Old 04-30-2006, 03:13 PM   #16576
onnetz's Avatar
Default spur gears
are the .8 spur gears the same for the mtx-3 as the mtx-4?
onnetz is offline   Reply With Quote
Old 04-30-2006, 03:18 PM   #16577
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
spurs, yes. pinions, no.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 04-30-2006, 03:24 PM   #16578
onnetz's Avatar
thanks.... one more question..
do you have to keep the same spread between first and second on the pinions and spures?
Old 04-30-2006, 03:29 PM   #16579
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Yes, sometimes you can get away with 1 tooth, but I recommend keeping the same split.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 04-30-2006, 03:58 PM   #16580
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I used to think and say that as well. I learned something at this last race. The first gear spurs are the same size. Same with the second gear spurs. Measure them. There is a very slight difference in manufacturing from gear to gear, but other than that, they are the same size.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-30-2006, 04:27 PM   #16581
onnetz's Avatar
I was hoping someone would say that..
its the same way on the r40..
but like everything else, there is a limit to what you can get away with.
is there a chart showing stock pinions compared to the .8's?
Old 04-30-2006, 05:00 PM   #16582
I am not sure what you mean by a chart showing stock pinions vs. the .8's. You have to use .8 spurs with .8 pinions.
Old 04-30-2006, 05:26 PM   #16583
onnetz's Avatar
am I wrong in thinking that the stock pinions are not .8?
looking for pinions I've come across the "stock" pinions, the .8 pinions and what some places referr to as the "fine" tooth pinions.. I'm thinking the "fine" pinions are the .8's....
Old 04-30-2006, 05:29 PM   #16584
The stock MTX3 pinions/gears (they come with the kit) are not .8 pinions. The MTX3 prospec kit comes stock with .8 pinions/spurs.
The MTX4 also comes with .8 pinions/spurs.
Old 04-30-2006, 05:33 PM   #16585
onnetz's Avatar
ok... thats what I thought...
what I meant by chart is there somthing comparing a stock size pinion to a .8 pinion...?
a stock 20 isnt going to be the same as a .8 20....
Old 04-30-2006, 06:26 PM   #16586
The diameter isn't going to be the same, but if you were using a 20t normal pinion and a 60t normal spur the gear ratio is the same as if you are using a 20t .8 pinion with a 60t .8 spur.
What happens is when changing from the old setup to the .8 setup is you will be running more teeth on the .8 stuff. You will use more teeth on the pinion and the spur.
Old 04-30-2006, 06:46 PM   #16587
onnetz's Avatar
that makes sense.. thanks...
Old 04-30-2006, 11:56 PM   #16588
asw7576's Avatar
Yes, stock gearing for mtx3 prospec :
pinions: 21/27 ( 6 tooth difference )
spurs: 53/59 ( 6 tooth difference )
In my car, I replace the pinions with 22/29 ( 7 tooth , but it's okay.... race tested ). However, it would be peace of mind if I could get 22/28 pinion gears as grandgixxer said.
Old 05-01-2006, 12:22 AM   #16589
onnetz's Avatar
I ended up going with a 4 tooth split..
21/25
54/58
I will end up buying more, but these pinions are spendy...
anyone running the white springs?
I got used to driving an almost twitchy car and the mtx-3 feels too planted in the rear and not enough steering...
Old 05-01-2006, 01:01 AM   #16590
asw7576's Avatar
21/25
54/58
Mugen white springs ? Isn't that too stiff ?
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
