Mugen MTX-3
man this car is awsome this car is so much better than my ntc3 i had for about 2yrs, turns in great and can really hug the apex of the corner, 10x better! but i had a problem my engine was fat the 2times i ran it in qualifer, so i got that all worked out then started to get glitches @ the end of the straight @ full rpm and mph, looked @ all wires and none are cut, open, no wires to see, so i rearranged the wires in the box & still getting glitches any ideas? also tried new crystals
Assuming that you have already change with new crystal, you should check the receiver is dry and free from fuel splashes. Make sure all connectors ( metal to metal ) feel tight.
Double layers double tape to reduce vibration.
Only managed to run a 3 tanks full before I went airborne clipping an apex curb that sent my car flying to the metal fencing ......broke the rear bulk head that holds onto the rear shock tower, drats.
Initiall feel with the new setup is steering feels less aggressive and with a tinge of understeer. Going to get ém spare for the next run.
One remedy to this was to put a slightly longer screws there (take care of not hitting the diff bearing putting a too long screw, don't remember if they were 3x10 or 3x12mm if 10mm long, put a 12mm. If 12mm put a 15mm screw to have more meat of the rear bulkheads gripping the rear shock stay bulkhead.
Good idea, i could meaure the depth of the hole and change the screw accordingly.
One other thing I noticed today, when the gear shifts to second the front of the car actually lift! both front wheels were off the ground! At first I thought it was the heat so I got the guy in the pit to keep an eye on it and they confirmed it!
front shock 3 holes front outside/rear two from top.50wt -2 camber front/-4 rear camber. Front/rear toe remain. - sorry, my personal notepad. Lazy to jot ém on paper
Originally Posted by Corse-R
Welcome to the club. That was the achylles heel of that car. Many of us suffered of this (and many DNF's were due to this).
Originally Posted by asw7576
It's 12mm screw if you talking like in the picture, see the arrow marking in the attachment.
track width
just wonderin....i am running mostly 199mm front width, and 200mm rear...what other combo's ru guys running...tq
198 front, 199 rear
i do this to be safe when my car goes to that tech board...
when there's no tech, i use it anyways so when time comes and i need to race a sanctioned race, i'm used to legal width.
200 front
199 rear
199 rear
Parts lot
I am interested in purchasing extra parts for my mtx3 prospec.
wanted new in package:
front universals
front arms
springs
etc...
Let me know what you are willing to sell at [email protected].
Thanks,
Mike
front universals
front arms
springs
etc...
Thanks,
Mike
200 front
199 rear
199 rear
Originally Posted by rcabj
u sure or u mistype...
I'm setting like that for flip proved.
shock oil
Sure, 200 front.
..anyway regarding shock oil..i've been using something like 70/80 wt oil like forever ...recently change to 50wt oil all round just to see the different reaction of the car....i notice a more grippier setup rather than b4,not a very large difference ...
...anyway i like to hear u guys comment a bit through your experience liking/dislike on oil choices...thanks
Yes, mine is little bit understeering under full throttle....... anyway that's the way I like it. Infact I use two piston holes at front and one piston hole at rear with light blue springs all around and 40wt oil. Maybe because my car is gawd damn stiff ( 4mm chassis from 3 racing + 5mm CF upper deck ).
