Old 01-28-2006, 11:11 AM   #16306
asw7576's Avatar
Originally Posted by devious17
Todays weather was excellent! I can foresee buggy days are coming back once again.
The mtx3 ran in a total of 14 tanks full today. First time running a one way in front............I think I will switch back to diff next time. The early throttle off really gets to me, I kinda prefer charging down a corner and braking at the very last moment while chucking the car into the corner. With the one way braking is like almost virtual! I had to change my braking style to merely jab at the brakes for a split second otherwise the car will spin. I guess it is time to fully utilise the ABS braking system and retard the throttle exponential to eliminate on throttle spin on my 3Pk. Has anyone use ABS and throttle exp to run your car with one ways? I'd appreciate a base setup or any setup that your are usiing on your Tx now.
Crashed a few times trying to learn the one way handling.Also did one "long flight" crash, cliped an island at full speed and sent the car airborne no less than 5 meters.
Maybe I should give it a few more runs to see if I can adapt or really hate it that much.
practise and patience ........if my wallet can hold on that long
need new shell again.........
Reduce brake EPA, maybe like 40% - 50%. I'm using 40%, so I can safely brake at mid corner without spinning. I marked red circle where I applied brake ( if I feel understeer ).
I don't use ABS function in my 3PK..... Maybe it won't solve the rear spin problem because it still lost the traction at initial brake anyway.... I don't know. Wanna test it ?
Old 01-28-2006, 12:05 PM   #16307
Corse-R's Avatar
Do yourself a favor and get the teflon brake pads (yellow ones), braking with those is much easier and progressive.
BTW: MTX3 with foams the way to go is with front-one way. Overtaking the turns, jamming the brakes and trying to throw the car into the curb can look spectacular, but is slow on the chrono, much better to try to get a more constant speed and being gente (in fact, if you have such problems of getting excessive wear of the rear tyres).
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-28-2006, 12:24 PM   #16308
krisnata's Avatar
Location: Everybody wants to go to Heaven..... but Nobody wants to die
asw, senayan trak was the thumbnail, wasn't it ?
krisnata is offline   Reply With Quote
Old 01-28-2006, 12:38 PM   #16309
asw7576's Avatar
yes
Old 01-28-2006, 06:17 PM   #16310
devious17's Avatar
I knew you were going to say that,yes, I am on the teflon pads a long while ago. I will try the ABS function to kick in throught the braking into corners trying to simulate my braking technique like I was on diff still.
Tyre wear? I ran used front 42(HPI) for smaller diameter and new 40 (GQ)rear yesterday and the rear still wears out faster.
rcabj,asw7576 , yeah, I have increased the brake linkage length but not the EPA, will try out the ABS and let you know.
By looking at your braking spot you are braking much later than i am, I guess I need to reduce the brake further.Will try the EPA this time.
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 01-28-2006, 08:15 PM   #16311
Derby Bros Racing's Avatar
for those of you who are using 16/19 belts, i now have them instock again and listed. if interested, please PM me for more info.
Thanks!
Derby Bros Racing is offline   Reply With Quote
Old 01-28-2006, 08:22 PM   #16312
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I'm thinking of buying a brand new mtx3 kit at my LHS...unless anyone has a prospec vs for sale or something? Ran at FBF (Floyd bennet field) today and I wasn't really impressed with my R40. Think it's bout time I finally make that change.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 01-28-2006, 08:23 PM   #16313
Corse-R's Avatar
As I told you previously, tyre wear is a matter of how you drive, how you setup your car and many other things, you cannot pretend drag race on each straigh, smash the brakes when a turn is over and try to conserve your tyres. Doesn't matter how hard tyres you may try, you'll ever wear much your rear tyres than fronts.
He can brake much later because he drives and maintains a driveline who keeps the car stable into the curbs, he can be globally faster than you, just because he enters with the car under control and he can accelerate earlier because their car is stable, he will overlap you in few turns, I could be for this.
Don't try to make up a por set-up car going agressive, the key is to keep the most constant speed around all the track, doesn't matter if you at the backstraight go over 90Km/hr if you need to brake up to 10 just to take the turn. Get some fresh tyres, start over from the stock setup and try another time with one-way.
Cheers,
Corse-R
Old 01-28-2006, 08:32 PM   #16314
Corse-R's Avatar
Sorry, don't be fooled by the 'attractive' prices of MTX-3 is a good, but old car, all we have it, we're proud of it, but the MTX4 is out there since some time and the way to go is the MTX4.
The '4' is way better than the '3', I have all two and each day I'm faster and faster than with the MTX3. For me the retire time of the MTX3 is very near, probably on two weeks or three.
Buy whatever you want, but my advice is to get the new kit, the ProSpec looks really good, but the MTX4 is better and you will have plenty of spare parts for this model for some time, Mugen told that spares for '3' will be out there for some time, but didn't told for how long.
Cheers,
Corse-R
Old 01-28-2006, 08:45 PM   #16315
HarKonnenD's Avatar
GOod call then. I'll think about the 4 and how I'd get it. I'd be out of a TC for a while, but more time to get the 8th running.
Old 01-28-2006, 10:11 PM   #16316
HarKonnenD's Avatar
Wait, doesn't most of the 4 fit anyway? I mean surely it's all driver, but I guess having the MTX4 is kinda nice. A friend of mine ran a mostly box stock MTX3 and he dominated over a lot of racers at revalation.
Old 01-29-2006, 12:44 AM   #16317
devious17's Avatar
Agreed with corse-R, go the mtx4 way. My LHS told me there will be spares for the mtx3 for another year to come but untill it runs out of parts I will stick to the mtx3 untill I get my stuff right
corse-R, you are right about the setup and all, after all I am considered a rookie in 1/10 still, lots more to learn.Thanks Dude, appreciate it.
Audio,Video, Disco
Old 01-30-2006, 07:31 AM   #16318
devious17's Avatar
After one hard day at the tracks today I finally realised one way is so much better and the best part is I could still throw the car into corners BUT minus the rear anti roll bars. Today the mtx3 clocked 9 tanks of fuel and one good set of foams. The ABS function was great BUT it drained my Rx battery too fast so Ihad to turn it off and reduce braking EXP to 48%,just enough to slow the car down and EPA to max out at just harder braking.
Half way through I got into engine problem, the middle screw had plans of it's own and it gave me one heck of a day trying to find out why on rolling sprint the engine boggs like a hog..........darn screws.
Audio,Video, Disco
Old 01-30-2006, 08:00 AM   #16319
asw7576's Avatar
If you increase the height of rear upper link ( lets say 6mm ), the car is more forgiving in middle of cornering and more stable under hard acceleration.
Btw, I don't use stabilizer at all front and rear. I feel more sideways grip. Get traction roll problem ? Shave the front tires 60mm, Rear 63mm. More negative chamber especially front if it exhibits traction roll.
Old 01-30-2006, 09:27 AM   #16320
devious17's Avatar
Thanks asw7576, I will try the 6mm rear camber link too.
I was a coincident(actually I forgot) that I took off the rear roll bars cause the kFactory's brace was missing a set screw,then it hit me "lets try without ém" and I like it a lot.
I dont have a tyre truer to reduce the foam tyres unfortunately, what I am doing now is to rotate the front tyres from the previous set heh heh...used front with new rear everytime........it is becoming an expensive affair.
Audio,Video, Disco
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
