Old 10-06-2005, 08:34 AM   #16021
JLock's Avatar
Stefan,
I was meshing mine starting with the second gear and letting the first gear mesh fall where ever it did. With that method, I was still stripping the second gear. I even ran a mesh that was as tight as possible without binding and it still stripped. Once I went back to the 1.0 pitch gears, I have not had a problem with gears stripping. I even changed to a stiffer chassis and still had the problem when using the 0.8 gears. The mounts to the chassis and motor were tight and I checked after every run. Go figure.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 10-06-2005, 08:37 AM   #16022
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Originally Posted by stefan
I have seen a buddy waisting 3 second gear spurgears in one day.
We found out that he was adjusting mesh only at the first pinion/spur and never checked how mesh was at second gear.
He always had his engine mounted at an angle.The first gear mesh was fine, the second was way too big.
How are you doing it?
Understood - I always check both gears when setting clearance. I will be paying more attention to these issues.
Thanks for all of the tips guys!
JAG Racing is offline   Reply With Quote
Old 10-06-2005, 08:40 AM   #16023
JAG Racing's Avatar
Default off topic
Maybe off topic here but you guys should be able to help .... I have seen many guys using a carbide coated file for doing the final tire edge trueing on foams.... Do any of you have a source for this carbide file?
Old 10-06-2005, 09:01 AM   #16024
JLock's Avatar
You can get a file from your local Home Depot, Lowe's, or any other hardware or department store. When truing tires, you round the edges so that they don't catch when the tires roll and chunk them. Your buddies Ron Atomic and Todd Bath showed me this over a year ago.
Texas 5
Old 10-06-2005, 09:02 AM   #16025
stefan's Avatar
Send a message via AIM to stefan
Just get a rasp/file combination from any hardware store. Costs a fraction and does the same thing.
stefan is offline   Reply With Quote
Old 10-06-2005, 09:04 AM   #16026
stefan's Avatar
Originally Posted by JLock
Stefan,
That's why I never switched to 0.8 module.
Nobody is able to tell me the advantage of the 0.8 modul anyways.
Old 10-06-2005, 09:21 AM   #16027
JLock's Avatar
The 0.8 pitch gears give you a bit more top-end speed in first and second gears at mid-size to large tracks. It also gives you a bit more gear tuning for the track size over the 1.0 pitch gears. However, the 1.0 gears are thicker, tougher, and can take more abuse than the 0.8 gears. Your mesh does not have to be precise with the 1.0 over the 0.8. I did notice a difference in top-end speed and punch out of corners with the 0.8 over the 1.0 with the Mugen X-12 motor I was using. But with the stripping of the gears, it was costing me more in parts and finishing positions/trophies at the track than what it was worth.
Texas 5
Old 10-06-2005, 10:40 AM   #16028
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
.8 module gears have two advantages.
1st: You can make more subtle changes to your gear ratio with these gears as they have more teeth to them.
2nd: This one is minor, but is true. During the rotation of the engine, because there are more teeth the mesh is smoother. Closer to a direct drive type situation. There is less friction in the power transfer and therefore it gives a more effective transfer of power. It is slight, but there is a little bit more power with these gears.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-06-2005, 03:19 PM   #16029
asw7576's Avatar
Stefan,
Check & rebuild the rear bulkhead and bearings for the 2 speed shaft. I suggest to use longer screws like SJG3 x 12mm to hold the rear & front bulkheads.
After couple of month of torture, believe it or not, the spur gear actually became smaller ( less outer diameter ) despite of still okey look. You notice the bottom engine mounting screws become closer to rear side.
Also pay attention to bottom plate underneath pinion gears' endbell. Sometimes the endbell touch the bottom of chassis. You can see the scratches. I have to dremel a bit the chassis so the endbell doesn't touch it anymore.
What brand of the aforementioned stiffer chassis ?
Old 10-06-2005, 10:50 PM   #16030
gentleman81's Avatar
Default .8 gears
so are .8 gears more trouble than they are worth. what is the key to get them to last and not cause problems? i am running first in points right now and just changed to .8 gears, is this a smart move?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 10-06-2005, 11:00 PM   #16031
Keep your mesh with little play and kepp your car on its wheels and you will be just fine.
Old 10-07-2005, 12:55 AM   #16032
asw7576's Avatar
I'm using 0.8 gears and I have no problem as long as the mesh is right.
Old 10-07-2005, 05:23 AM   #16033
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Use a piece of paper in between the gears when your going to tighten the engine. Just apply pressure against the gears as much as you can. Try to apply the pressure moving the engine completely and not from an angle. When you take the piece of paper out (which has to be done by moving the gears up or down). You'll have a perfect mesh.
Riketsu is offline   Reply With Quote
Old 10-07-2005, 09:24 PM   #16034
Default 0.8 gears
I think I may have an advantage from my days of running electric touring cars, 64 pitch gears will strip if you just look at them wrong!! I have never stripped a gear since I started running the 0.8 gears, I think it due to two things:
1. Good mesh, the paper trick works if you are new to the fine tooth gear mesh game. Be sure to check your 1st gear mesh if you set the second gear with the first gear removed, the 2nd gear can "appear" to be set right but the motor can be cocked to one side and then your 1st gear mesh will be too tight or loose.
2. Don't hit the dots (duh?) this causes the 2nd gear alot of strain when the wheels contact the track again because the 2nd gear engages in the air and slams it with too much torque.
Is it worth the added expense to switch from 1.0 gears? No if you don't pay attention to the mesh, Yes for the performance advantage if you do, my humble opinion.
DocSafety is offline   Reply With Quote
Old 10-07-2005, 10:44 PM   #16035
so mesh it right and stay on the ground. sounds good thanks
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
