Old 12-05-2005, 12:02 PM   #16171
wendellc1's Avatar
4mm is a major split! I've tried 1.5mm before and it worked great until it reaches 1mm. Then the car drives horrible. I will try 2-2.5mm. Thanks.
wendellc1 is offline   Reply With Quote
Old 12-08-2005, 12:59 PM   #16172
asw7576's Avatar
Is this me or happen to mtx3 owners :
Is it normal when rear tires become smaller in diameter than front the car's handling become worse and worser. ....... for examples, when the car turn and exit in tight corner, the car might skid for split seconds ( rear tires skid sideways ). It's annoying because I lose confident and push me to take next corners slower. This is not bottom out issue.
Old 12-08-2005, 01:31 PM   #16173
Derby Bros Racing's Avatar
you need to install the 16/19 conversion belt and have a 2mm split on your tires. this will help the tire wear become almost even. the stock setting is fine if you're track is very low wear. but like in my case, i use the 16/19 on my mtx-3.
Derby Bros Racing is offline   Reply With Quote
Old 12-08-2005, 07:20 PM   #16174
asw7576's Avatar
Jo, I have mtx3 prospec with original pulleys and original gearings.
What I have to change to get 16/19 conversion ? Thx
Old 12-08-2005, 07:33 PM   #16175
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
You need to buy the MTX3 pulley set. Right now you have a 19tooth side pulley on the rear and a 24 tooth on the front. Remove the 24 tooth front and put it aside. Take the rear pulley (19 teeth) and move that pulley to the front. Now take the 16 tooth pulley out of the bag of new pulleys and put it on the rear. You will also need a shorter side belt. Kawahara makes one. I am also about 99% sure that team taylor racing has the conversion side belts. You can find him at www.teamtaylorracing.net. If you can't find it on his website, then call or email him. He probably has the pulley set as well.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 12-08-2005, 07:48 PM   #16176
asw7576's Avatar
Thanks Scott
I have mtx3 pulleys bags. Gonna try next weekend. I hope the original middle belt is not too lose.
Old 12-08-2005, 08:00 PM   #16177
When I tried the 16/19 conversion I had the shorter belt. I never tried the stock belt but I would say that I am 99% sure that the stock side belt will be too long to run the 16/19 conversion.
Old 12-09-2005, 12:18 AM   #16178
you need to have the conversion belt. i used to sell the belts on ebay. i have sold more than 800 conversion belts!!! i don't sell them anymore because i thought the demand was not as much anymore. also, most of the people who bought from me probably still have spares because most of them bought bulk (5 sometimes 10 belts per order!)
but i might list it again towards the end of december because i do have them instock.
Old 12-09-2005, 11:39 AM   #16179
asw7576's Avatar
Thanks guys
I'm planning to look shorter belts in my LHS, I hope one of G4 or RRR or 710 middle belt is shorter than mtx3's.
What other benefits of running 16/19 conversion beside even tire wear ?
Cheers.
Old 12-12-2005, 05:00 PM   #16180
Jammin'Trey's Avatar
Send a message via ICQ to Jammin'Trey
Does anyone have a stock setup for the MTX-3, left my manual at the track.
Jammin'Trey is offline   Reply With Quote
Old 12-12-2005, 05:39 PM   #16181
Speedbug's Avatar
See if these help, otherwise log onto the mugen web site you can down load the whole manual.
http://www.mugenseiki.com/menueefi.htm
Speedbug is offline   Reply With Quote
Old 12-12-2005, 06:49 PM   #16182
My computer has dial up so it won't load PDF files, sooo... I guess I was mainly looking for rear diff oil and camber.
Old 12-12-2005, 07:17 PM   #16183
10K rear diff
camber start out -2 in the front and -4 in the rear. and then adjust as you run the car. i.e. when the tires are coning in (more meat on the outside than inside of tire), decrease camber and vice versa.
hope this helps
Old 12-12-2005, 11:25 PM   #16184
asw7576's Avatar
Jo, you want to play MRX4 now ?
Old 12-12-2005, 11:45 PM   #16185
TexasRacer's Avatar
Send a message via AIM to TexasRacer
To let you know the Traxxas 4-TEC side belt will fit with the 19/16 conversion
TexasRacer is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
