Mugen MTX-3
Old 05-28-2006, 05:03 PM
  #16621
KAHUNA's Avatar
Cool SURGE POWER !
Question , will the mtx4 front universals fit / work on the mtx3
Thx.....
KAHUNA is offline
Old 05-28-2006, 06:41 PM
  #16622
B&B Racing's Avatar
Will the MTX-4 clutch bell work on the MTX-3?
Aaron
B&B Racing is offline
Old 05-28-2006, 07:21 PM
  #16623
Trader Rating: 28 (100%+)
Thx.....
Yes, but I would use the rear MTX3 universals on the front of the MTX4.
Scott Fisher is offline
Old 05-28-2006, 07:23 PM
  #16624
Aaron
It will fit, but your gearing will be way off as they can't use the same size pinions. They also use different bearings and one other piece is different. Like I said, if you use all the MTX4 parts (the flywheel, and clutch stuff is the same) it will fit, but your car will be way undergeared.
Old 05-28-2006, 07:30 PM
  #16625
Jammin'Trey's Avatar
Hey, I remember reading on a different top plate some guy made to reposition the servo/gast tank in the MTX-3.... is he making them for others too? Or is it not worth it so he didn't...
Jammin'Trey is offline
Old 05-30-2006, 03:30 AM
  #16626
Stusdal's Avatar
Raced the car for the first time this weekend. Dident get any time to practice(rained). Raced a old Sirio(older than evo 2).
The parts supply for mugen in Norway is crapy so i had to raced two left uprights, thus right turns were hard to get right.
But there is potetntials here. Finiehed second, and there were rrr's in the race
Will put the bibel asside to night and start reading these pages instead
Stusdal is offline
Old 05-30-2006, 03:40 AM
  #16627
itchy b's Avatar
i have a 3 piece vented mtx3 disk in the mtx4 i just got and was just wondering if the 2 outer disks are made of steel or aluminium?
can i use a metalic berake pad like app's on kyoshos with this vented disk?
itchy b is offline
Old 05-30-2006, 01:27 PM
  #16628
axle182's Avatar
Trader Rating: 18 (100%+)
does anyone know the lb/in ratings for the grey and the dk blue Mugen springs?
axle182 is offline
Old 06-06-2006, 02:25 PM
  #16629
B&B Racing's Avatar
Will the MTX-3 Prospec clutch set work on the regular MTX-3?
Aaron
  #16630
B&B Racing's Avatar
woops double post.
Old 06-06-2006, 02:51 PM
  #16631
Chris West's Avatar
yes it will
Chris West is offline
Old 06-06-2006, 10:56 PM
  #16632
rcabj's Avatar
hi..i'm still suffering the lack of "punch" in the starting...after changin the clutch shoes the difference is to little to notice...after doing checking to all dept i am suspecting the clutch bell ( a fren of mine had the same problem,after changin the clutch bell it was back to normal ) it seems the place in the bell where the bearing sits in has "worn out" which means a little free play/gap from its original condition...
has anyone encountered such exp., thanks .. i'll be trying my fren clutch bell first to see if it really works...
rcabj is offline
Old 06-07-2006, 12:32 PM
  #16633
asw7576's Avatar
It's either the clutch shoe is still new and need sometime to match the contour of the bell, OR inside surface of the bell is glazed, OR you need to reduce the front shims ( too many will bog down the engine. Assuming you have set the clutch spring correctly ). OR, you could change to yellow clutch shoe for more punch.
asw7576 is offline
Old 06-07-2006, 12:36 PM
  #16634
asw7576's Avatar
Originally Posted by Chris West
yes it will
Chris, can I use MTX3 flywheel for MTX4 ?
asw7576 is offline
Old 06-07-2006, 11:35 PM
  #16635
rcabj's Avatar
hey thanks for the info...
rcabj is offline
