Old 08-22-2006, 08:24 AM   #16726
Default somethings is not right!! need help plz
hi i have only had my car for a month and am a newbie to nitro rc.
the car is 2nd hand and has been fine apart from a few knocks and a broken rear arm.
i was at the track the other day and 1 of the guys who knows a bit about the cars was having a quick look over it for me.he said it all looked good but my gears had to much of a gap between them and the gogs from the engine.
we went to undo the engine mount screws to adjust thepostion and 1 of the screws was stripped. i got it out but the thread in the eninge mount was gone ,so i had to buy a new 1.
so all good changed the engine mount and but engine back in making sure the gears and gog was togehter and had no gap. when i took the engine out i only undone the mount,nothing else not even the throttle control(was able to do it without taking anything off and just thought it would be easyer to put back)
went down to the track and started her up and it sounded a bit diff than normal(bit more high pitched)
went to drive and had to rev a lot higher than normal to get clutch engaged.
humm
so i went round a few times and it seemed ok so i thought i would open her up.
some thing very odd is going on with the gears /clutch. sometimes it wont change,other times it seems its stuck in second and it also when it gets to the point when it should change sometimes its sound gose right down to a low pitch growl or gurgle and seems to lose a lot of power,which i guess is not good cause it never sounded like that before.i have been running this car for at least 10 hours prob free and cant think wat this is.
i did not touch the hsl or anything else so i dont see why the tuning can have changed.
thanks for taking the time to read this and thanks for any replys.
if you got any ideas wat the prob could be or wat to look at that would be great.
have i lost my tuning? is the gear and gogs to close now?(they are near enough touching where i had about a 1 mm gap before)
dick dastardly is offline   Reply With Quote
Old 08-22-2006, 11:50 PM   #16727
asw7576's Avatar
humm
You need expert to accompany you setting the car.
3 things to check:
1. Engine HSN and LSN
2. Centax Clutch Spring tension. Should be 0.6mm to 0.8mm at the spring locknut, and 0.2mm at the end of thrust bearing.
3. 2 speed clutch shoe. Buy a new set and set it right. I prefer to use MTX4 2 speed clutch with longer M3 screw ( M3x10 ) and toss the ball out.
Old 08-23-2006, 05:52 AM   #16728
3 things to check:
Thanks for the advice asw7576, iam gonna try to goto the track this weekend and hope some1 is there that can help me.
so you dont think it is anything to do with the gears and gogs being too close ???
i read somewhere there should be a slight gap or they bind(watever that means)
whats the best way to line these up????
cheers again
Old 08-23-2006, 07:09 AM   #16729
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Hey guys, how much longer till you think part for the MTX3 will be rare? I'm trying to find a car for a friend and spotted one with engine and pipe (and parts) for $250. Think it's worth a shot?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 08-23-2006, 07:36 AM   #16730
I sent you a PM on a new one I have with tons of spares.
James
22dasher is offline   Reply With Quote
Old 08-23-2006, 07:48 AM   #16731
Corse-R's Avatar
Make to your friend a favor... convince it to get a MTX4, MTX3 was in fact good, but their 'worst defect' was a large tunning window that maked it somewhat irresponsive to small tunning changes.
The 4 is faster and responds better to small changes. If your friend in fact still wants a '3' maybe he has spare parts for another year or 1.5 years, but... better to go the '4' route.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 08-23-2006, 06:34 PM   #16732
HarKonnenD's Avatar
22dasher- Sry, no thanks.
Corse-R- Makes sense. I'll do just that.
Old 08-23-2006, 11:29 PM   #16733
asw7576's Avatar
I suggest don't. I recently bought use MRX3 and regret it. The cost of renovation is close to brand new MRX4-R.
Buy new car and enjoy it. Nothing compare to new car.
Old 08-23-2006, 11:33 PM   #16734
asw7576's Avatar
cheers again
Try to spin the gears. If they can spin at least 1 second, you are good to go.
Old 08-25-2006, 01:26 AM   #16735
bjc
Default Front Diff Oil for MTX-3
Ok, quick question again fellas.
I read that some people recommended 100k oil in the front diff and I use 10k in the rear.
Our track is carpark and slippery most of the time, its not real long and there is a few s bends where braking is prefered thats why I want to change from the one way.
Any feedback for oil thickness would be appreciated.
Cheers,
Brett
bjc is offline   Reply With Quote
Old 08-28-2006, 07:12 AM   #16736
Eric Gebhard's Avatar
I am looking for the parts that I need to get to setup a front diff. I donít have a manual and I canít down load it for the Mugen web site. Does anyone has a downloaded copy of the manual that they could e-mail? Any help would be appreciated.
Eric
Eric Gebhard is offline   Reply With Quote
Old 08-28-2006, 07:22 AM   #16737
Trader Rating: 15 (100%+)
Cheers,
Brett
I ran 50K in my front diff. If I was really loose I would use 15K in the rear but most of the time I ran 30K in the rear.
I only ran A front diff when I ran a spec class when everyone had to run with rubber tires.
THE DOCTOR is offline   Reply With Quote
Old 08-28-2006, 07:30 AM   #16738
My local track is really small (115í X 50í) so there is no way we can run a one-way on it so I need to setup the front diff.
Old 08-28-2006, 05:58 PM   #16739
quietstorm76's Avatar
hey guys I keep stripping gears on my MTX3. I don't know much about the car and was wondering is this a common problem?
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-29-2006, 08:47 PM   #16740
TonysScrews's Avatar
Eric
Hi Eric,
Here ya go MTX3 Manual
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
