Mugen MTX-3
Old 06-08-2006, 12:23 AM
  #16636
Trader Rating: 28 (100%+)
Originally Posted by asw7576
Chris, can I use MTX3 flywheel for MTX4 ?
Yes...
Scott Fisher is offline
Old 06-08-2006, 01:52 AM
  #16637
Chris West's Avatar
Chris West is offline
Old 06-08-2006, 04:58 AM
  #16638
asw7576's Avatar
Originally Posted by Scott Fisher
Yes...
Scott & Chris :
Thank you.
asw7576 is offline
Old 07-01-2006, 09:31 AM
  #16639
Default mtx-3 front springs
Can someone tell me why the front springs are shorter than the rear springs? If the shocks are all the same length. Is it an attempt to lower the front roll center?
Elliott hart is offline
Old 07-01-2006, 09:43 AM
  #16640
Riketsu's Avatar
Trader Rating: 33 (100%+)
Its because front springs are harder (i think) than rear springs, even if they are the same color.
Riketsu is offline
Old 07-01-2006, 02:23 PM
  #16641
I have to do more research. I would think the spring rate would be the same no matter how long the springs are. It just seems odd that the front springs coller has to be almost at the bottom of the shock to keep a certain ride height when your using lower than average tires.
Old 07-02-2006, 05:09 PM
  #16642
I think I figured it out. Mugen changes spring length based on spring rate. if you look at all the different color springs they are different lengths. I guess it is way of changing spring rate by changing the number of coils per inch/mm.
Anyone have any other ideas?
Old 07-02-2006, 07:51 PM
  #16643
mistercrash's Avatar
It's been my understanding that the front Mugen springs have less coils than the rears to make them a little stiffer.
mistercrash is offline
Old 07-04-2006, 04:42 PM
  #16644
Nosram's Avatar
Default Diff Oil
I am rebuilding my MTX-3, what viscosity diff oil should I use? I guess it depends on the track conditions, but I could do with a starting place, please
Nosram is offline
Old 07-04-2006, 08:15 PM
  #16645
Chris West's Avatar
Mugen 30 000 in the rear and fill to the top of the 2 spider gear shafts
Old 07-05-2006, 07:25 AM
  #16646
Nosram's Avatar
Default Gearbox oil
Thank you very much
Nosram is offline
Old 07-06-2006, 02:16 PM
  #16647
The Fog's Avatar
Assisitance please on the ABCs of the Ackerman blocks. I know theory til it comes out my ears. Just wondering if anyone has first hand knowledge in this dept. I've not tried yet being new to the car. I've got to the point of trying to find more high speed turn in, having done the rest of the tricks with camber, caster, tyres etc and come back to the ABC blocks. I have A right now and reckon there might be too much ackermanization happening (meaning the inside wheel is turning in more than needed) showing as inside tyre showing a feathered inside edge.
Waddaya know out there ??
Jacko
The Fog is offline
Old 07-06-2006, 07:05 PM
  #16648
Chris West's Avatar
doesnt the feathered edge come from the amount of caster??
Old 07-07-2006, 05:01 AM
  #16649
asw7576's Avatar
Jacko
A = less ackerman = more agressive steering = good for tight corners or technical track
B = neutral
C= more ackerman = less agressive = good for wide open corners and sweepers.
Sorry If I'm wrong, but I'm quite sure is correct.
asw7576 is offline
Old 07-07-2006, 10:17 PM
  #16650
::TEAM SRGS::'s Avatar
Post 19/16 pulley conversion belt
Where can you get this belt from.
Thanks Ross
::TEAM SRGS:: is offline
