Mugen MTX-3
Old 05-15-2008, 06:52 PM
  #17101
G87z's Avatar
Originally Posted by Tire Chunker View Post
That is some good reading. I think I will stick with the oneway. I am used to it. And who uses the brakes anyway. I just slightly tap them to slow the car.
G87z is offline
Old 05-16-2008, 10:08 AM
  #17102
Seisick's Avatar
Default do
Originally Posted by G87z View Post
Hey guys, It seems alot of you running the MTX-3 are looking to run a spool or a front Diff instead of the front one way. Could someone please explain the pros and cons of doing this? I have always run a front one way.
you can download the nt1 setup book, lots ot infos on setup including spool one way and diffs
Seisick is offline
Old 05-19-2008, 02:12 PM
  #17103
vazzo's Avatar
Trader Rating: 100 (100%+)
Hi Guys
Just wondering what the smallest pinion gears are available for the MTX3? If there are any smaller than a 20 that fot where do you buy them from.
Cheers
Adrian
vazzo is offline
Old 05-19-2008, 02:58 PM
  #17104
G87z's Avatar
Originally Posted by vazzo View Post
Hi Guys
Cheers
Adrian
15 and 19 for the standard pitch that came with the car. I am not sure of the new style pitch that the MTX-4 and 4R use. The pinions are found pretty much anywhere. Check www.amainhobbies.com or on Ebay. Ebay has a TON of mtx3 parts. They are also decently priced.
G87z is offline
Old 05-21-2008, 05:35 AM
  #17105
touringdriver's Avatar
Trader Rating: 16 (100%+)
looking for a good starting point in gearing my mtx3. my track is about 100x60. it's a fairly tight track. we use the pro rail track. i use a o.s. .12 tz 5 port engine. just got the nitro sedan fever. but not familiar with the 2 speed gearing. we normally keep one straight away open for speeders. thanks for any tips.
touringdriver is offline
Old 05-21-2008, 08:45 AM
  #17106
asw7576's Avatar
here..... mtx3 gear ratio chart.
I suggest 20T/25T pinion gears with standard 59T/53T spur gears.
asw7576 is offline
Old 05-23-2008, 03:38 PM
  #17107
ROBBIE C's Avatar
Mugen message board is now on and live as of 5/23 2008
www.mugenracing.com click on message board create an account and start posting just that easy.
Hopefully this will help people with questions in-regards to setup tips and other frequently asked questions.
ROBBIE C is offline
Old 05-30-2008, 07:25 PM
  #17108
does anyone know of a lipo battery that will fit in the mtx3?
Old 06-01-2008, 09:17 PM
  #17109
Grenade10's Avatar
Trader Rating: 38 (100%+)
Back a few posts, someone sugested to use 100,000 lube in the front gear diff. Well I pulled the oneway and made the change, and boy did this really work!
Question if anyone has run this, what lube did you use in the rear? Any other settings with this diff?
I'd have to say, I really like being able to use the breaks even if it is just to stop in the pits, but boy does it pull out of a corner!!
Grenade10 is offline
Old 06-02-2008, 12:48 AM
  #17110
stefan's Avatar
I always ran 100K front and 50K rear in my MTX3 and it worked great.
stefan is offline
Old 06-02-2008, 03:55 AM
  #17111
G87z's Avatar
Alright thats what I like to hear. so 30k rear and 50k front is a good starting point.
G87z is offline
Old 06-26-2008, 01:12 PM
  #17112
almtx3's Avatar
Was looking for some parts on ebay and and ran in to this. Thought it was a good deal but I have most of those parts, so Im not getting in on it. I don't know the seller or have anything to do with the auction, I just thought some of you guys might be interested. Auction ends in a day or so. Ebay Item number: 200234297614.
almtx3 is offline
Old 06-27-2008, 08:42 AM
  #17113
HulkNT1's Avatar
hey Alm you are all over this forum today wow..
HulkNT1 is offline
Old 06-27-2008, 08:44 AM
  #17114
almtx3's Avatar
just trying to help out
almtx3 is offline
Old 06-28-2008, 09:26 PM
  #17115
asw7576's Avatar
Who still has MTX3 ?
Do you still race it ?
asw7576 is offline
