Old 09-16-2005, 08:40 PM   #15961
gentleman81's Avatar
will to much turn in cause the rear end to break loose or should the rear end be able to handle it with the correct setup?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 09-16-2005, 11:20 PM   #15962
asw7576's Avatar
This is yes and no answer, in other words, your setup is not perfect yet. There are many ways to overcome the problem such as softer springs, softer damping oil, softer rear tires.
Try C steering ackerman : C is the softest turning action eventhough you have fast hand. Some people have smooth hand and some don't ( like me ).
You could also try to reduce dual rate and exponential rate from your radio tuning option.
Old 09-19-2005, 10:06 PM   #15963
Default update
i have been picking you racers brains all season and it has paid of tremendous, i am currently first in my class with an absence of the leader at one race but anyway. my car has gotten better and better with every race. the biggest improvement came after setting my droop for the first time! never thought up travel would hurt but weight transfer is the key.
calming down and not going full throw every turn is a good idea too, just taking my time and driving the car. my setup and driving got me two laps over my best race this sunday and it was great!!!! thanks again
Old 09-20-2005, 09:42 AM   #15964
asw7576's Avatar
Wanna get MTX4 with MTX3 ? I think it's do able : Custom made radio plate, Get MTX4 fuel tank, Custom made bottom plate for battery, Side Pack AAA batteries.
What do you think ?
Old 09-20-2005, 09:56 AM   #15965
Derby Bros Racing's Avatar
to the machinist hands, yes, it probably is doable. but to me, i'll just get the real deal and go with the mtx-4
Derby Bros Racing is offline   Reply With Quote
Old 09-20-2005, 04:12 PM   #15966
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
Default Changes????
I saw the pics on the Mugen thread too. Your forgetting the geometry changes involved. 5.5mm longer arms for starters. The car just looks alike. I bet their's only 40% parts interchangability...My biggest impression was the 5cell flat pack. They couldn't do that from the start? Also the easy diff/oneway removal is a major plus!
Nick Altieri
TeamNitro RC Club, New Home track- Ho Chunk Southland Expo, Lynwood IL
Serpent 748 Natrix WC, PICCO EMX "R", Spektrum DX4RPro, Futaba servos
977 EVO2, Matrix tires, Picco power.
Please drive responsibly
TeamCarnage is offline   Reply With Quote
Old 09-23-2005, 01:18 PM   #15967
Send a message via AIM to jeff whiting
I am going to be racing this track in Ohio for the next two weekends and it is part of the Midwest Series in the US . It looks way bigger than I am used to. Any one out there race at this track that can give my Mugen and I good starting point setup? Gears, tires, springs for sure would be helpful. I need a starting point. Hopefully I got the link in here correctly.
JEFF
http://www.tri-statercautoracers.com...pics/track.jpg
Thanks to our sponsors: Desoto Racing, Serpent, Ielasi Tuned, HobbyWing, Byron's Fuel, Matrix Tires, Protoform, Futaba, www.LEFComplex.com
jeff whiting is offline   Reply With Quote
Old 09-23-2005, 05:53 PM   #15968
wehbad2003's Avatar
Default Info Midwest series Race
The track has Changed several times . That picture is old I ran there two year's ago with Larry Stone . I think that picture was a couple years old then. All I can tell you is run in the middle on your first gear, and your largest second gear ratio. Straight is about 250 feet or so . This track is Soooo Sweet 40 's on rear 42's on front 1 deg camber front 2 deg camber rear front toe 1 deg rear toe . This track is very fast as for springs depends on Your driving style . Track is very smooth with excellent traction. Start from here and adjust . NO front diff oneway only .
wehbad2003 is offline   Reply With Quote
Old 09-23-2005, 07:27 PM   #15969
Ok thanks. That sounds about right. I just got my Prospec so, I need to pick up some gears. I am looking forward to it. The biggest track I have run on so far was this year at the Beat the Heat race in Memphis which for me was hugh. The Nashville track and Alabama tracks I usually run are small and you run the lowest pinions you have and you have to run a front diff or even a front spool if the bit is good. Should be fun!!
JEFF
Old 09-23-2005, 08:19 PM   #15970
Just wonder is it neccessary to provide tire traction compound for sponge tire during a long race. Will it help to reduce wear and better grip?
MARKANO is offline   Reply With Quote
Old 09-24-2005, 02:34 AM   #15971
asw7576's Avatar
I don't think so, tire compound will not last 30 minutes main nor reduce tires wear. Better grip ? yes for first 5 minutes.
I suggest to check your setup again like ride height, tires thickness and chamber. I think tire compound is not necessary when you are using fresh new tires. However, 1 month old tires maybe need tire compound to soften the sponge.
Old 09-24-2005, 06:09 AM   #15972
HarKonnenD's Avatar
Send a message via AIM to HarKonnenD
Anyone think I should sell my two current onroads and toss in some $$ for the MTX3 prospec or just get one of ebay? I never really bought a used ride.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 09-24-2005, 07:25 AM   #15973
asw7576's Avatar
Yes, sell them and get MTX4 or MTX3 prospec.
This is what I do if I have to buy MTX3 Prospec :
1. Buy Front & Rear suspension arms from MTX4 ( don't know if they are fit or no.... must try first ). MTX4's suspension arms are wider than the 3.
2. Position throttle servo's ears underneath carbon fiber radio plate. See MTX4 photo.
3. Re-route the servo + on-off wires to the inside ( between throttle servo and fuel tank ).
4. And these from 3racing :
Old 09-24-2005, 09:43 AM   #15974
HarKonnenD's Avatar
Yeah, I'll think about it as I'm in need of a spektrum radio. Wah, you mean after the prospec buy all that? C'mon is it really necessary?
Old 09-24-2005, 10:23 AM   #15975
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Don't sell....
Trade me!!!!
nsxshogun is offline   Reply With Quote
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
