Old 01-25-2006, 06:05 AM   #16291
devious17's Avatar
recently ran 60wt front and 50wt rear on 42shore foams, blue 1.7 mugen springs........didn't like the understeer a bit....changed to 50wt front and rear and now feeling much better.
Audio,Video, Disco
devious17 is offline   Reply With Quote
Old 01-26-2006, 09:19 AM   #16292
Gemnic's Avatar
Is K Factory the only place where I can get a lightweight 2speed shaft ?
Gemnic is offline   Reply With Quote
Old 01-26-2006, 09:40 AM   #16293
Derby Bros Racing's Avatar
you can get others like the one by Skyline
i know it says it's for MTX-4, but the 2-speed shaft is the same for the 3 and 4
Derby Bros Racing is offline   Reply With Quote
Old 01-26-2006, 12:06 PM   #16294
devious17's Avatar
What wt diff oil do you guys run on a relatively new high bite semi technical tracks? I will be runing one way front (for the first time) and a 50kwt diff oil at the rear. Wanted to go 30kwt but ran out of it so 50kwt it is for now......wonder if it'll throw like the 1/8's do into corners
Audio,Video, Disco
Old 01-26-2006, 12:20 PM   #16295
Corse-R's Avatar
Done some tests in the past and found that 30k on the MTX3 goes really fine on large tracks.
If you're going to a smaller and technical track, maybe you can do some dirty trick I tried in the past. Go with a 30k or go with a 50k but remove the o-rings that goes on the planetary gears to free it a little (is very noticeable, done it on the past when I've run out of a diff oil and worked for me).
If you want to trow the car into the corners like 1/8, you need to have a very good setup for your car, think that entering into the corners like this demands a lot to the tyres and the engine.
Better to have the clutch well adjusted to avoid as much stress as possible.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-26-2006, 12:45 PM   #16296
devious17's Avatar
Thanks Corse-R
My RB V12 is on it's way out so no worries about the engine, I got my clutch tightened and it is showing about 3mm of the shaft from the nut, by this I can jab the throttle to about 50% and the clutch still wont bite.
I do mostly club races and toying with the idea of going RB v15
Corse-R, when you mentioned good setup for throwing the car like the 1/8, what do you mean? More of every settings?
Audio,Video, Disco
Old 01-26-2006, 04:27 PM   #16297
Corse-R's Avatar
Huh!... 3mm of the shaft from the nut? Really... what kind of clutch spring are you using? Hard? Super Hard?.
I routinely use the Super Hard, the stock weights with a 3mm drill (the lighter ones come with two drills and are 'too light' for my personal tastes ,the red clutch shoe and about 1.7mm of 'shaft' - I suppose you're referring to the nut that locks the flywheel to the crank). This setup along 0.65mm of clutch bell gap gives me a great clutch (enough loose for not touching the shoe and really disconnect the engine from the transmission, less wear of the shoe, and lots of punch when I mash the throttle).
For less traction I go for 0.7 or 0.75mm and gives me a more sweet clutch, less punchy and if I have lots of traction I go for 0.6 to show real muscle.
Is the same
With a sedan car is quite difficult to have the insane grip that offers Lola based bodies, but, when I referred to this I was thinking on a car with a really quick steering and quick reactions (probably on a setup like you need to use gray springs and almost vertical front anti roll bar...). Sometimes a set of 42's lasted only 15minutes (insane grip and a surface like sandpaper - was a really nightmare to all we were running there).
Cheers,
Corse-R
Old 01-26-2006, 06:31 PM   #16298
Gemnic's Avatar
Old 01-26-2006, 06:58 PM   #16299
devious17's Avatar
corse-R, I am running hard springs only otherwise I dont think I could push the spring that low. What do you mean by drill ?
The clutch are standard prospec items and yes it is the shaft that I am refering to.
On our local tracks, a vertical roll bar would need at least 38 shore or it'll be understeer fest all day long heh heh
Audio,Video, Disco
Old 01-27-2006, 12:36 AM   #16300
Corse-R's Avatar
The old 'stock' clutch weights were full (without holes) and someday needed a set lighter than the old but not that much of the prospec ones who came with two holes, so drilled a 1/8" hole on the weights just to remove weight.
That's why I said for a setup for throwing the car into the turns as a 1/8 scale, track conditions should be ones that warrants you will have enough grip, whatever you may do. Be sweet with your car and with a little less spectacular driving (just be on the line) you will be awarded with better laptimes.
Cheers,
Corse-R
Old 01-27-2006, 02:37 AM   #16301
devious17's Avatar
I understand the drill thingy now. Are you refering to making holes on the 4 individual pieces or the one round piece?
My individual pieces are already having 2 holes each and none on the one piece. If you drilled holes on the round one piece wont you have balancing issues?
I totally agree with you on the driving habit but I have this tendency to get agressive when I am chassing someone
Just finished setting the car up ,
42 front 40 rear
50wt all round
-4 rear -2.5 front camber
castor neutral
anti roll bars flatfront and rear(Kfactory item)
5mm front 6mm rear height
3 front and rear droop
3 from top front and 2 from top rear damper mount
one way front and 50k wt rear
25% fuel with 10% castor
2mm raised rear camber link
my usual on the web setup sheet
Drats! the GQ foams I bought has 2mm rear offset .........oh well
Audio,Video, Disco
Old 01-27-2006, 09:04 AM   #16302
Corse-R's Avatar
Did the holes on the 4 small pieces (weights), not on the round one (clutch shoe).
Cheers,
Corse-R
Old 01-27-2006, 05:54 PM   #16303
devious17's Avatar
I have even seen modified clutch shoe, some made grooves on it for ventilation and some cut out parts of the shoe to reduce weight. They'll try anything
Audio,Video, Disco
Old 01-28-2006, 08:09 AM   #16304
devious17's Avatar
Todays weather was excellent! I can foresee buggy days are coming back once again.
The mtx3 ran in a total of 14 tanks full today. First time running a one way in front............I think I will switch back to diff next time. The early throttle off really gets to me, I kinda prefer charging down a corner and braking at the very last moment while chucking the car into the corner. With the one way braking is like almost virtual! I had to change my braking style to merely jab at the brakes for a split second otherwise the car will spin. I guess it is time to fully utilise the ABS braking system and retard the throttle exponential to eliminate on throttle spin on my 3Pk. Has anyone use ABS and throttle exp to run your car with one ways? I'd appreciate a base setup or any setup that your are usiing on your Tx now.
Crashed a few times trying to learn the one way handling.Also did one "long flight" crash, cliped an island at full speed and sent the car airborne no less than 5 meters.
Maybe I should give it a few more runs to see if I can adapt or really hate it that much.
practise and patience ........if my wallet can hold on that long
need new shell again.........
Audio,Video, Disco
Old 01-28-2006, 09:43 AM   #16305
rcabj's Avatar
Default one way and brakes"
wow 14 tanks....like one full day of racing, ...with a one way u only need to adjust the braking so that the car will not spins when full braking...no need to use abs....
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
