Old 03-30-2006, 04:08 PM   #16456
Big KAT's Avatar
Originally Posted by Scott Fisher
My MTX3 came with a 23t front pulley. I liked the car better using that pulley than the 16/19 converison.
Scott could you give me the part# for the 23t pulley?
With this pulley how much different is your front tire diameter to the rears? Thanks
Xray
Big KAT is offline   Reply With Quote
Old 03-30-2006, 09:04 PM   #16457
huskerfreak's Avatar
Originally Posted by asw7576
Anybody have experience with 23t front side pulley ( instead of original 24t ) ??
I want to minimize rear tyres' wear rate. I'm still using stock pulley setup with 3mm split. I feel the car is becoming harder to drive especially almost the end of race. Would 23t pulley help ?
I cannot use 16/19 coversation..... no short belts in my LHS.
I really appreciate your inputs for 23t pulley ... thanks .
If you still would like to have the 16/19 setup a Traxxas Nitro 4 tec belt is the right size for the coversion. The belt may be a little stiffer but it is the same size. Just so you know.
I know putting Traxxas parts on a mugen is like buying a Kraco radio for a Vette.
huskerfreak is offline   Reply With Quote
Old 03-31-2006, 02:05 AM   #16458
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I was incorrect. My MTX 3 had a 24t pulley. I know Mugen has made some 23t pulleys as the first batch of the MTX4's had 23t pulleys. (My kit came with both 23 and 24 tooth pulleys). If you contact Mugen directly, you should be able to find one.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-31-2006, 01:13 PM   #16459
onnetz's Avatar
Default brakes
I've tore it down a couple times and can't get the brakes not to drag..
is there somthing I'm missing maybe?
it seems like the disc is too wide..
onnetz is offline   Reply With Quote
Old 03-31-2006, 04:08 PM   #16460
I dremel the brake pads and plate so, the disk would roll freely. Try that one.
trebronpay is offline   Reply With Quote
Old 03-31-2006, 04:16 PM   #16461
onnetz's Avatar
I know that will work, but want to make sure that something else is not wrong..
Old 03-31-2006, 04:22 PM   #16462
The other thing I noticed on my friends car is the disc. It won't move freely left and right. I have to make a bigger hole.
Old 03-31-2006, 04:30 PM   #16463
onnetz's Avatar
that actually may be the majority of the problem.. so if the disc is at an angle then it doesnt align itself straight...
Old 03-31-2006, 04:43 PM   #16464
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
I used some 80 grit sandpaper and just sanded the pads down until they didn't drag on the disks. You may have to take off quite a bit. I know I was there for quite a while.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 03-31-2006, 05:06 PM   #16465
onnetz's Avatar
I did sand them some to make sure they were smooth and even but it sounds like I'm gonna be sanding some more along with checking the holes in the disc for rough edges....
thanks for all the info guys..
Old 03-31-2006, 05:08 PM   #16466
Chris West's Avatar
Send a message via MSN to Chris West
i had a similar problem with my mtx-4 with the brake disc not staying completely vertical jut needed to file out the holes a little that the brake hub shafts go into and then it was sweet
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 03-31-2006, 05:09 PM   #16467
Chris West's Avatar
but the prospec one was ok as there was more surface area touching the brake hub shatfs
Old 03-31-2006, 05:27 PM   #16468
Also, the screw that hold the rear body post to the rear bulk head make sure it is not too long other wise it will press the rear bearing of the diff and would also, cause drag and possible handling issue aswell.
Old 04-01-2006, 12:40 AM   #16469
onnetz's Avatar
Default clutch question
how many shims are some of you using in the clutch?
I have no shims behind the collet or at the end of the shaft and have almost no play in the bell....
the engine is the sts d12x with original collet.
Old 04-01-2006, 02:20 AM   #16470
Chris West's Avatar
depends on your engine none will be the same so it doesnt mattter how many shims you have all that really matters is the clutch gap and how tight you have the spring
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
