Old 09-04-2006, 05:52 PM   #16771
hey guys looking for some help here. i put together my mtx-3 the other night and havnt gotten a chance to run it yet. and i might this weekend. so i just plan on tweaking the suspention and all the stuff. but it seems a little hard to adjust the camber and all of that. i was just wondering how all of you guys adjust it since there is only a hole there and i dont really have anything that small enough that i can jsut keep spining it to adjust it. and i was wondering if some one could give me a basic set up to use. i have had an R40 for a few years now and i was just going to use kinda the same set up with -2 rear and -1 front camber....1 degree toe in rear and 0 front with a ride height of 6mm. any help would be great.
thisisagame24 is offline   Reply With Quote
Old 09-04-2006, 07:16 PM   #16772
devious17's Avatar
I use a 0.5mm allen wrench, it is small enough and it's an L shape whichI can use to turn the camber rod. As for the setup, go to mugen's site and you would find several setup sheet for you to choose from.
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 09-04-2006, 07:49 PM   #16773
Default Front Universal
Guys,
Does the MTX-3 come with a Front Universal or just One-Way? And if it does where can I get the front universal from, thanks.
BeBop is offline   Reply With Quote
Old 09-04-2006, 07:59 PM   #16774
the kit comes with a one way. but i saw some where that is possible to turn it in to a spool which i still cant find out how to do....any one know how i can do that becuase i really dont like one ways
Old 09-04-2006, 08:30 PM   #16775
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
You can't turn the front one way into a spool. You can build a locked diff for the car if you want to.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 09-04-2006, 08:34 PM   #16776
ViperSkull's Avatar
hey guys, i was just wondering if you know where i can get the manual for the MTX-3 from the net.
BRCCC Wynnum
Mugen MTX4-R/Novarossi Max Power/Mugen Pipe/Futaba 3PK/Spektrum HRS System
*For Sale, CT4S with a heap of parts*
ViperSkull is offline   Reply With Quote
Old 09-04-2006, 08:37 PM   #16777
ViperSkull's Avatar
Nevermind. Found it
BRCCC Wynnum
Old 09-04-2006, 09:57 PM   #16778
hav_lova's Avatar
There is a way to turn the oneway into a spool it has todo with getting rid on the one way bearing putt a solid peice of metal in and making a hole and putting a grub screw in.
Just playing with bigger toys now...
serpentrc.com.au
hav_lova is offline   Reply With Quote
Old 09-04-2006, 10:25 PM   #16779
I guess I should have said there is no easy way. Some aftermarket one ways have a hole you can add pin to lock it.
Old 09-05-2006, 01:04 AM   #16780
asw7576's Avatar
I have never had to replace the center adapter. I don't do it the way ASW describes. I use the stock parts and just tighten the set screw that pushes down on the balls until the two speed shoes separate from each other. Run some gap between the shoes. Test fit the shoes on the 2nd gear hub and make sure it doesn't rub. If you separate the shoes this way you will not have to replace your center adapter.
I never change the center adaptor either. The rest is like yours : "tighten the set screw that pushes down on the balls until the two speed shoes separate from each other. Run some gap between the shoes. Test fit the shoes on the 2nd gear hub and make sure it doesn't rub".
Old 09-05-2006, 05:15 AM   #16781
Trader Rating: 15 (100%+)
Originally Posted by BeBop
Guys,
I think that you mean a front diff not a universal right? The car comes with a front one way but you can buy a front diff for the car. ashfordhobbies.com usually has the housing then you just need the gears and outdrive stuff that is in the rear diff.
You can also get front and rear CVD's for the car. Hope this is what you were looking for.
THE DOCTOR is offline   Reply With Quote
Old 09-05-2006, 05:26 AM   #16782
hav_lova's Avatar
hey guys i'm looking for a little bit more snappiness out of my clutch down low on launch. It's not so much a concern when i use my modded TZ as the thing has so much power i don't need such a snappy clutch response but when im using my RB i really want to get all the punch i can get.
I'm using the stock spring and stock shoe. And i have a gap of .31mm or so when i move it backwards & forwards. What would be the easiest way of getting more punch i killed two thrust bearings before i really got a good clutch setup now im wondering if i open the gap to .50 mm will the thrust bearing have a shorter life? I'm not a fan of having to consider thrust bearings perishables.
serpentrc.com.au
Old 09-05-2006, 05:32 AM   #16783
RR
RR's Avatar
Send a message via AIM to RR
Originally Posted by asw7576
I win almost all my races in 2006 with 1 clutch shoe. It's up to you. I already share my secret.
wow
you win alot of races...
hmm... then i should get tips from you ...
thanks in advance first
RR is offline   Reply With Quote
Old 09-05-2006, 10:29 PM   #16784
Default MTX-3 and 4 Parts
Guys,
Are the parts for the MTX-4 can be used on the MTX-3 and vice versa?
Old 09-06-2006, 12:10 AM   #16785
devious17's Avatar
Some parts are compatible most aren't.
Audio,Video, Disco
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
