Old 02-26-2008, 11:39 PM   #16996
asw7576's Avatar
Originally Posted by kidsid99 View Post
Can anyone tell me how much length difference there is between the front and rear universals for the MTX3?
Thanks for any help available.
Sorry, I don't know the exact numbers.
Just make sure the longer universals go to front, and the shorter go to rear.
Old 02-27-2008, 08:15 AM   #16997
almtx3's Avatar
Finally got the car out to the track this past Saturday and it ran great. I was happy with the car but my driving was another story. It was tough out there and I was all over the place the first few laps. Got the jitters out and I was finally able to get around the track without hitting the boards. I immediately noticed I wasn't shifting into second gear but after a quick inspection I realized my 2 speed clutch shoe was totally worn out. Got a new one on order. Kept running the rest of the day with only first gear and the car was doing great around the turns and handling was on point. Couldn't really open the engine up down the strait but had a lot of fun anyways. Cant wait to get back out in a few weeks after the repairs. Overall the car performed well for its age and with some more fine tuning I think it will be ready for an upcoming club race.
almtx3 is offline   Reply With Quote
Old 02-27-2008, 08:57 AM   #16998
asw7576's Avatar
You bought another MTX3 brand new ?
Old 02-27-2008, 09:29 AM   #16999
almtx3's Avatar
Nah, just more spare parts... One MTX3 is enough for me. Got a new baby at home so cant upgrade to a new MTX4 yet. Need the $$ for pampers and formula! Once hes old enough he will inherit the MTX3 and I will be forced to upgrade!
Old 02-28-2008, 01:57 AM   #17000
ViperSkull's Avatar
Hey guys, my dad is running an MTX-3 with a pull start engine and he's having problems with the car pushing the front so he's not getting any traction. also he's under steering a lot. We run on a Tight track with medium grip and medium surface.
His setup is
Front Differential: 50,000 weight oil
Front shocks: blue springs, 35 weight shock oil
A Ackerman
Caster clip things put all to the front
Rear Differential: 30,000 weight oil
Rear shocks: purple springs, 35 weight shock oil
Roll center block A
Front camber: 1 degree in
Front Toe: 1 degree out
Rear camber: left 2.5 right 2.0
Rear toe: 3 degree in
I also forgot to mention that he is running a 4mm chassis, and we do run on a tight track so i think we find the 4mm too stiff, maybe thats part of the under steering issue.
any help will be appreciated
cheers,
Tim
BRCCC Wynnum
Mugen MTX4-R/Novarossi Max Power/Mugen Pipe/Futaba 3PK/Spektrum HRS System
*For Sale, CT4S with a heap of parts*
Last edited by ViperSkull; 02-28-2008 at 01:59 AM. Reason: forgot to add something
ViperSkull is offline   Reply With Quote
Old 02-28-2008, 06:11 AM   #17001
ira
ira's Avatar
Trader Rating: 18 (100%+)
How small is the track?
Use the purple sprins on the front of the car, and the light blue on the rear.
I ran the MTX3 on parking lot tracks and on perm. tracks. Use the stock setup on the car, you might want to us a lighter front diff oil (30,000).
If the car wants to under steer on power, limit the front droop
RC AMERICA, XRAY, FUTABA, O.S. ENGINES, BYRON FUELS, SPEEDWORLD RACEWAY, HOBBICO, MATRIX TIRES...
ira is offline   Reply With Quote
Old 02-28-2008, 10:07 AM   #17002
asw7576's Avatar
Congratulation on your new born son
Don't spend too much on rc stuffs ( waste of money ).
BTW, I went to florida last year. I stay at fountainbleau.
Old 02-28-2008, 10:31 AM   #17003
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
His setup is
A Ackerman
Roll center block A
cheers,
Tim
What type of tires rubber/foam shore rating ect........your set up looks good could just be to hard of a shore upfront.
Also check your front sway bar setting, for a small track make sure it is horizontal more steering and not perpendicular less steering.
I have two MTX-3 prospec a small track and a large track version both with the 4mm chassis the only difference in the cars are diff/one-way, softer vs. harder springs. I run foams and tune to the track some times 40/40 40/38 ect.........
Tire Chunker is offline   Reply With Quote
Old 02-28-2008, 05:54 PM   #17004
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
also i would chang the rear blocks with a parking lot you don't want A's go with B or C. once you get the car better if you are loose on power with low traction go C in the front of the rear hing pins and B rear
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-28-2008, 09:51 PM   #17005
ViperSkull's Avatar
http://www.wynnumrc.com/10022008/index.html
Look through those images, this is the track we race on.
We run 40 shore foams front and rear. No stabilizer bars as it makes the car too stiff for this track.
BRCCC Wynnum
Old 02-29-2008, 06:04 AM   #17006
ira
ira's Avatar
Where is this track located?
What City and State?
Old 02-29-2008, 06:09 AM   #17007
ira
ira's Avatar
Also try standing the front and rear more up right. You can use a softer front tire, I will post a setup I used on my MTX3 that works realy well. I ran on a track very similar.
Old 02-29-2008, 08:01 AM   #17008
almtx3's Avatar
Thanks asw7576! Ill try not too!
PM sent.
Old 03-03-2008, 05:36 PM   #17009
20 SMOKE's Avatar
i got to run my car yesterday after allmost 3 years, man do i miss it
Jamie W
Old 03-03-2008, 05:37 PM   #17010
tony montana's Avatar
Trader Rating: 66 (100%+)
the mtx3 is still a good car, I dont care what anyone says
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
