Old 10-31-2005, 04:04 PM   #16081
Toma2525's Avatar
another question for everyone. I have an M8 and would really like some help in figuring out what settings i should be using and what some of these settings mean. Anyone running an MTX-3 and an M8 that can lend a helping hand? Thanks everyone!
Yokomo BD7...TQRC Raceway Chino, CA
Toma2525 is offline   Reply With Quote
Old 10-31-2005, 08:23 PM   #16082
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Originally Posted by Toma2525
So I have a problem. Got the universals, installed, hit the track! Everything is great except for a slight problem. On power, the car jolts to the right. It seems to track straight but hit the gas and the car bolts to the right everytime. Any ideas anyone?? What should i check. Where should i start?
Was this problem there before you installed the new uni's?
Of course check the obvious belts, pulleys and shocks (not binding). Check suspension "uptravel" to make sure BOTH front tires leave the ground at the same time when lifting the front chassis up off the ground. Just use a long screw driver and place in under the front chassis from the front of the car. Now lift up using the screwdriver as a prybar until the chassis begins to lift off the ground noting when the two front wheels come off the ground. They should "lift off" at the same time.
JAG Racing is offline   Reply With Quote
Old 10-31-2005, 08:25 PM   #16083
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Of course check the obvious belts, pulleys and shocks (not binding). Check suspension "uptravel" to make sure BOTH front tires leave the ground at the same time when lifting the front chassis up off the ground. Just use a long screw driver and place in under the front chassis from the front of the car. Now lift up and the screwdriver until the chassis begins to lift off the ground noting when the two front wheels come off the ground. They should "lift off" at the same time.
And if it dont lift off at the same time. How can you fix this?
Riketsu is offline   Reply With Quote
Old 10-31-2005, 08:33 PM   #16084
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Either you missed a set screw when you built the Universals, or your one way is not working propperly.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 10-31-2005, 08:33 PM   #16085
Suspended
ntro75's Avatar
do you have a set up board?..basicaly you have to measure everything to make sure that its even on both sides,make sure your up&down stops are equal as well.make sure you have the same suspention travel on both sides,also what do you have in the rear diff for fluid?what weight?
ntro75 is offline   Reply With Quote
Old 10-31-2005, 08:33 PM   #16086
JAG Racing's Avatar
Check the photo. This same process will work for the rear also. Check this with and without the shocks mounted; should be the same otherwise it points to "shock problem".
Old 11-01-2005, 12:55 AM   #16087
Don't forget the anti roll bar is also adjustable for tweak using the excentric bracket at one side.
One of the guys at our track had bent one side of his anti roll bar after an impact
Bob The Builder is offline   Reply With Quote
Old 11-01-2005, 09:01 AM   #16088
Toma2525's Avatar
i will check and try the suggestions. i have been contiplating investing in a setup board system to measure everything. i have a feeling that your suggestions coupled with a setup board should help me nail down the problem. i had the problem before the universals were installed also. not sure the weight i used in the rear diff. i have a front one-way installed. i will also pull the shocks off and rebuild them, making sure they are both equal in length.
Thanks everyone.
Old 11-01-2005, 09:23 AM   #16089
JLock's Avatar
Thanks everyone.
Integy has a neat set-up board/system that is around $130 that has everything that you need. You need to invest in a setup board/system is you are going to do more serious racing. This was a hard lesson I learned a couple of years back (use to eyeball everything).
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 11-01-2005, 10:11 PM   #16090
gentleman81's Avatar
how do u use that cam thing on the roll bar up front.
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 11-02-2005, 12:54 AM   #16091
Toma2525's Avatar
i saw an ad for the integy station and it looks really nice...not to expensive. sounds like it might help and save me some headaches down the road. I will give you all an update after some wrenching and some more track time.
Can anyone provide some help regarding setting up my M8 with my MTX-3?
Old 11-02-2005, 02:05 AM   #16092
It is used to equal the effec the anti roll bar has on each side.
With the car sat on set up blocks - check the droop on each side and make them equal if possible ( If not possible you will need to use the cam to do it )
Then when you have the droop equal - start to lift the hub on one side and see how far it moves before the opposite side hub starts to lift.
Do the same the opposite side and make sure that the amount of lift is the same to move the opposing hub.
Adjust the cam until both are equal.
Then re-check your droop.
Rear anti roll bar is adjusted by changing the length of the links going between the anti roll bar and the wishbone.
Old 11-02-2005, 05:52 PM   #16093
otay
Old 11-06-2005, 12:07 PM   #16094
Toma2525's Avatar
Well, i heeded the advice of most of you and seemed to have nailed down the problem to un-even arm travel....apparently, i never bothered to adjust (or install in some cases) the various set screws that manage the arms!!!
After getting the setup station, adjusting all of the setscrews to where everything was even i hit the track and WOW!! It was a different car...actually drivable. I did however run into another problem that is stumping me. i traction roll alot. i figure i need to stiffen up the suspension a bit, go with stronger springs, reduce roll etc. any suggestions???
Thanks again everyone....really made a difference!
Old 11-06-2005, 12:29 PM   #16095
Derby Bros Racing's Avatar
maybe you're using too soft of tires for your track. try going 1 shore up (i.e. from 37shore to 40shore) with your tires. this is the easiest fix. next lower the car if it's riding too high. then if it's still traction rolling, add more camber and go one more shore up (i.e. from 40shore to 42 shore) on your tires.
hope this helps
Derby Bros Racing is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
