Old 07-31-2005, 07:10 PM   #15646
Default servos?
i have 3rwc serio evo 3 futaba s9252 & s9451. will build it soon.
i just recieved a mtx 3 pro spec, haven't bought the motor or the servos yet. i've heard certain servos don't work well with certain cars, can anyone let me know what works well in the mtx?
also ;
2 savages
2 revos
1 v one rr for sale
anthony750 is offline   Reply With Quote
Old 07-31-2005, 07:26 PM   #15647
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
The MTX does not seem to have problems with servo size. Any standard servo should fit ok.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-31-2005, 07:35 PM   #15648
Default servos?
ok, thanks!
Old 07-31-2005, 08:29 PM   #15649
Fsturbo15's Avatar
Send a message via AIM to Fsturbo15
Anyone have a solid axle aka spool for sale.(I think they're the same)
Fsturbo15 is offline   Reply With Quote
Old 08-01-2005, 01:14 AM   #15650
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Nitrohouse.com Acehardwarehobbies.com PersisionRC.com Rcmart.com and a few other shops that sell mugen parts will have them. Also checkout speedsterhobbies.com they have the new jaco's on sale also....
nsxshogun is offline   Reply With Quote
Old 08-01-2005, 07:18 PM   #15651
Seisick's Avatar
for those in need for more racing time without reacharging, panasonic's hhr-4hpa/2b are the newest aaa ni-mah you can find, the label says 1350mah.
I bet Mike didn't know about these new batteries.
price $7 for each pair.
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 08-02-2005, 12:02 AM   #15652
afm
afm's Avatar
Where did you get them.
AFM
afm is offline   Reply With Quote
Old 08-02-2005, 12:11 AM   #15653
What pipe are you guys using with the Mugen X12 engine?
snowboardgeek1 is offline   Reply With Quote
Old 08-02-2005, 01:11 AM   #15654
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
shadow1208
Tech Apprenticef: The spool should be ran on a small tight technical coarse with lots of traction. The Diff should be used when you have a small track with little traction or where you would have a small tight track. The one-way works best on a large sweeping turn type track.
Also, I have the Kawahara part for the person looking for the spool. Part is new in Package....PM sent
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 08-02-2005, 07:47 AM   #15655
Thanks rcfoolz, I have a tight track and was using the dif, but the car wouldn't turn. I switched to the spool and now the car is real loose, I guess I will have to find a way to get a little more rear bite without making it push like a dump truck.
Thanks Again
shadow1208 is offline   Reply With Quote
Old 08-02-2005, 11:51 AM   #15656
Derby Bros Racing's Avatar
try 30k diff oil in the front and 10k in the rear.
Derby Bros Racing is offline   Reply With Quote
Old 08-02-2005, 04:04 PM   #15657
I have tried from 50K down to 5K in the front and from 30K down to 3K in the rear. If that diff is in the car it just pushes like crazy, mostly off power but still a small amount on power. The car is a lot better with a spool, its just real loose.
Old 08-02-2005, 04:28 PM   #15658
what is your toe in on the front, if its to far in you wont have enough steering, also try changing the caster on the car, the less caster u use the better the steering you will get.
ATXPro4 is offline   Reply With Quote
Old 08-02-2005, 05:16 PM   #15659
I had from 0 to 2 degrees out on the toe and had the least amount of caster. I even pulled the front swaybar, ran thinner shock oil, softer springs and softer tires and still couldn't get the steering needed. The car is alot better with the spool and so are my lap times. I just really have to work the throttle to keep the car under me. I thought that a tight parking lot track with so so traction would suit the diff more, but I guess not.
Old 08-02-2005, 06:22 PM   #15660
you may try this and get a similar result from a solid front diff but a little forgiving which may help.
leave whatever you have in the rear diff.
put 70k or 100k diff oil in the front.
also, it helps to lower the front ride height. try 2mm split with tire and ride height. i.e. 3.5mm front and 5.5mm rear ride height and 60 tire front and 62 tire rear. it will give you a lot of turn in.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
