Old 02-06-2006, 08:52 PM   #16351
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Scott, that is a real interesting one to stick in the back of my head just in case I run into a similiar problem...I don't think I would have checked that for a long time....
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 02-06-2006, 10:02 PM   #16352
Derby Bros Racing's Avatar
that's the main reason why the prospec didn't come with a titanium main shaft
the hallow steel works pretty good though.
Derby Bros Racing is offline   Reply With Quote
Old 02-06-2006, 10:08 PM   #16353
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by asw7576
..... upon corner exit I gave it full throttle, the engine rpm screamed, but the car slips or didn't run ..... I have to re- gas again and then the car run. The effect is something like that ( loose flywheel ).
I check the shimming...... I admit my clutch bell clearance is too narrow ( very little play ).
A friend of mine suspect the one way bearing on 1st Spur Gear.
I have seen this problem quite a bit after cleaning the car up. The one way bearing on the 2 speed shaft is over lubed or wet from cleaning. Take the hub off and clean the bearing out, then put (1 drop of oil back on it).
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 02-06-2006, 10:23 PM   #16354
asw7576's Avatar
Okey... thanks guys !!! It's either the main shaft or one way bearing. I change the one way bearing first and test the result.
Old 02-06-2006, 10:30 PM   #16355
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
You may have been the one that called this to my attention. Either way, I am now running a skyline hollow steel shaft, but I am going to try the Kfactory hardened aluminum version. I am going to weigh them both this weekend and see which is lighter.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-07-2006, 12:24 AM   #16356
Chris West's Avatar
Send a message via MSN to Chris West
Slotmachine reduce the size of your sig, its way too big
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 02-09-2006, 01:05 PM   #16357
Default one way vs. diff???
In what scenerios would you run a front diff instead of a one way? And, should your front diff oil be the same as the rear??? I run 50k in the rear and thinking about trying a front diff instead of the one way. Thanks!
MikeyG is offline   Reply With Quote
Old 02-09-2006, 01:54 PM   #16358
the front diff is used for small technical tracks where used of brakes is a must. generally, the front diff should be stiffer than the rear (i.e. 50k front, 30k rear). this makes it easier coming out of the turn on power. if the rear is stiffer than the front, the rear will bite more coming out of the turn making the car want to spin out.
Old 02-09-2006, 02:05 PM   #16359
good info...Thanks. Are there many racers who use the same diff oil in each (i.e. 50k r & f)?
Old 02-09-2006, 02:13 PM   #16360
i don't know if there is a lot using the same for the diff, but i've tried it before and i didn't have much luck with it. i like the front to be stiffer as it makes the car easier to drive aggressively.
Old 02-09-2006, 02:17 PM   #16361
Data's Avatar
EBAY ?!?!?!?!
jo you are losing it....
Data is offline   Reply With Quote
Old 02-09-2006, 02:19 PM   #16362
Originally Posted by Data
EBAY ?!?!?!?!
.... in the process of updating
Old 02-09-2006, 07:19 PM   #16363
GMartinez's Avatar
Trader Rating: 85 (100%+)
What up Tige how ya been
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 02-10-2006, 06:39 AM   #16364
devious17's Avatar
today I finally put an end to mending my prospec chassis . Was trying out new setup on the prospec ,front one wat, rear 50k diff, 50wt front and rear dampers on blue mugen springs, 3 holes from top damper mouting and 3 rear.
Did a high velocity sweeper and the car wandered a bit and got planted onto the metal fencing.Prospec chassis bent to the shape resembling a Z ! front right upright torn clean from the pivot balls, rear right lower arm broken at the hinge pin. Broken T/B servo mount
looks like I have to make use of the 3mm chassis now. The prospec 4mm now looks like a crumpled card board after being hammered flat
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 02-10-2006, 11:39 AM   #16365
I have two prospec used chassis that are useable. At least one of them is for sure. Neither is perfectly flat. One of them (without pins) I changed because of a problem that I thought the chassis was tweeked. It really isn't that bad, but I never tried the chassis again. The other chassis I just changed before a big race. The car handled perfectly. If you PM me your address and paypal me six dollars (assuming you live in the continental USA) to cover the mailing, I will send them to you.
My paypal is [email protected]
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
