adjuster t0307 1
mtx3 servo saver spring t0308 1
mtx3 46T 1st gear t0222 2
mtx3 47T 1st gear t0223 2
mtx3 48T 1st gear t0224 4
mtx3 58T 1st gear t0251 1
mtx3 60T 1st gear t0253 2
mtx3 15T 1st gear t0707 4
mtx3 17T 1st gear t0709 1
mtx3 19T 2nd gear t0710 2
mtx3 21T 2nd gear t0712 2
mtx3 21T 1st gear t0715 2
mtx3 22T 1st gear t0716 4
mtx3 25T 2nd gear t0718 3
mtx3 26T 2nd gear t0719 4
mtx3 27T 2nd gear t0720 3
mtx3 28T 2nd gear t0721 3
mtx3 29T 2nd gear t0722 4
mtx3 42T 2nd gear t0225 2
mtx3 43T 2nd gear t0226 2
mtx3 44T 2nd gear t0227 3
mtx2 front upright t0112 1
mtx2 anti-roll bar t0117 1
mtx2 f/r axle shaft (for universal) t0212 1
mtx2 f/r drive shaft (for universal) t0213 2
mtx king pin d0105r 1
mtx brake disk h0356 1
mtx spring adjuster h0513 1
mtx rear spring 1.6 Purple h0527 3
mtx front spring 1.7 light blue h0524 1
mtx 12x18x4 bearings h0601 1
mtx 2nd gear housing j0217 1
mtx rear bulk head t0102 1
mtx rear upright t0113 4
mtx rear upper arm shaft t0115 1
mtx aluminum rear brace t0120 3
mtx drive shaft for f/r t0203 1
mtx middle shaft t0205 2
mtx front one way drive set t0216 1
mtx 36T front one way pulley t0217 2
mtx radio plate t0301 1
mtx 17T 1st gear d0713 2
mtx 44T 2nd gear h0227 2
mtx 45T 2nd gear h0228 3
k2x/sting king pin d0105 2
mbx5 rear lower arm support e0113 1
mrx3 servo saver shaft h0365 1
mrx servo saver spring h0367 1
mrx3 brake bracket h0173 1
mrx/ms/mt damper plastic parts h0551 2
mrx3 front damper stay h0552 1
sti 22T 2nd gear h0717 2
ava rear upright j0114 2
3Racing mtx3 graphite rear shock tower mtx3-018 1
3Racing mtx3 rear body mount mtx3-019 1
3Racing mtx3 rear suspension mount (H) mtx3-027a 3
3Racing mtx3 rear suspension mount (M) mtx3-027b 3
3Racing mtx3 rear suspension mount (L) mtx3-027C 3
3Racing mtx3 4mm graphite front shock tower mtx3-400 1
Penguin r/c mtx2 front bumper brace (g10) p6001 1
Kawahara Mugen/Kyosho/Serpent Belt tensioner A-001 1
Kawahara mtx2 19T k-712 2
Kawahara mtx2 flywheel k-722 3
Kawahara mtx2 rear lower arm R k-744 1
Kawahara mtx2 rear lower arm L k-745 1
Kawahara mtx2 rear upright brace k-748 1
Kose mtx2 19T gear k-2206 1
Kose mtx2 18T k-2205 1
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 07-19-2010, 01:34 AM   #17204
thefuzzclub's Avatar
do you ship in the Philippines?
thefuzzclub is offline   Reply With Quote
Old 08-29-2010, 05:37 PM   #17205
pipcars's Avatar
Default MTX3 Diff Part Numbers
Hi, I need to convert my MTX3 from a front one way to a gear diff, Can anyone help with part numbers as I've misslaid my manual.
Cheers Paul.
pipcars is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
