Mugen MTX-3
Originally Posted by ProSpec4evr
By taking off the sway bars... the car will roll more while in the corners
I think that yes i't will give you a little bit more of traction. That is if the track is a little loose..
But any quick switch backs the car will be very slow to rebound back to the other direction.
Originally Posted by performula
What effects will happen by taking sway bars off?
Be careful with traction roll, mtx3 happens to flip easy. You could overcome the flip problems with lower ride height, softer springs, lighter oil weight.
I have a good used mtx3 prosprec for sale with servos for 300!!
Originally Posted by THE DOCTOR
I was wondering if there is a set measurement when the second gear clutch shoes need to be replaced? My clutch got stuck today. The inside of the clutch bell is 1.151 and the clutch shoes measure 1.172 when it is on the outside of the hub riding on the small ball that is inside of the shoe.( if this makes sence)
It was alot closer when it got stuck todayin the main. Do these measurements sound right?
mine are separated more than a milimeter, it is new, it's just the 2 speed aluminum housing with wear!
Has anyone tried the new engine by novarossi? LL5 tuned by nova
does anyone have a good setup for a pretty tight -high traction ashphalt track..............does the mtx-3 like softer shock oil ?????????what weight ??????????does it like softer springs????can i use the AE spring set????
and does it like soft foams or harder foams???? bigger or smaller cut foams??????????
thanks
Mike
thanks
Mike
second gear clutch
the doctor
i dont even used that little ball in the midlle
check your clutch it might be stipped
i'll be runnin that hyper motor for the charity race
Originally Posted by dg8one
the doctor
Originally Posted by gonzoY5
How is that possible? Without anything there the cam will just spin free.
mine dont
mine dont
Thats just WIERD Nelly!
what brand foams are you guys using on your MTX-3? I just ordered the Fast foams for mine just trying to find other alternate tire sources.
James
James
22dasher,
I run GQ foams on my MTX-3, they work well and wear real good too, just one guys opinion...I ran them before they sponsored me so you can take that for what it is worth
