Old 07-24-2005, 05:51 PM   #15601
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
you can run the 22 with the 29, you just have to change the 58 spur to a 59. You will have less stripping if you keep the tooth differences equal.
IE: 29t and a 22t. 7 tooth difference. Use a 52 and a 59. You could use a 53 and a 60t spur.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-24-2005, 06:53 PM   #15602
Bandeira's Avatar
Send a message via ICQ to Bandeira
Gonna try...
I'm planning to order a Kfactory 23t gear...(at least if there isn't a typo at the website)
Anybody tested them? They are quite cheap... are they nice?
Bandeira is offline   Reply With Quote
Old 07-25-2005, 01:42 AM   #15603
gonzoY5's Avatar
Originally Posted by Bandeira
Gonna try...
I think that KFactory 23t is a 2nd Gear pinion with the 1.0 Mesh
gonzoY5 is offline   Reply With Quote
Old 07-25-2005, 02:33 AM   #15604
Default new pro spec
does anyone know if there is an engine in a pro spec box? the net instructions say no pipe or manifold, but nothing of the engine. on the outside of the box it lists the engine with the standard features? do you know what roar legal engine does well in this car? thanks, ant
anthony750 is offline   Reply With Quote
Old 07-25-2005, 07:39 AM   #15605
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Cool
No the prospec does not come with an engine, pipe, body, tyres or radio gear.
Cheers Daniel
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 07-25-2005, 07:48 AM   #15606
RichChang's Avatar
Default Spring pounds
Hi,
Does anyone know what pounds the various Mugen springs are?
ie: is the purple spring 20 pounds?
purple - ?
light blue - ?
dark blue - ?
grey - ?
Thanks,
-Rich
RichChang is offline   Reply With Quote
Old 07-25-2005, 10:24 AM   #15607
Trader Rating: 15 (100%+)
I have a question about my car getting a lot of oil around the back of the car and making the second gear clutch slip. I pulled the diff apart last week and put a new gasket in it and all of the screws are tight. It is throwing oil even to the front of the car. Could it be the seal on the engine and the clutch bell is what is throwing the oil all over the place? Anyone have this before?
THE DOCTOR is offline   Reply With Quote
Old 07-25-2005, 10:35 AM   #15608
gonzoY5's Avatar
Originally Posted by RichChang
Hi,
purple - ?
light blue - ?
dark blue - ?
grey - ?
Thanks,
-Rich
Do a search for spring rates. Or look back a few pages. I know someone just posted the info from one of the recent Car Mags. But i can't remember which thread it was on.
Old 07-25-2005, 11:36 AM   #15609
gijoe64's Avatar
Trader Rating: 30 (100%+)
You are filling your rear diff up to much. Fill the rear diff just so that the oil covers the cross pins holding the diff gears.
gijoe64 is offline   Reply With Quote
Old 07-25-2005, 12:44 PM   #15610
sohlman's Avatar
Trader Rating: 89 (100%+)
Hi,
purple - ?
light blue - ?
dark blue - ?
grey - ?
Thanks,
-Rich
purple - 1.6
light blue - 1.7
grey - 1.8
white - 1.9
dark blue is between light blue and gray
Steve Sohl
sohlman is offline   Reply With Quote
Old 07-25-2005, 01:04 PM   #15611
Hi,
purple - ?
light blue - ?
dark blue - ?
grey - ?
Thanks,
-Rich
Sohlman,
I think he was looking for lbs not wire thickness.
Rich Chang,
Purple front springs= 25lbs
Purple rear springs= 21lbs
Light blue fronts springs= 31lbs
Light blue rear springs= 27lbs
Dark Blue front springs= 32lbs
Dark blue rear springs= 27lbs
Grey front springs= 35lbs
Grey rear springs= 30lbs
All measurements were taken using the Xipp spring dyno.
And the tenths, hundreths, and thousanths were all rounded off to nearest denomination. Hope this helps.
Jamie Corrado is offline   Reply With Quote
Old 07-25-2005, 01:05 PM   #15612
Sohlman ,
Give me a call.
Old 07-25-2005, 01:38 PM   #15613
sohlman's Avatar
D'ohhhh! My bad.
Steve Sohl
Old 07-25-2005, 04:28 PM   #15614
Seisick's Avatar
Guys! all things being equal and without worrries on the performance on the straight! what is the best way to vent the engine; with the hole half on the roof (like swauger´s car) both windows cut, just the left window; half the back window, etc etc? the bodies to be used are mazda and stratus, just want to know. I´m currently using the mazda with 50mm hole straight to the engine on the upper part of the front window and with both front window cut and 60mm hole straight on the back window. for what i´ve heard,front windows cut will provide more venting on tight tracks, back window totally cut will be faster on straight but with a slightly higher temp. and the front circle higher will provide more temps but with a higher performance due to less resisance and air coming and easy to reach tank. replies appreciated!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 07-25-2005, 06:48 PM   #15615
I found the problem. The two sealing washers for the fuel line onto the carb where leaking. I sanded them flat and reinstalled them and no more leaks. It was coming off of the carb and dripping onto the brake disc. The brake disc was spraying it everywhere. Thanks for the reply back gijoe64.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
