Old 07-31-2008, 12:05 AM   #17131
vazzo's Avatar
Trader Rating: 100 (100%+)
Hi Guys
Is there another company that make the gears for the MTX3? More so the pinions, I heard that Kyosho have steel ones available which pretty well last forever, that would be great. The other question is can you run the MTX4 gears on the MTX3?
Cheers
Adrian
Gone riding, cya.........
vazzo is offline   Reply With Quote
Old 07-31-2008, 09:49 AM   #17132
almtx3's Avatar
Hey vazzo, there are still plenty of pinion gears available on ebay. Here is a link to a store that has a few and they ship outside the U.S.
http://cgi.ebay.com/MUGT0714-Mugen-M...2em118Q2el1247
I still have the stock pinion gears that came with the kit and they are in pretty good shape. Ive had to replace a few spur gears but those are still easy to find here in the states.
As far as running the MTX4 gears Ive heard you can do it. Ive heard you can swap out the entire clutch kit from an MTX4 and install it to whatever engine your running on your MTX3. Your obviously going to have get the correct spur gears to match the new pinion gear size. The gearing on the MTX4 is a bit different than the stock gearing on the MTX3. I recently installed a new engine in my MTX3 and I was thinking about doing that swap but I never went through with it. I figured if the clutch Im running now ever gives out I will go for it.
By the way, my MTX3 is running great with that new O.S. 12TZ! I just finished breaking it in last week at the track and I'm really looking forward to fine tuning it and running it all out in a few weeks.
almtx3 is offline   Reply With Quote
Old 07-31-2008, 04:00 PM   #17133
JLock's Avatar
Originally Posted by vazzo View Post
Hi Guys
Cheers
Adrian
The 0.8 pitch spur gears for the MTX3 and MTX4 are the same and you can buy those through Mugen Seiki, Nitrohouse, RC-Toro, RC-Mushroom, and several other websites. However, the 0.8 and 1.0 clutchbell spur gears for the MTX3 are becoming harder to come by. Like almtx3 said, keep your eyes on Ebay, for sale portions of chat forums like this, Mugen Seiki, and overseas websites like RC-Toro and RC-Mushroom (both tied to Hong Kong shops/distributors). Integy may still have some (and other MTX3) parts availabe through their website. Hope this information helps.
JLock is offline   Reply With Quote
Old 08-04-2008, 12:00 AM   #17134
does any one know where i can get a new clutch assy i need the whole thing no one seems to have it all i see is one for the mtx4 please help pm me ith any answers
infernoman2008 is offline   Reply With Quote
Old 08-04-2008, 11:45 AM   #17135
asw7576's Avatar
You can use mtx4 parts for centax clutch shoes and 2speed clutch shoes. Bring your old parts to your LHS for direct comparison.
The difference between 3 and 4 occur in centax clutch assembly : flywheel, centax locknut, clutchbell.
Old 08-04-2008, 12:43 PM   #17136
Default Clutch Parts
I know I have a few different Items and I no longer have a MTX3, email me directly at [email protected] and lets see what I can do to help you out.
Jaime
jaimepn is offline   Reply With Quote
Old 08-04-2008, 11:06 PM   #17137
looking for a new mtx3 clutch assy need all new parts
Old 08-13-2008, 12:58 AM   #17138
JVT MTX3's Avatar
How much are used MTX-3 going for now-a-days? In excellent condition and RTR.
JVT MTX3 is offline   Reply With Quote
Old 08-14-2008, 06:10 PM   #17139
look for pinion gears 22 first gear and 28 second gears does any one know about any updated parts numbers
Old 08-15-2008, 08:58 AM   #17140
spenzalii's Avatar
Send a message via AIM to spenzalii
You may want to try Nitrohouse. They should still have some of teh MTX-3 parts in stock:
http://www.nitrohouse.com/options,_mtx-3.htm
As mentioned though, moving to the 0.8 gears the MTX4 and MTX3 Prospec used. those gears are much easier to find, and you should be able to duplicate the gear ratio (or find one slightly better) with the new gears. They sell the complete clutch; my LHS has one in stock. I can get the part number next time I head up there.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 08-19-2008, 07:12 PM   #17141
JVT MTX3's Avatar
I can't get my nephew's MTX3 to start. When I set the car on starter box I can hear the motor fire up but not enough to stay on.
Anytech advice is much appreciated.
Old 08-19-2008, 07:33 PM   #17142
BLKNOTCH's Avatar
Send a message via MSN to BLKNOTCH
You may want to start by setting the carb back to the base settings, then replace the glow plug with a fresh one and be sure you glow igniter is fully charged. Also be sure the fuel line is clear of any blockage and that it is full of fuel. When first starting put your finger over the exhaust to feed fuel to the carb (just a sec on the starter box) then when you start with the igniter you should have no issues.
Good luck
Sean
BLKNOTCH is offline   Reply With Quote
Old 08-21-2008, 10:10 AM   #17143
JVT MTX3's Avatar
Good luck
Sean
Thanks Sean!! I'll let you know tomorrow if I'm able to start the engine.
Old 10-13-2008, 08:36 AM   #17144
almtx3's Avatar
Hey guys I cant find a front upright for my MTX3 online anywhere (Part Number T0164R). Broke mine yesterday at the track and need a replacement.
I found this part number MUGT0138-B claiming to be a new version upright that will fit both the MTX3 and the MTX4? Just wanted to make sure this part would fit and if anyone has installed this part number on their MTX3 and had any problems.
Old 10-13-2008, 09:05 AM   #17145
Grenade10's Avatar
Trader Rating: 37 (100%+)
I'm not sure if they will work, but I know I have atleast one spare that I could get to you.
PM me your contact info and I'll get back to you this evening.
Also, to all who are still running the MTX-3, I have decided to move on to other things, so I will be selling off my stash of parts, cars and motors. If you need something, let me know. Price will be right for the RcTech Family.
Send me you want list prior to putting them in the "For Sale" Thread and then off to E-bay.
Mark
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
