Mugen MTX-3
Old 08-22-2005, 07:44 PM
  #15751
raffaelli's Avatar
Same here.
They hold heat, the rims never break or crack, the foam is durable and has as much bite as any other foam.....priced right also.
raffaelli is offline
Old 08-22-2005, 08:12 PM
  #15752
Trader Rating: 28 (100%+)
The GQ's are fine. I used them for a while and they did offer me a sponsorship. I stopped using them, because availability was not consistant. I have switched to Fast Tires on the MTX wheels. The fast tires can be purchased at Ace or Nitrohouse for a very good price. Ace normally charges $15/pr but you buy 3 and get 1 for free. That comes out to $11.25/pr. That is a great deal for a US dealer.
Scott Fisher is offline
Old 08-22-2005, 08:38 PM
  #15753
Trader Rating: 15 (100%+)
Originally Posted by Seisick
had the same problem, 2 speed getting stuck within the 2d gear housing, just tight the 4mm set screws a little.
mine are separated more than a milimeter, it is new, it's just the 2 speed aluminum housing with wear!
Yea I noticed that the cam had a little bit of slop when it was inside of the shoes. I just ordered some new shoes to be on the safe side. Going to NJ this weekend. Thanks
THE DOCTOR is offline
Old 08-22-2005, 08:59 PM
  #15754
MAVICXXX's Avatar
hey,i solved d prob by getting few tips from last few pages,1st chnge d ball from 3mm to 4mm,2nd-nonid d ball,just get 8mm setscrew d same size currently 4mm,slam direct,u wil enjoy running wit it even up to 3 races..
MAVICXXX is offline
Old 08-22-2005, 09:00 PM
  #15755
Fsturbo15's Avatar
Ellegi's.
I am going to try Jaco 2 stage foams after this pair.
Fsturbo15 is offline
Old 08-22-2005, 09:39 PM
  #15756
ProSpec4evr's Avatar
I have found that the best tires to use are the Fast Tires with the MTX3 rims.....all others are good... i just found these to be the best
ProSpec4evr is offline
Old 08-22-2005, 10:30 PM
  #15757
mkristanto's Avatar
Default tires
I agree. especially with off set.
But i found kawahara tires are good too and Ellegi is also works well
mkristanto is offline
Old 08-22-2005, 10:57 PM
  #15758
factory racer's Avatar
can you not use for example jaco nitro shoes 0degree off set...do you have to use a off set or can u use 0degree offset........
one question.....i need all of your opinions on this
Should i get a mugen mtx-3 prospec for a good price now or should i wait till the beggining of the season and get one ...........do you guys think the prices will go down considering the mtx-4 is comin gout
thanks
Mike
factory racer is offline
Old 08-22-2005, 11:04 PM
  #15759
Fsturbo15's Avatar
thanks
Mike
- You can use zero degree off set tires and 2 degree offset tires, you may need to do some ajusting.
- I'd wait for the MTX-4, it will be around $350 which is cheaper than what the prospec is priced right now.
Old 08-22-2005, 11:20 PM
  #15760
asw7576's Avatar
How do you know MTX4 will be price around $350 ? I think it's fair price considering the price of V1 RRR and 710.
asw7576 is offline
Old 08-23-2005, 12:09 AM
  #15761
Fsturbo15's Avatar
How do I know?
Mike confirmed it for us a while back.
The MTX-4 will not be more expensive then a MTX-3 Prospec. The MTX-4 is going to be about the same price as a standard MTX-3.
Old 08-23-2005, 12:11 AM
  #15762
asw7576's Avatar
Originally Posted by Slotmachine
Thats just WIERD Nelly!
I've been using this idea about 5 months. I haven't replace the clutch since new. Periodical 1 month check is necessary to save TO233 from slip damage.
asw7576 is offline
Old 08-23-2005, 10:36 AM
  #15763
yeah but the mtx-4 wont be a prospec will it????
thanks
Mike
Old 08-23-2005, 10:48 AM
  #15764
Seisick's Avatar
found the same dilemma, get the mtx4 stock or wait for the prospec. Ive got my mtx3 stock about 2 years and it runs strong as brand new! Ill wait for the prospec version to come out some time next year and see what are the pros and cons once the 4 comes out. too bad that the 4 wont come with front universals and al engine mount
Seisick is offline
Old 08-23-2005, 11:35 AM
  #15765
Originally Posted by 22dasher
what brand foams are you guys using on your MTX-3? I just ordered the Fast foams for mine just trying to find other alternate tire sources.
James
I've used GRP Devils with great results, you can get them from www.nitrohouse.com for $9 bucks a pair.
EJRacer is offline
